Author Topic: [IC] SP SA Mechanist (Restart!)  (Read 449840 times)
Offline oh_chesteroni
Re: [IC] SP SA Mechanist (Restart!)
« Reply #300 on: Tue, 22 May 2018, 12:38:46 »
I'm digging regular alphas.
Offline Kerasan
« Reply #301 on: Tue, 22 May 2018, 13:17:40 »
Hi erveyone,
The IC restarts now, I haven't gived up this design, I want to make it happen.
I'm going to keep updating the drawings until the group buy starts one day!
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
This is really good news, I am anxiously waiting for this set ...
I have no preference between the two alpha kits, I would take them both
P.S. but has anything changed compared to the original idea?
KMK Labs.
Offline PotatoTM
« Reply #302 on: Tue, 22 May 2018, 16:32:14 »
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
Really great to hear you haven't given up on this design! Still very excited to see this happen.
Offline kyoumau
« Reply #303 on: Tue, 22 May 2018, 18:44:54 »
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
I'm happy to see news on this.
I like both alphas, especially the frozen alphas. The WFK white is a great color.
Offline hoq
    • wolfmark.work
« Reply #304 on: Tue, 22 May 2018, 19:55:02 »
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
Neat. I'd personally prefer the alphas over the frozen alphas -- I think there's enough sets out there that do the usual high-contrast stark light alpha/dark modifier combination.
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
I too like the alphas over the frozen alphas. I would say keep it with a cool color pallet. Do you know what will be the estimated cost of this set?
Thanks! Alphas' cool tone color is my initial inspiration of this design. I love it very much.
The cost of Mechanist will be similar to those popular SA key sets I think.
Offline hoq
    • wolfmark.work
Re: [IC] SA Mechanist (launch in 2018 with MD!)
« Reply #305 on: Tue, 22 May 2018, 20:06:43 »
This is an instant buy for me as long as I can have a 1.75 Control key.  Based on all the sketches / renders, it won't be a problem.
Any estimate as to when this will be available?
I'm still fairly new to the hobby, but is there a reason as to why a 1.75U control key is important? And which one of the kits will contain a 1.75U control key?
HHKB layout users are used to use 1.75U Control on caps lock's position.
Offline hoq
    • wolfmark.work
« Reply #306 on: Tue, 22 May 2018, 20:11:49 »
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
Thanks so much !
Offline hoq
    • wolfmark.work
« Reply #307 on: Tue, 22 May 2018, 20:13:27 »
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
KMK Labs.
Thanks, basically not that much change I think, just add several keys to match new keyboards such as FC980, UHK ....so on!
Offline gnunin
« Reply #308 on: Wed, 23 May 2018, 00:02:40 »
Those Frozen Alphas looks insanely good!  :eek:
Offline stu-rem
« Reply #309 on: Wed, 23 May 2018, 06:52:45 »
A large proportion of individuals like to have R3 control instead of capslock due to the infrequent use of capslock. Although its not necessary to have correct legends to do this, it is still nice for individuals who want correct legends.
+1
Many early terminals had Control where IBM PC put CapsLock, and HHKB stays faithful to that (plus less strain on the left little finger, often the weakest.)
My personal preference for CapsLock key is just BBQ IT AND DON'T LET PPL SHOUT IN ALL CAPS!  :-)
Sent from my SM-N9005 using Tapatalk
Offline Mcnos
    • GMK Fuyu
« Reply #310 on: Thu, 24 May 2018, 20:36:20 »
I'm down for this if it ever drops :D
Offline Peiweisgreat
« Reply #311 on: Sun, 27 May 2018, 05:11:23 »
Nice to see once again that this set isn't just a dream yet. Still digging everything about this set, so do what you gotta do. My wallet will be waiting.
Offline ramblinrose
« Reply #312 on: Sun, 27 May 2018, 12:44:45 »
Nice looking set! Would be hard to decide between the two alpha sets!
