Author Topic: Problem with Satan GH60 and the QMK firmware flasher  (Read 6904 times)
Offline Ozymandias99
  • Uhhh I don't know what to put here so Hello There!
« on: Mon, 07 November 2016, 11:36:37 »
So I have a Satan GH60 board. I have been able to flash it using the TKG flasher (https://github.com/kairyu/tkg-toolkit) just fine, only to realise the under lighting LEDs used aren't compatible with it. I contacted the guy that made the board and he said to use the QMK firmware flasher (https://geekhack.org/index.php?topic=82505.0) and he whipped up a .hex file for me. I can load the program just fine, and I can select the .hex file fine. Once I've done that, it tells me to 'Press RESET on my keyboards PCB'. So I press it... and nothing happens. It still says to press it and the 'Flash keyboard' button is still red, meaning I can't hit it. It's worth noting I'm on Windows 10, and I've tried the program on several other machines (all Windows 10). I have no idea what could be the problem.
If any of you have any idea, please ELI5, because I'm still new to all this.
Any help is appreciated.
Offline Tactile
Re: Problem with Satan GH60 and the QMK firmware flasher
« Reply #1 on: Mon, 07 November 2016, 15:44:15 »
It sounds like a driver problem. The driver for the controller chip is not installed. A regular GH60 has an ATmega32U4 but I don't know what chip is used in that keyboard.
REΛLFORCE
« Reply #2 on: Mon, 07 November 2016, 16:23:05 »
Do you know how I can download the controller chip driver?
Offline Tactile
« Reply #3 on: Mon, 07 November 2016, 16:43:07 »
Well, as I said, I don't know what controller chip is used on that PCB. If, as you said, you can contact the person who made the board they should be able to tell you. Or someone else here might chime in. I don't know anything about the Satan GH60.
Here it is in a nutshell...
Windows sees your keyboard plugged in, along with your mouse, etc
You press the reset button and the keyboard controller performs a switch - it used to identify as a keyboard & now it identifies as a controller chip
Windows sees the keyboard disappear and a new device appears. This new device is the controller chip. Windows sees the controller chip but, without a driver, doesn't know how to communicate with it.
REΛLFORCE
« Reply #4 on: Mon, 07 November 2016, 17:52:56 »
Device manager called it 'ATm32U4DFU', so I guess that's the chip.
It says all the drivers are up to date. Any ideas?
Offline Tactile
« Reply #5 on: Mon, 07 November 2016, 18:07:57 »
I'm not running Windows here. I don't know if this site is trustworthy.
http://www.driverscape.com/download/atm32u4dfu
REΛLFORCE
« Reply #6 on: Mon, 07 November 2016, 18:23:48 »
I downloaded the driver. What do I do with it? How can I apply it?
This is what the folder looks like: http://i.imgur.com/7AcMmwr.jpg
Sorry for sounding like a retard. Again, I'm new to all this and just want my LEDs to work :(
Offline Tactile
« Reply #7 on: Mon, 07 November 2016, 18:29:55 »
This is risky because, as I said, I'm not running Windows here...
Open Device Manager & find the controller chip
Right click & tell Windows you want to install a new driver (or something like that)
Tell Windows not to install automatically (or something like that)
Click on something to let you navigate to that folder & tell Windows to find the driver there
... or something like that
« Last Edit: Mon, 07 November 2016, 18:32:36 by Tactile »
REΛLFORCE
Offline Tactile
« Reply #8 on: Tue, 08 November 2016, 16:19:46 »
ahhh... The silence of a satisfied customer.
REΛLFORCE
« Reply #9 on: Tue, 08 November 2016, 16:29:51 »
Hahaha! Sorry for not replying, been caught up in schoolwork.
Thanks so much for your help! I really appreciate it.
