Author Topic: [IC] Custom Engraved Brass Keycaps  (Read 39496 times)
« on: Fri, 19 July 2013, 11:04:32 »
PROTOTYPES IN : http://geekhack.org/index.php?topic=45974.msg970004#msg970004
Would anyone be interested in a simple, square shaped brass keycap with their own custom engraving on it? There's no profile to cut down on costs. Looks like this :
I have ordered a prototype which should be coming in a few weeks. I expect (note the word expect - i can't guarantee anything) these will cost around £15-25 each depending on numbers.
The engraving is COMPLETELY custom. You can put whatever you want on it. The only limitation is that, since these are being machined, internal corners will have to have a radius.
Thanks and let me know what you think.
« Last Edit: Tue, 23 July 2013, 11:14:41 by Photekq »
Re: [IC] Custom Brass Keycaps
« Reply #1 on: Fri, 19 July 2013, 11:11:07 »
You now I'll buy at least one just to have bro!!!...I think it should say sPaMrAy
Offline SidusNare
  • Do, or do not; there is no try.
« Reply #2 on: Fri, 19 July 2013, 11:13:43 »
Well, it seems we need to get down to brass tacks on this :-p
What are you going to do with the top, it looks totally flat, are you going to give it a cylindrical or spherical profile? I know it would be more, but I don't think totally flat would be very appealing.
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
« Reply #3 on: Fri, 19 July 2013, 11:15:50 »
Good to hear you're interested ray ;D
I didn't give it a profile to cut down on costs. You would be surprised how much more expensive a keycap with a profile is.
« Reply #4 on: Fri, 19 July 2013, 11:18:17 »
I'm in.  I want some seriously badass seal(emblem) style engraving
« Reply #5 on: Fri, 19 July 2013, 11:39:11 »
Seal emblem engraving? :confused:
Offline Tym
« Reply #6 on: Fri, 19 July 2013, 11:42:06 »
Seal Ingraving?
Offline esoomenona
  • Gnillort?
« Reply #7 on: Fri, 19 July 2013, 11:42:56 »
Can you engrave a moose on it?
Also, what height are they? Similar to top row? Would bottom row be possible (nice for some Fn keys)?
« Reply #8 on: Fri, 19 July 2013, 11:45:33 »
Seal emblem engraving? ???
Seal Ingraving?
Navy Seal maybe?
28710-0
« Reply #9 on: Fri, 19 July 2013, 12:22:50 »
They will be 1cm high, which is about the same height as f-row cherry profile keys. You could use them for bottom row, but since they have no profile they might not match too well. I think they would work best as an esc key or even as the three media keys that some boards have.
I can engrave a moose if you can provide a fairly simple vector. These can't be extremely complex due to the small canvas (18x18mm)
Seal Ingraving?
Navy Seal maybe?
That's what I was thinking initially.. I'm still confused :confused:
« Last Edit: Fri, 19 July 2013, 12:27:46 by Photekq »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #10 on: Fri, 19 July 2013, 14:54:30 »
I would be interested.
« Reply #11 on: Fri, 19 July 2013, 15:18:02 »
Here's an example of what could be done
Offline Kempher
« Reply #12 on: Tue, 23 July 2013, 01:12:49 »
Not a bad concept, any idea which row these will fit, or when you say no profile, are you going to keep it completely flat?
SQ-1800 /w Gateron Blacks
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #13 on: Tue, 23 July 2013, 10:59:36 »
Offline codyeatworld
« Reply #14 on: Tue, 23 July 2013, 11:01:57 »
I would want a couple with engraving!
« Reply #15 on: Tue, 23 July 2013, 11:07:19 »
They are square-shaped. Completely flat.
I have my prototypes here now. They're absolutely beautiful and my machinist has done a great job of the engraving. They're also bulky as hell (weight 25g each) and have an amazing feel to them. I need to smooth some things out with them before I even think about selling any though.
They're hard to photograph since they're so shiny.. but this should give a good idea of how it looks. I'm afraid I don't have an MX board to put it on atm.
« Last Edit: Tue, 23 July 2013, 11:09:00 by Photekq »
Offline calavera
Re: [IC] Custom Engraved Brass Keycaps
« Reply #16 on: Tue, 23 July 2013, 11:15:11 »
Curious as to how these would look on a board though, like does the height match with row1 (function row)?
« Reply #17 on: Tue, 23 July 2013, 11:16:11 »
These are 1cm high, very close to the height of Cherry profile R1 caps. I'm curious too. I think they'd be most suited to esc, or as media keys.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #18 on: Tue, 23 July 2013, 11:17:52 »
Looks real nice. If only it were spherical.
Offline Kempher
« Reply #19 on: Tue, 23 July 2013, 13:01:13 »
It really does look fantastic. Very heavy though, you'll need a heavier spring under that bad boy to compensate. I wonder if anyone would fill an entire keyboard with these lol.
« Reply #20 on: Tue, 23 July 2013, 13:04:26 »
I don't think you'd want to put it on a key you use frequently :)) At least it isn't 50g.. then you wouldn't even be able to use it on lighter switches. Thanks for the compliment :)
Offline MOZ
  • Busy making stuff
« Reply #21 on: Tue, 23 July 2013, 20:59:25 »
Good thing, I am getting 80g springs :D
Offline Lu_e
« Reply #22 on: Wed, 24 July 2013, 13:00:39 »
Lead-free?