Offline goodman247
  • It's confirmed, I'm an idiot.
« Reply #313 on: Sun, 27 May 2018, 22:39:28 »
Hope this set can happen!! GL, pushing for this!!
Offline breusch91
« Reply #314 on: Mon, 28 May 2018, 00:46:41 »
Can we still expect to see other kits, such as the Ergodox kit and the novelty kit? Or is the new "updated kits" list the only kits being offered. Would really suck to have waited over a year for this gb to even start only to have it stripped down to the basics.
Offline hoq
    • wolfmark.work
« Reply #315 on: Wed, 30 May 2018, 08:46:20 »
Updates! Yes, Ergodox and some other kits will come soon!
Offline sevenseacat
« Reply #316 on: Wed, 30 May 2018, 09:58:41 »
Dvorak and Colemak support! Yessssss! <3
Offline Kerasan
« Reply #317 on: Wed, 30 May 2018, 10:10:35 »
Nice updates...
KMK Labs.
Offline euphxenos
« Reply #318 on: Wed, 30 May 2018, 11:36:20 »
Could you add a 1U R3 Fn key to the non-standard kit?  That's used in the bottom row of some 65% layouts (Tada68, most Whitefox layouts).
Offline Tech22
« Reply #319 on: Wed, 30 May 2018, 14:07:16 »
I would love a set like this! Sign me up! I like the regular alphas better than the frozen, as my current white-ish color keycaps get really dirty in finger oils/residue and I think they look better.
Offline hoq
    • wolfmark.work
« Reply #320 on: Wed, 30 May 2018, 20:06:38 »
OK, I got it. I 'll add it .
Thank you!
Offline hoq
    • wolfmark.work
« Reply #321 on: Sun, 03 June 2018, 10:56:22 »
Offline Parva Ovis
« Reply #322 on: Sun, 03 June 2018, 12:47:19 »
Two R3 Enter keys in the Ortho kit is unnecessary for probably the majority of buyers.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #323 on: Sun, 03 June 2018, 15:00:16 »
And does anyone actually have a capslock key on a 40% board?
Offline hoq
    • wolfmark.work
« Reply #324 on: Mon, 04 June 2018, 00:03:02 »
Maybe I made a mistake of that R3 Enter key.
But honestly, I'm not very familiar with the recent 40% keyboards, if you have any advice, please let me know.
Offline Kerasan
« Reply #325 on: Mon, 04 June 2018, 07:29:02 »
hype!!!
KMK Labs
Offline dc_in_sf
  • Old Bastard
« Reply #326 on: Mon, 04 June 2018, 17:52:26 »
Always down for blue SA sets with 65% support  :thumb:
Just hope it can happen before the end of 2019!
Offline hoq
    • wolfmark.work
« Reply #327 on: Wed, 06 June 2018, 10:16:54 »
Ortholinear kit modified.
Offline hoq
    • wolfmark.work
« Reply #328 on: Wed, 06 June 2018, 10:19:17 »
Ergonomics
Offline hoq
    • wolfmark.work
« Reply #329 on: Wed, 06 June 2018, 10:20:20 »
Mecha Tools novelties
Offline hoq
    • wolfmark.work
« Reply #330 on: Wed, 06 June 2018, 10:21:18 »
Spacekeys
Offline hoq
    • wolfmark.work
« Reply #331 on: Wed, 06 June 2018, 10:25:22 »
Spacebars
Offline elfick
  • Can I get Colemak and a side of fries with that?
« Reply #332 on: Wed, 06 June 2018, 11:52:43 »
How about a 1.25u spacekey (unless there is a 1.25u blank somewhere that I missed). Also, any plans for a 1.25u R3 novelty?
Offline hoq
    • wolfmark.work
« Reply #333 on: Wed, 06 June 2018, 20:59:21 »
1.25u R3 novelties will come in Gears Novelties kit, please wait a moment.
but 1.25u spacekey is out my plan, Does any keyboard have a 1.25u blank spacekey?
