Author Topic: Should I sand my QFR Top Plate before Painting?  (Read 2059 times)
Offline Madone6
  • Slurpee Shill
« on: Sun, 02 October 2016, 12:59:03 »
I'm thinking of painting my QFR and it has a soft touch finish, should I sand it before painting?
Offline Badwrench
  • ummmm.....I forgot
Re: Should I sand my QFR Top Plate before Painting?
« Reply #1 on: Sun, 02 October 2016, 13:04:23 »
Yes, you will want to sand it off before you paint.
Here are some good links to help you out:
https://geekhack.org/index.php?board=152.0
Offline Madone6
  • Slurpee Shill
« Reply #2 on: Sun, 02 October 2016, 13:14:35 »
Thanks Man!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Sun, 02 October 2016, 13:18:03 »
Definitely sand that rubbery coating. It is really not much effort; comes off quick.
« Reply #4 on: Wed, 05 October 2016, 04:30:51 »
A bit more direct information on sanding here.
Offline punksinatra
    • Random Stuff
« Reply #5 on: Thu, 06 October 2016, 05:01:58 »
I just finished repainting mine and sanding it down took roughly 3 hours. I used 400grit wet sanding.
