Author Topic: IBM 1370477 101 key  (Read 1697 times)
Offline pj1976
IBM 1370477 101 key
« on: Fri, 23 September 2016, 12:06:38 »
I just seen this was posted on ebay!   is this a good deal!!?
http://www.ebay.com/itm/152252518362
Offline y11971alex
  • Looking for Toronto meetup
Re: IBM 1370477 101 key
« Reply #1 on: Fri, 23 September 2016, 12:23:31 »
This should be posted in Great Finds.  And I'd say it's a good deal, but most Model M keyboards in good condition are as good as new; some would even say used specimens are better, since their springs are mellowed by use.  It's not a particularly rare sub-model, either.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Fri, 23 September 2016, 12:26:06 »
No, it's not a good deal, not even close.   New in box is irrelevant for M's unless you're going to put it on a shelf.