Offline Lndefinite
« Reply #334 on: Wed, 06 June 2018, 22:22:31 »
I've seen some custom split spacebar layouts have a 1.25u in the middle... like this thing http://i.imgur.com/7EXes.png
Offline hoq
    • wolfmark.work
« Reply #335 on: Wed, 06 June 2018, 22:29:09 »
That key seems like a FN or layer change function key. Maybe you can use a 1.25u novelty to adapt it.
Offline Lndefinite
« Reply #336 on: Wed, 06 June 2018, 23:06:28 »
Oh yeah, you're right. Hmm, in that case the smallest actual space bar I've seen is 2u on ortho keebs or 40% keebs.
Offline elfick
« Reply #337 on: Thu, 07 June 2018, 10:21:03 »
Actually the smallest space "bar" is the 1u key on a grid planck. :)
In my case the 1.25u blank is actually my space key, but that's my custom layout so I don't expect it to be supported.
The 1.25u novelty would work just as well for my purposes.
Offline RobotRogue
  • No.
« Reply #338 on: Thu, 07 June 2018, 10:32:46 »
Really nice colorway, big fan of the large centered alpha legends
Offline clorex
« Reply #339 on: Thu, 07 June 2018, 17:47:25 »
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
KMK Labs.
Has support for the Ultimate Hacking Keyboard been added already? Would be nice to have a blank/novelty R1 1.5u key for the UHK's backspace, as the only compatible ones in terms of size and profile are the Ergodox's =+ or -_ keys, which would lead to an incorrect (and repeated) legend on the UHK.
Offline Parva Ovis
« Reply #340 on: Thu, 07 June 2018, 18:09:38 »
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
KMK Labs.
Make it two R1 1.5u keys and there will be support for Race 3 as well.
Offline hoq
    • wolfmark.work
« Reply #341 on: Fri, 08 June 2018, 00:34:09 »
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
KMK Labs.
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
KMK Labs.
Since I haven't got my UHK, I can't tell which special keys need to be added. Do you have a UHK layout map?
I'm cosidering  changing the Ergo kit with all blank keys, because every Ergo users always  their own key layout,  actual legends make no sence for them. 1.5u R1 blank keys are not a problem if the Ergo kit are all blanks.
Offline clorex
« Reply #342 on: Fri, 08 June 2018, 00:54:03 »
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
KMK Labs.
Hi erveyone,
Kits update:
1. Alphas
2. Frozen Alphas
3. TKL Adapter
KMK Labs.
Yup, there's this handy page on the official website:
https://ultimatehackingkeyboard.com/layout-and-keycaps
Offline hoq
    • wolfmark.work
« Reply #343 on: Fri, 08 June 2018, 01:56:39 »
OK, That helps a lot! Thanks!
Offline imdiedie
« Reply #344 on: Fri, 08 June 2018, 02:53:08 »
wow, uhk layout... had thought about buying SA Carbon kit to match it and it was like you need to buy some kit twice  ;D happy to heard it might support (though the price would be...)
Offline hoq
    • wolfmark.work
« Reply #345 on: Fri, 08 June 2018, 09:46:34 »
Finally, I modified the Ergonomics with blank keys.haha .
Offline hoq
    • wolfmark.work
« Reply #346 on: Fri, 08 June 2018, 09:47:19 »
Gear novelties
Offline hoq
    • wolfmark.work
« Reply #347 on: Fri, 08 June 2018, 09:48:43 »
ISO
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
« Reply #348 on: Sat, 09 June 2018, 07:56:35 »
looks nice! definitely will join in:)
Offline hoq
    • wolfmark.work
« Reply #349 on: Sat, 09 June 2018, 10:23:58 »
Thanks, I'll make all the drawings done soon, and  the group-buy will start sooner than we thought.  :p
