Author Topic: Weird sound with new spacebar keycap - do I need to lube?  (Read 8350 times)
Offline trenzterra
« on: Fri, 04 November 2016, 19:23:03 »
Hi all, I have a Ducky Shine 5 keyboard and I went to buy a set of Tai-hao ABS keycaps for it. The keys are fine, just that the spacebar sounds really weird.... There is this hollow, metallic pinging sound when I press down on it. It doesn't seem to affect any of the other keys.
From what I've read it seems that I need to lube the Cherry stabiliser. However, my issue is that this weird sound doesn't occur with my standard Ducky spacebar or the YOTG spacebar... so I was wondering if the Taihao is the issue and how I can resolve it when the problem lies with the key and not the stabiliser (besides changing to another keycap set).
I am using the doubleshot ABS if that helps. I have checked for warping and any warping is minimal, if at all.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Weird sound with new spacebar keycap - do I need to lube?
« Reply #1 on: Fri, 04 November 2016, 19:48:49 »
Could be a combination of the keycaps and unlubed stabilizer wire. Maybe you can pop a paintbrush in there and see what happens? I could definitely see myself unsoldering an entire keyboard just to lube the spacebar's stabilizers but I'm mildly insane--so there's that.
Here's a bit of Geekhack info regarding the Ducky Shine 5 Stabilizers
« Reply #2 on: Fri, 04 November 2016, 19:57:57 »
Most likely it's the taihao cap.
It's possible it is rubbing or hitting something differently than the stock caps.
I've never had to lubed any stock cherry stabilizers for this particular issue.
I have a ducky that's picky with spacebars, I think the plate is just fractionally off and the stabilizers are a little tight then when you have caps that are also slightly out of spec you have issues.
« Last Edit: Fri, 04 November 2016, 20:07:54 by SpAmRaY »
Offline trenzterra
« Reply #3 on: Sat, 05 November 2016, 07:55:52 »
Turns out -- the keycap was probably too thin.
I shoved a piece of paper in the cap, punched a few holes and the feeling of the spacebar is far, far better. Previously it would rattle if I were to wiggle the keycap a little. Now it feels sturdy!
Still, I think I will invest in better quality PBT caps for the long haul.
Offline E3E
« Reply #4 on: Sat, 05 November 2016, 08:28:39 »
My Jukebox SA space bar sounded hollow on my Octagon v1, the first custom I ever built (and thus didn't have much experience with beforehand), and I used 70 duro O-rings and it fixed that hollow sound right up. Since 70 duro is rather firm, it didn't substantially change the feel either.
Offline bexleycorona
« Reply #5 on: Sat, 05 November 2016, 12:55:50 »
I'm having a similar problem but probably for different reason.
I switched out the stock keycaps on my Rosewill 9000 board for PBT Ducky keys that I really liked. The spacebar has some play in it and rattles a bit. I suspect it's because the keys are shorter creating more travel. I mean the keys feel thicker than the stock ones and look thicker.
GE Marquette | Rosewill RK-9000 | Rosewill Apollo 9100 | Realforce 87U "EK Edition" 45g Uniform | Unicomp Ultra Classic Black Buckling Spring | Realforce 87U SE07T0 Variable | Dolch PAC65
Offline jcoffin1981
« Reply #6 on: Sun, 06 November 2016, 19:53:50 »
You can purchase a single space bar to replace this funky one for probably 6-10 dollars.  You can also try flipping the bar around and maybe it won't vibrate/ping so much.  But it seems you found a solution that you are happy with.