Just say NO to ABS keycaps
Offline neoezekiel
    • My GW2 Guild - The Fallen Souls [SouL]
« Reply #23 on: Wed, 24 July 2013, 13:09:45 »
Lead-free?
Since when did Brass contain Lead?
Also I am in for a few of these once you start selling :)
« Last Edit: Wed, 24 July 2013, 13:31:35 by neoezekiel »
WTB: Cherry G80-2550, GnCC/CCnG sets, led mx greens, mx dark greys, Plate Design Service, Case Design Service
Offline Lu_e
« Reply #24 on: Thu, 25 July 2013, 15:01:42 »
Lead-free?
https://en.wikipedia.org/wiki/Brass#Lead_content
« Reply #25 on: Thu, 25 July 2013, 15:07:55 »
I will ask my machinist about the lead content. Is it very important to you?
« Reply #26 on: Thu, 25 July 2013, 15:42:03 »
The brass is a grade that contains small amounts of lead. It allows it to be machined easier.
Offline Tym
« Reply #27 on: Thu, 25 July 2013, 15:47:37 »
I'm pretty sure its fine unless you decide to ingest the key or put it in your water supply.
« Reply #28 on: Thu, 25 July 2013, 15:54:12 »
Yeah. It's totally fine. Even an entirely lead keycap would be fine.. It's not going to poison anyone :))
« Reply #29 on: Thu, 25 July 2013, 15:55:26 »
But be sure if you send any to California it's labeled as containing a toxic substance. ;)
Offline neoezekiel
« Reply #30 on: Mon, 29 July 2013, 13:17:45 »
Offline MOZ
  • Busy making stuff
« Reply #31 on: Wed, 07 August 2013, 20:17:56 »
Photekq, would it be at all possible to share the CAD files for these, I would like to see if the local machinist can make these, I might get him to try on other materials as well, such as SS, Alu.
« Reply #32 on: Fri, 09 August 2013, 15:27:08 »
Offline fydo
  • Meow!
« Reply #33 on: Fri, 09 August 2013, 15:39:49 »
I'd be interested depending on price. :)
Looks pretty cool. How is the fit on the Cherry MX stem? I have heard that metal keycaps will sometimes fit very tightly.
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
« Reply #34 on: Fri, 09 August 2013, 20:14:22 »
No, not at the moment. I'm still playing with the design and waiting to hear back from testers. Maybe at a later date, but at the moment I still have many things to change.
Soon. Soon :)
The original prototypes (with TEK logo) were very tight. The V2s I had made for Bunny and HoffmanMyster fit very, very well.
Offline MKULTRA
  • telling it how it is
« Reply #35 on: Fri, 09 August 2013, 20:54:58 »
I'd be in.
You should look into blockers...
« Reply #36 on: Fri, 09 August 2013, 20:56:13 »
I'd be in.
Different cases have different heights for their bezels.. It's hard to make it look nice.
« Reply #37 on: Sat, 10 August 2013, 00:23:04 »
Okay everybody.  If this doesn't get you excited for these I don't know what will!  Welcome to the dark side.
In case it isn't clear, the logo on this is raised, rather than being engraved and cut into the cap.  I really like the look.
Please enjoy the photos below and an album with 11 additional photos here.
DSC01862 by HoffmanMyster, on Flickr
DSC01924 by HoffmanMyster, on Flickr
DSC01903 by HoffmanMyster, on Flickr
Different lighting
DSC01917 by HoffmanMyster, on Flickr
DSC01920 by HoffmanMyster, on Flickr
For reference, here is the image I sent:
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #38 on: Sat, 10 August 2013, 00:32:01 »
I would be interested in one with a Darth Vader etching? That would look so badass..
« Last Edit: Sun, 08 September 2013, 14:01:32 by kenmai9 »
Offline MOZ
  • Busy making stuff
« Reply #39 on: Sat, 10 August 2013, 03:03:54 »
Different lighting
I fell in love when I saw that, the design is perfect for the keycap, reminds you of old navy seals, or pirates, ships, colonial days.
« Last Edit: Sat, 10 August 2013, 03:06:29 by mohitgarg »
Offline MOZ
  • Busy making stuff
« Reply #40 on: Sat, 10 August 2013, 03:04:47 »
--- Double Post ---
Offline MOZ
  • Busy making stuff
« Reply #41 on: Sat, 10 August 2013, 04:00:39 »
If I can, I would get this:
Else:
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #42 on: Sat, 10 August 2013, 07:30:51 »
oOOHH, GoT House Sigils.
I love it, but I'd also like to see a quote on a key with... any profile. Spherical might be cool with a brass keycap. But I just want some profile, at all.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
« Reply #43 on: Sat, 10 August 2013, 07:37:25 »
Soon. Soon :)
Just dont' forget about me bro!! ;)
Offline fydo
  • Meow!
« Reply #44 on: Thu, 29 August 2013, 23:06:24 »
Any word on this? :D
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #45 on: Fri, 30 August 2013, 00:03:06 »
That prototype looks kick ass photeq.
Having a bad day?
« Reply #46 on: Fri, 30 August 2013, 02:32:27 »
Next revision coming soon :)
Thanks man :D
« Reply #47 on: Fri, 30 August 2013, 07:38:25 »
Offline LechnerDE
« Reply #48 on: Fri, 30 August 2013, 08:00:09 »
Can I get one with a Darth Vader etching? That would look so badass..
+1
I wouldn't mind a storm trooper either :D
Offline MOZ
  • Busy making stuff
« Reply #49 on: Fri, 30 August 2013, 13:13:35 »
Waiting.
