Author Topic: [GB] Duck Viper/Eagle V2 Kustom Group Buy [Closed] - 2nd Batch Shipped  (Read 419109 times)
Offline poolside
Re: [GB] Duck Viper/Eagle V2 Kustom Group Buy [Closed] - 1st Batch Shipped
« Reply #700 on: Thu, 30 March 2017, 17:11:18 »
This is for a single front diffuser that matches the stock ones that came with the board with added Zeal compatibility.
Should the Cherry screw-in stabs from the current Originative GB be expected to interfere with the stock Duck front diffuser?
Offline aaron6301
  • Pixel Pusher
« Reply #701 on: Fri, 31 March 2017, 09:46:46 »
Does anyone have access or a copy to the .eps or .svg file that was used to create the Poly/Alum/SS plates? If so, please shoot me a pm!
Edit: Made my own. I plan on having a stainless steel plate fabricated next week  :thumb:
« Last Edit: Fri, 31 March 2017, 23:21:29 by aaron6301 »
Offline swimmingbird
  • keyset hoarder
« Reply #702 on: Sun, 02 April 2017, 02:18:12 »
Just built my second Viper using 67g Zealios and a plastic plate - feels so good
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« Reply #703 on: Sun, 02 April 2017, 02:39:38 »
anychance making one with brass?
  • keyset hoarder
« Reply #704 on: Sun, 02 April 2017, 04:48:24 »
Discovered one of my PCBs came with a missing diode - luckily I had some on hand to fix it up
Offline dubious
  • 쏘쿨
« Reply #705 on: Sun, 02 April 2017, 23:00:50 »
Can you write a small comparison of acrylic vs ss/alu with a tactile switch like zealios?
If you can, thanks!  :thumb:
  • keyset hoarder
« Reply #706 on: Sun, 02 April 2017, 23:04:01 »
I'll write one up when I get home but so far I have found that on 67g Zealios the plastic plate feels much nicer than the Alu plate. I still have another one to build with the SS plate so I'll get around to writing that one up at some point
Offline dubious
  • 쏘쿨
« Reply #707 on: Sun, 02 April 2017, 23:09:31 »
wicked
Offline profanum429
« Reply #708 on: Sun, 02 April 2017, 23:24:58 »
Long shot I know but if anyone has a Viper from this GB they'd like to part with I'd love to try to make a deal :)
Offline Jumie
« Reply #709 on: Mon, 03 April 2017, 00:55:03 »
Finished the build yesterday.. potato pic below..164704-0
Offline ctzn_voyager
« Reply #710 on: Mon, 03 April 2017, 07:30:30 »
Finished the build yesterday.. potato pic below.. (Attachment Link)
Wow, turned out beautifully.
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
« Reply #711 on: Mon, 03 April 2017, 09:46:52 »
Nice build! What switches are you using?
Offline Jumie
« Reply #712 on: Mon, 03 April 2017, 11:28:02 »
vintage black 65g
Offline elton5354
« Reply #713 on: Mon, 03 April 2017, 15:13:57 »
No updates from my end. Will let you know as soon as I hear from Duck.
Offline dubious
  • 쏘쿨
« Reply #714 on: Mon, 03 April 2017, 15:18:02 »
thanks for the update elton!
Offline anthorix
  • Finally Awake
« Reply #715 on: Mon, 03 April 2017, 15:43:40 »
It's been so long...  :(
It'll finally arrive...  :cool:
Offline mindxthinker
« Reply #716 on: Tue, 04 April 2017, 00:16:43 »
Any news on 2nd batch shipping?
« Reply #717 on: Tue, 04 April 2017, 00:40:19 »
scroll up a bit
Offline BlackInk
    • TeamGSB
« Reply #718 on: Thu, 06 April 2017, 18:30:47 »
Do hou guya know where to get a brass plate for duck eagle/viper? Thanks
Offline gaiden
« Reply #719 on: Thu, 06 April 2017, 19:22:54 »
Merlin64 will run it. It hasn't started yet.
