Author Topic: [IC] SP SA Mechanist (Restart!)  (Read 449732 times)
Offline hoq
    • wolfmark.work
Re: [IC] SA Mechanist ( 40% kit and novelties revised 2016-11-17)
« Reply #100 on: Wed, 16 November 2016, 21:27:25 »
Some novelty keys revised.
« Last Edit: Fri, 02 December 2016, 08:25:00 by hoq »
Offline ticktwo
  • -kbdfan
« Reply #101 on: Thu, 17 November 2016, 00:53:51 »
Frozen Alphas with TKL is a good set   :-*
HHKB | Leopold FC750R | Mech27 (soon) | TX-75 (soon)
Offline brianjking
  • always carry a towel.
    • @brianjking
« Reply #102 on: Tue, 22 November 2016, 10:07:43 »
Nice, very interested!
Offline GreyAmbience
  • I can stop when ever I want
« Reply #103 on: Tue, 22 November 2016, 14:31:49 »
Just found this, and hot damn frozen alphas board looks amazing. I'm in!
Offline davisthegreat
    • 3DKeebs
« Reply #104 on: Wed, 23 November 2016, 00:42:24 »
Love it! Certainly interested
By looking at the sets would the Adapter kit cover the TADA68 and the new RS96 verIII ( currently on MD)?
Offline hoq
    • wolfmark.work
« Reply #105 on: Wed, 23 November 2016, 10:17:16 »
Maybe you should buy a Planck/Atomic kit to match a 68 layout.  :)
Offline hoq
    • wolfmark.work
« Reply #106 on: Wed, 23 November 2016, 10:19:26 »
06.P/A kit
« Last Edit: Fri, 02 December 2016, 09:02:31 by hoq »
Offline elfick
  • Can I get Colemak and a side of fries with that?
« Reply #107 on: Wed, 23 November 2016, 10:33:40 »
I looked but couldn't really tell... Is there a 1.5 R3 BBJ anywhere in any of the sets? Legend doesn't matter.
Offline hoq
    • wolfmark.work
« Reply #108 on: Wed, 23 November 2016, 10:59:44 »
We haven't made a 1.5u BBJ key in R3. Where do you want to use?
Offline elfick
« Reply #109 on: Wed, 23 November 2016, 11:12:11 »
It would be my enter key in a custom layout but I know there are 1.5 R3 caps in the set that I could use. I just wanted a dash of that sweet BBJ color and I didn't think I'd end up with any. I forgot that I could use the two 1.25 R3 BBJ caps from Novelties-1 in my bottom row so no worries. :D
Offline Data
« Reply #110 on: Wed, 23 November 2016, 11:30:20 »
Wow, that's a lot of kits.  :eek:
Offline hoq
    • wolfmark.work
« Reply #111 on: Wed, 23 November 2016, 19:12:57 »
That’s OK!
and as a suggestion, SA Dasher and Dancer keysets also have BBJ color keys with white legends,
If you really need a BBJ 1.5u R3 keycap, you should  go to have a look.
It will be launched in 12.12.2016.
Offline zslane
« Reply #112 on: Wed, 23 November 2016, 21:43:50 »
Indeed.
As I mentioned in the IC thread over at DT, I think Dasher/Dancer and Mechanist make for brilliant companion sets to each other.
Offline zslane
« Reply #113 on: Wed, 23 November 2016, 23:46:14 »
If I might offer one suggestion: you might not want to use BBJ legends with WA keycaps. The contrast is too low, IMO. Below is an image showing just the luma of two of your colorway samples, and you can see how poor the contrast is between the legends and the keycaps when BBJ legends are used on WA keycaps in the lower example. Notice how much better the contrast is when you use BFR for the legends, as in the upper example. Maybe go with something like BFP legends with the white keycaps.
Just something to consider.
153650-0
« Last Edit: Thu, 24 November 2016, 01:43:06 by zslane »
Offline hoq
    • wolfmark.work
« Reply #114 on: Thu, 24 November 2016, 02:29:04 »
Since the requirment is getting more and more, I added more keys and sets.
This makes us a little worried, even if the group opens oneday, some kits are hard to meet the moqs.
Offline hoq
    • wolfmark.work
« Reply #115 on: Thu, 24 November 2016, 02:54:32 »
Yes you are right.
the Frozen Alphas set looks a little  bit low contrast.
In fact, at the very beginning, we only developed the BFM Alphas (with BFR legend) as the main alpha set,
as some user want more choise ,We added the Fronzen Alphas set,
Frozen Alphas (WA with BBJ legend) look low contrast,but more elegent.
