Author Topic: Keycap combination/color Suggestion  (Read 8945 times)
Offline punksinatra
    • Random Stuff
« on: Thu, 06 October 2016, 03:48:56 »
Hi Guys,
I recently painted my CM QFR to a shade of blue (photo attached). Just want to get ideas for keycap color combination. If you got photos or link to a photo as a sample would help much. Thanks  ;D
Re: Keycap combination/color Suggestion
« Reply #1 on: Thu, 06 October 2016, 04:22:56 »
Yellow would go very well with that!
Or blue.  Or blue and yellow!
Offline punksinatra
    • Random Stuff
« Reply #2 on: Thu, 06 October 2016, 08:24:28 »
I am trying to imagine how it would look hahaha you have any photos you can refer me too.. too bad wasdkeyboards does not allow changing the board color so I can test it huhuhu
« Reply #3 on: Thu, 06 October 2016, 20:41:07 »
No, sorry, but yellow goes with everything :D
Offline punksinatra
    • Random Stuff
« Reply #4 on: Fri, 07 October 2016, 02:34:45 »
Too bad ain't got friend who uses yellow keycaps I would like to try before I buy..
Well I did have some extra caps around and tried them on with several combination and something like this I came up with. Thoughts?
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #5 on: Fri, 07 October 2016, 03:26:08 »
GMK hydro would look awesome on this build
« Reply #6 on: Fri, 07 October 2016, 04:36:35 »
Is that case together properly?  Or are they especially low profile keycaps?  My QFR keycaps stick out a lot higher above the case than that.
I prefer \| and `~ to be the same colours as the alphas, but otherwise it's a nice combination :)
Offline punksinatra
    • Random Stuff
« Reply #7 on: Fri, 07 October 2016, 04:38:17 »
Nope this is how it looks with the top case properly put
Offline punksinatra
    • Random Stuff
« Reply #8 on: Fri, 07 October 2016, 04:38:45 »
Hey thanks do you have photos of that?
Offline punksinatra
    • Random Stuff
« Reply #9 on: Fri, 07 October 2016, 04:41:40 »
Oh nevermind I think I know that set unfortunately I wasn't able to get into the gb
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #10 on: Fri, 07 October 2016, 04:42:04 »
i got it off the IC page of hydro but the GB just ended tho.
https://geekhack.org/index.php?topic=83881.msg2234441#msg2234441
 :thumb:
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #11 on: Fri, 07 October 2016, 04:42:55 »
lol too late. posted it.
anyhow you could check out my IC on gmk black lotus haha but i dont think that would fit right with the color of your case haha
« Reply #12 on: Fri, 07 October 2016, 04:47:25 »
The Filco yellow keycaps are great, but don't look quite this yellow in real life, unless you happen to get the lighting right ...
149924-0
Offline punksinatra
    • Random Stuff
« Reply #13 on: Fri, 07 October 2016, 04:47:36 »
 :thumb:
Yeah but when I go to pre order they are still accepting from keyclack.com
Offline punksinatra
    • Random Stuff
« Reply #14 on: Fri, 07 October 2016, 05:47:46 »
Ok I may still have a chance for the hydro set
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #15 on: Fri, 07 October 2016, 09:29:40 »
Go for it!
Offline seville57
« Reply #16 on: Fri, 07 October 2016, 10:29:28 »
Blue and Yellow, the Swedish flag.
« Reply #17 on: Sun, 09 October 2016, 04:03:07 »
Your next task is to design a keyboard with this pattern made from its keycaps.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #18 on: Sun, 09 October 2016, 06:21:54 »
GMK Dolch + CMYK Mods all the way :eek:
like-a-dis by Mr. Hoff. Except for that spacebar. What's up with the orange spacebar? :-X
Offline punksinatra
    • Random Stuff
« Reply #19 on: Sun, 09 October 2016, 06:26:52 »
Looks ok just not sure if it will match the paint
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #20 on: Sun, 09 October 2016, 06:36:39 »
Welp. How about Skidata? I think the pic is by JaccoW
https://geekhack.org/index.php?topic=35672.150
Offline punksinatra
    • Random Stuff
« Reply #21 on: Sun, 09 October 2016, 06:56:46 »
Hmm I think I saw someone selling that set in the classifieds section
Offline punksinatra
    • Random Stuff
« Reply #22 on: Sun, 09 October 2016, 07:03:05 »
This too bad its missing 1 key
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #23 on: Sun, 09 October 2016, 07:05:52 »
aw nuts :(
Offline punksinatra
    • Random Stuff
« Reply #24 on: Sun, 09 October 2016, 08:05:18 »
aw nuts :(
Yup too bad.. I did fine another possible set.. do you know what these keycaps are called?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #25 on: Sun, 09 October 2016, 09:49:21 »
aw nuts :(
Hmmm,  I can't place it with a EU/US vendor. At first, I thought Skydolch but the set in your picture is the same color as Skydolch modifiers which is weird. So strange to see the cyan/black without the light gray alpha keycaps. Surely someone will recognize it
« Reply #26 on: Sun, 09 October 2016, 20:37:59 »
aw nuts :(
"Begin" instead of "Home" - haven't seen that before!
Offline benderkey
« Reply #27 on: Mon, 10 October 2016, 10:52:55 »
Try looking at Keypuller for color schemes.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #28 on: Mon, 10 October 2016, 15:01:24 »
aw nuts :(
Haha that is less confusing imo
Offline punksinatra
    • Random Stuff
« Reply #29 on: Mon, 10 October 2016, 22:15:10 »
It is not a custom wasd set is it?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #30 on: Tue, 11 October 2016, 00:36:18 »
It doesn't appear to have the UV coating that WASD places on their keycaps. I suppose someone could have sent in a fully custom .svg keyset design for WASD to print and the designer later stripped the keycaps of the UV coating. That seems very unlikely, though.
Offline MJL
« Reply #31 on: Tue, 18 October 2016, 05:39:33 »
Blue modifiers and white letters?
http://www.ebay.com.au/itm/Double-Shot-Keycap-104-Set-for-Chery-MX-Keyboard-Key-Caps-Blue-White-/271608725745?hash=item3f3d2440f1:g:AZYAAOSwnDZUGFAJ
I have not got mine yet but am thinking about navy modifiers and blue letters (sorry no picture).
Offline punksinatra
    • Random Stuff
« Reply #32 on: Fri, 11 November 2016, 22:29:04 »
Hey thanks for the suggestion
Hmm I might check and consider that.. so far I have tested these
152728-0152730-1
