Author Topic: Looking for fluorescent/green/yellow set  (Read 3296 times)
Offline Sock
« on: Mon, 17 October 2016, 15:05:15 »
Sup guys, i'm looking for a fluorescent green/yellow key set. It needs to be UK layout and i'm open to all kinds of sets how they look etc.
I won one of the Bro PowerCore's today. So i'm trying to dig around to see what matching sets would fit it.
This is the colour i'm trying to match things up to.
https://ctrlalt.io/invasion-pt-ii/products/power-core
Thankssssss :D
Offline 1swt2gs
  • DOGE
Re: Looking for fluorescent/green/yellow set
« Reply #1 on: Mon, 17 October 2016, 19:15:22 »
Gonna be hard to find a full set that matches that color.
I won the same set and most likely will be using it on a black blank set, going for the opposite of hugely contrasting it.
Would really make the artisan stand out and pop.
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
« Reply #2 on: Mon, 17 October 2016, 21:01:45 »
For a yellow set, you could dream about Turtle Power: http://keypuller.com/turtle-power/
For green, perhaps Toxic.
« Reply #3 on: Mon, 17 October 2016, 21:08:04 »
I'd go with Toxic if you want something fluorescent.  The only other option I know about is the Massdrop Toxic knockoff/wannabe set.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #4 on: Mon, 17 October 2016, 22:08:59 »
Matching power core is gonna be tough. I second going with a black set to make the Bro really pop as an accent.
Offline Sock
« Reply #5 on: Tue, 18 October 2016, 04:56:11 »
How would I go about buying that set? that looks like an old post.
Thanks for the input guys maybe some blank black keys might pretty sick
« Reply #6 on: Tue, 18 October 2016, 09:47:16 »
It's a separate buy o MD now, but I think it's 60% only.  It looks like a cheap imitation of Toxic to me though.  Toxic really would be the best set for you to try and find if you want a bright color.  Otherwise, like others have said, a nice dark set would look best.
Offline Vigrith
« Reply #7 on: Tue, 18 October 2016, 09:53:00 »
Toxic would be the dream with Power Core in my opinion, I got one of them too - hoping Toxic gets run once again after Bunny manages to sort out all the issues with the previous run. According to the progress stated it shouldn't take too long now.
« Reply #9 on: Tue, 18 October 2016, 10:32:05 »
+1
all praise WoB
Offline Minnie2
« Reply #10 on: Tue, 01 November 2016, 00:20:52 »
I think ur keyboard should be white, then grey caps will fit this bro.
    A Bro Caps Fan
Just wanted to make sure everyone sees that information. A lot of people missed it ;)