We will consider about  the font color, BFP or some other dark colors. Thank you.
Offline hoq
    • wolfmark.work
« Reply #116 on: Thu, 01 December 2016, 06:29:24 »
11 Novelties 2
« Last Edit: Fri, 02 December 2016, 08:02:23 by hoq »
Offline LXuelin
Re: [IC] SA Mechanist ( Signature Banner added 2016-12-03)
« Reply #117 on: Sun, 04 December 2016, 06:28:34 »
Vrey nice! :D
I am very expect this but it is too many kits. :-X :confused: :confused: I only wish I have enough money to buy them in next year.  :)
Also, I hope the color is the same as the picture。 ;)
Offline hoq
    • wolfmark.work
« Reply #118 on: Sun, 04 December 2016, 19:39:38 »
Vrey nice! :D
Thank you for your support.
In order to maintain the right color in PC software and in output pics.
I used RGB cord of each SP color.
you may refer to the color card below to see how deferent between the pics and your pc software.
                                                Hex color        RGB color
        deep blue   BFR   #293649      41,54,73
   blue           BBJ    #008fb0      0,143,176
   light blue   BFM   #abc6dc      171,198,220
   white           WA         #e4dedd      228,222,221
Offline robotmaxtron
« Reply #119 on: Wed, 14 December 2016, 16:21:14 »
Really really nice set.
Offline ricyuyc
« Reply #120 on: Fri, 23 December 2016, 08:50:31 »
pls. let me in  :)
Offline kmba
  • Formerly tameone
« Reply #121 on: Wed, 28 December 2016, 00:09:20 »
While this won't fit non-programmable 75% board, it will work for programmable thanks to the adapter set :thumb: excited to see this in a full render.
keyboards.
Offline LDobler
« Reply #122 on: Wed, 28 December 2016, 04:26:12 »
This set looks really nice! In for a TKL set when the GB starts  ;D
Offline hoq
    • wolfmark.work
« Reply #123 on: Wed, 28 December 2016, 05:50:51 »
Thank you for your appreciations.
I will update the renders in Jan.  :p
Hope you have a nice vacation all  !
Offline bkw1209
« Reply #124 on: Thu, 29 December 2016, 17:33:34 »
I want it!!!!!
Offline ChitownM2
« Reply #125 on: Sun, 01 January 2017, 20:46:24 »
Another solid looking keyset to consider. There are so many good IC kits right now that my wallet is going to be in serious trouble if they all make it to production.
Offline FLOCKA
  • New name: ghostdeini
« Reply #126 on: Mon, 02 January 2017, 12:23:53 »
Yes you are right.
Have you given more thought as to whether or not you'll change the frozen alphas' font color? I like this set so much, but my main concern is that it'll have the same problem as Chronicler (too low-contrast)
Offline hoq
    • wolfmark.work
« Reply #127 on: Mon, 02 January 2017, 21:00:57 »
I don't quite understand what color the Chronicler used, maybe the same with DCS Soware,
If it's the same with Soware, the alphas color are  GTD(BFQ). that‘s really difficult to identify the alphas at all.
I compared it with Frozen Alphas, obviously, the contrast of Frozen Alphas is higher.
or we can use BFR legends on WA keycaps to add more contrast.
I will make some mock-ups to show which is better later.
Personally, I like BBJ color on WA, that looks more "frozen" ;)
Offline hoq
    • wolfmark.work
Re: [IC] SA Mechanist ( Signature Banner added)
« Reply #128 on: Fri, 13 January 2017, 09:53:00 »
07. 40%
8. Minila
« Last Edit: Fri, 13 January 2017, 11:09:11 by hoq »
Offline hoq
    • wolfmark.work
« Reply #129 on: Sat, 14 January 2017, 02:45:13 »
9. Ergodox
Offline hoq
    • wolfmark.work
« Reply #130 on: Sat, 14 January 2017, 11:19:09 »
10 Novelties-1
12 Forums
13 Dvorak-Colemak
Offline alveeno
« Reply #131 on: Sat, 14 January 2017, 12:57:22 »
Alphas are two different bright colors, have you considered alphas of same color as mods? I would be down for those
Offline breusch91
« Reply #132 on: Sat, 14 January 2017, 18:15:32 »
I like the colors you have going on now but agree with alveeno, this might look really cool. I'd really like alphas the same color as the mods legends/novs. Kind of like how SA carbon ran the orange alphas that matched their novs/mod legends
« Last Edit: Sat, 14 January 2017, 18:18:05 by breusch91 »
Offline hoq
    • wolfmark.work
« Reply #133 on: Sat, 14 January 2017, 21:05:50 »
I tried to make a mock up pic as you required.
