Author Topic: WYSE Keycaps  (Read 8291 times)
Offline ntw
WYSE Keycaps
« on: Mon, 14 November 2016, 10:02:14 »
Dug these old WYSE keycaps out of the store room and put it on a B.Mini
Offline kinglukas38
  • Do you even tactile?
Re: WYSE Keycaps
« Reply #1 on: Mon, 14 November 2016, 10:13:21 »
nice pics ntw, wyse are probably my favorite old school caps
I've never done it before, but I'm pretty sure I'm good at it
Offline ntw
Re: WYSE Keycaps
« Reply #2 on: Mon, 14 November 2016, 11:18:13 »
any idea where to get the modifiers and spacebars? its tickling my ocd senses :mad:
Offline kinglukas38
Re: WYSE Keycaps
« Reply #3 on: Mon, 14 November 2016, 11:25:59 »
Og mods are a no go for this set unfortunately
Well bottom row anyway
Offline gnmar2723
Re: WYSE Keycaps
« Reply #4 on: Mon, 14 November 2016, 18:53:09 »
WYSE double shots are so good looking! I wish someone would do a GB with the exact retro color scheme so I could get a set that doesn't look brown  :p
Offline kinglukas38
Re: WYSE Keycaps
« Reply #5 on: Mon, 14 November 2016, 19:19:41 »
https://geekhack.org/index.php?topic=84001.msg2238717#msg2238717
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: WYSE Keycaps
« Reply #6 on: Tue, 15 November 2016, 06:20:19 »
It looks great  :thumb:  I especially like it with the purple mods!
Offline Jokrik
Re: WYSE Keycaps
« Reply #7 on: Tue, 15 November 2016, 06:27:38 »
oh wow, never thought it's that good
<3
Offline Neo.X
Re: WYSE Keycaps
« Reply #8 on: Fri, 25 November 2016, 14:41:22 »
The thick WYSE keycaps are really good, very enjoy typing on them.
All those keyboards will be lost in time....
Offline alienman82
Re: WYSE Keycaps
« Reply #9 on: Sat, 26 November 2016, 13:25:02 »
removed.
« Last Edit: Thu, 01 March 2018, 13:34:24 by alienman82 »
Offline gnmar2723
Re: WYSE Keycaps
« Reply #10 on: Sat, 26 November 2016, 15:52:41 »
thick?  From which board??
I don't think they are specific to any WYSE board but my WY-30 had some and they are glorious. I just wish they weren't so yellowed though
Pics
Offline Neo.X
Re: WYSE Keycaps
« Reply #11 on: Sat, 26 November 2016, 17:51:18 »
Pics
These are exactly what I have. Thick and yellow, but very nicely typing on. It's actually make my liner switch quieter.
Offline ntw
Re: WYSE Keycaps
« Reply #12 on: Tue, 29 November 2016, 11:53:42 »
those WYSE are so thick. have you tried retrobrite?
Offline gnmar2723
Re: WYSE Keycaps
« Reply #13 on: Tue, 29 November 2016, 12:18:44 »
Yeah I tried it on some of my thin WYSE double shots and it ended up leaving some white stains so I am a bit weary to try with these thicker double shots in fear that the same thing might happen. I'm not sure if the thing I used caused it or if I left the keycaps in the sub too long.
Offline alienman82
Re: WYSE Keycaps
« Reply #14 on: Tue, 29 November 2016, 12:21:05 »
I had a baggie with like 4000 wyse caps in it, but all thin and all **** layout.  they're in a local landfill now  :rolleyes:
Offline ntw
Re: WYSE Keycaps
« Reply #15 on: Tue, 29 November 2016, 12:49:47 »
well at least you have like 4000 smooth mx black switches :thumb:
Offline alienman82
Re: WYSE Keycaps
« Reply #16 on: Tue, 29 November 2016, 13:21:51 »
removed.
« Last Edit: Thu, 01 March 2018, 13:32:36 by alienman82 »
Offline gnmar2723
Re: WYSE Keycaps
« Reply #17 on: Tue, 29 November 2016, 14:01:26 »
ehh long story more like 500...  rust :D
Yeah blacks from WYSE boards are really hit or miss
Offline alienman82
Re: WYSE Keycaps
« Reply #18 on: Tue, 29 November 2016, 15:30:29 »
removed.
« Last Edit: Thu, 01 March 2018, 13:32:32 by alienman82 »
Offline gnmar2723
Re: WYSE Keycaps
« Reply #19 on: Tue, 29 November 2016, 16:20:14 »
yeah I would really just get the NIB ones if you're after the switches.  That or get an old G80 and don't fuzz about the logos since it makes no difference.
I picked up one of these to convert but I'm thinking about getting some more for the switches. I really should be saving so I can pay for my viper though. When will the spending end?!  :))
