Author Topic: [IC] Brass Keycap  (Read 3465 times)
Offline Mr.Lunchbox
[IC] Brass Keycap
« on: Fri, 04 November 2016, 13:46:13 »
Hello everyone,
First off this is my first foray in to keycap design so lots of feedback is welcome.
Here's the cap
http://imgur.com/a/MZaYZ
Some info on the cap:
Material: Brass C260
Construction: CNC milled from a solid piece of brass.
Finish: Light Bead Blasting
Stem: MX
Weight: ~12g
The weight may be a little concerning. I would say MX Reds and Gateron Clears are definitely out and there could be slow return on some other switches. If this is a deal breaker I could re-assess the design and see where material could be removed.
As for the design itself, I've felt there have been a lot of "Apple-y" looking stuff (not just keyboards) with aluminum and rounded edges everywhere so I thought having virtually no visible rounded edges could be interesting and I've always like the look of brass and the fact that over time it would tarnish and take on a life of its own in a way.
I've contacted a few manufacturers and starting to get quotes. As this would be my first cap and buy I really want to make sure I have all my ducks in a row (and that there is interest) before moving forward. For this first go around I would limit the buy to 100 caps.
Let me know what you think!
« Last Edit: Fri, 04 November 2016, 13:50:18 by Mr.Lunchbox »
Re: [IC] Brass Keycap
« Reply #1 on: Fri, 04 November 2016, 13:47:35 »
If you need any tips these guys tried some brass caps back in the day
https://geekhack.org/index.php?topic=45974.0
Offline Mr.Lunchbox
« Reply #2 on: Fri, 04 November 2016, 16:45:43 »
Thanks for the info!