For the reference, the third pattern of the alphas changed to BBJ(BFR legend), They look like Carbon orange alphas color way.
but, I bend the color to black and white to check the contrast, they look even harder to identify the lengend.
« Last Edit: Sat, 14 January 2017, 22:45:07 by hoq »
Offline Parva Ovis
« Reply #134 on: Sat, 14 January 2017, 21:15:05 »
I don't like the idea of BBJ alphas, to be honest. It looks less like the cold and cool mechanism theme than the other two colors, and the contrast is too low. Plus, three different colors of alphas lowers the chances of any given color reaching MOQ or the price drop points. It's also very similar to Dancer SA. In fact, anyone who has their heart set on BBJ alphas could buy one of the extra MassDrop Dancer kits and mix it with Mechanist.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #135 on: Sat, 14 January 2017, 21:27:38 »
If this aint BFM (BFR), I will choke the living hell out of the goon that goes with any other way colour-way with this design.
Enough said here  >:( .
Offline hoq
    • wolfmark.work
« Reply #136 on: Sat, 14 January 2017, 22:48:37 »
Ease,bro. :D
I think the original two colors are better for daily use. I will keep the original design.
Offline hoq
    • wolfmark.work
« Reply #137 on: Sun, 15 January 2017, 09:32:05 »
14. International
15. ISO
Offline breusch91
« Reply #138 on: Sun, 15 January 2017, 10:01:13 »
You're right the new colored alphas would look to close to dasher/dancer and not as good in my opinion. I think alveeno was also saying try one were you kept the current mod base color but changed the mod legends to the color or the base alpha (BFM)
Either way I'm starting to get excited about this set!
Offline punksinatra
    • Random Stuff
« Reply #139 on: Sun, 15 January 2017, 11:31:56 »
Any 3D rendering? Can't picture it on my mind  :D
Offline cyberputty
« Reply #140 on: Sun, 15 January 2017, 13:07:35 »
If you actually managed to get a Dvorak layout made I'm on board.
Offline hoq
    • wolfmark.work
« Reply #141 on: Sun, 15 January 2017, 19:05:45 »
Of course there will be,
In fact, I'm a Colemak user, I must make a D/C kit.
Offline hoq
    • wolfmark.work
« Reply #142 on: Sun, 15 January 2017, 19:07:40 »
Still need some time to get a keyboard render, Please wait a moment.
Offline hoq
    • wolfmark.work
Re: [IC] SA Mechanist ( Signature Banner added+Renders are coming)
« Reply #143 on: Mon, 16 January 2017, 07:38:21 »
Offline elfick
« Reply #144 on: Mon, 16 January 2017, 08:59:04 »
New render looks awesome! I was leaning towards the original alphas but that render may sway me.
How are you going to handle the child kits that have heavy alpha content like Colevrak and Internation? Will you offer two versions to support both alpha colors or are you going to have a primary alpha color and only offer the child kits with that color?
Offline cyberputty
Re: [IC] SA Mechanist (Renders are coming)
« Reply #145 on: Mon, 16 January 2017, 12:12:30 »
When can I throw my money at you?
Offline hoq
    • wolfmark.work
« Reply #146 on: Mon, 16 January 2017, 20:21:37 »
I will keep the those child kits with the primary color (BFM), I will not make more Frozen Colevrak,ISO,International .because if I develope Colevrak and international with the same color of Frozen alphas, the kits become more and hard to hit the MOQ.
   I believe the BFM alpha also looks cool, I can't wait to make more renders to check how they look. Please wait a moment.
Offline kmba
  • Formerly tameone
« Reply #147 on: Mon, 16 January 2017, 20:31:58 »
Looks very nice in the render, and I'd definitely like to see the other alpha color mocked up.
keyboards.
Offline breusch91
« Reply #148 on: Tue, 17 January 2017, 21:22:06 »
the more i look at this the more excited i get. SA carbon is my favorite set and this feels like a blue version of that. I know they are different themes but i like that it follows the same setup as carbon with two different colored alphas and a row of 1u novelties. really like the way this is going so far and as long as it stays on this path ill definitely be committed to this.
Offline hoq
    • wolfmark.work
« Reply #149 on: Wed, 18 January 2017, 11:19:10 »
Thank you for you guys' appreciations.
Here are more renders, hope you like them :p
