Author Topic: [help] AMJ pad led not working  (Read 2303 times)
Offline Munnybear
« on: Fri, 07 October 2016, 14:43:35 »
Hi,
I have an AMJ number pad that works fine with no led. However, when I tried to add LED to the num lock it wouldn't light up. I only want to tell if the num lock is on. Much appreciated for any helps!
Munny
« Last Edit: Fri, 07 October 2016, 21:59:50 by Munnybear »
Offline Munnybear
Re: [help] AMJ pad led not working
« Reply #1 on: Sat, 08 October 2016, 08:05:37 »
I am thinking if this has anything to do with the firmware as I did flush it with my custom configs and I did not write anything for lighting...
« Reply #2 on: Sat, 08 October 2016, 08:37:11 »
Sounds likely, that or the LED is in backwards?
Offline Munnybear
« Reply #3 on: Sat, 08 October 2016, 09:32:20 »
Pretty sure it was... long end through the square hole... right?
Offline Data
« Reply #4 on: Sat, 08 October 2016, 14:26:31 »
That's the standard polarity.
Did you test the LED before you installed it?  Did you also install a resistor?