Sent from my SM-G935F using Tapatalk
Offline johnthedong
« Reply #720 on: Thu, 06 April 2017, 19:39:49 »
PS: Still looking for a Viper kit for a friend who saw my V1. Can offer the usual high market rates or even trades - ping me if you have an upcoming kit and are planning to sell.  ;D(https://geekhack.org/index.php?topic=88549.0)
Offline BlackInk
    • TeamGSB
« Reply #721 on: Thu, 06 April 2017, 19:54:43 »
I know he will be running brass inserts, not sure about plate tho?
Offline gaiden
« Reply #722 on: Thu, 06 April 2017, 20:16:16 »
Oops I misread.
Offline aaron6301
  • Pixel Pusher
« Reply #723 on: Thu, 06 April 2017, 21:06:57 »
Pretty sure you'll have to make/source a brass plate yourself
Offline merlin64
    • MechMerlin
« Reply #724 on: Fri, 07 April 2017, 13:03:36 »
I am talking with someone about the plate, waiting on his feedback with the prototype.
In terms of the weight, I am waiting for an email from Duck. Meanwhile my Orion/BB weight GB is still ongoing so I am unable to go through with any new GB yet.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #725 on: Fri, 07 April 2017, 13:09:41 »
Count me in for plate and weight man if they both go ahead as planned.
Offline BlackInk
    • TeamGSB
« Reply #726 on: Fri, 07 April 2017, 14:08:13 »
Glad to hear from you, count me in if you plan to run brass Plate + Weight insert
Thanks Merlin
Offline Shados
« Reply #727 on: Sat, 08 April 2017, 10:57:42 »
Finally got around to building my silver Eagle today.
Chucked some newly-arrived XDA Milestone kits + Granite mods on, a combination that turned out better than I was expecting. Still need to do keyswitch LEDs, but not sure on the colour I want yet... additionally, this board is likely to end up with GMK caps, so I need to source 1.8mm LEDs. Anyone know an inexpensive supplier with a decent range of colours?
Now to flash it with a sane keymap...
Offline johnthedong
« Reply #728 on: Sat, 08 April 2017, 20:30:45 »
Sounds great - am interested in this too should it come to fruition. I'm assuming that the weights will fit in the internal cutout on the bottom plate, right?
Offline zoomwalt
« Reply #729 on: Sat, 08 April 2017, 20:41:26 »
Sorry if this was asked somewhere else: is the PCB compatible with the eagle v1?
Offline loud_asian
« Reply #730 on: Sat, 08 April 2017, 20:58:26 »
no, usb port is in a different location
Offline johnthedong
« Reply #731 on: Sat, 08 April 2017, 21:11:31 »
Yep - it's at the center now. I've yet to see other PCB's compatible with the viper/eagle series due to their different mounting holes etc, so be careful if you're soldering stuff to it!
Offline BlackInk
    • TeamGSB
« Reply #732 on: Sat, 08 April 2017, 21:42:13 »
Any update on second patch? :(
Offline johnthedong
« Reply #733 on: Sun, 09 April 2017, 00:33:41 »
Anyone used switch holtites/planning to use switch holtites with them?
Offline Shados
« Reply #734 on: Sun, 09 April 2017, 19:13:53 »
I used both LED and switch holtites on my build (and also on my Blackbird). They work pretty well, just make sure you use a soldering iron (without solder) to push them in for a second or two. The heat and pressure help fix them in place and prevent them from coming out when you're removing switches... although that's not a huge issue either way.
Offline elton5354
« Reply #735 on: Sun, 09 April 2017, 19:51:31 »
Sorry guys, no updates yet.
Offline johnthedong
« Reply #736 on: Sun, 09 April 2017, 21:03:07 »
Sounds good - that should be something I need to do! Thanks!
Offline johnthedong
« Reply #737 on: Sun, 09 April 2017, 23:52:41 »
Last question - does the switches wobble when you type on them with the holtites on? I imagine it would be fine seeing that there's the plate on top, but I might be mistaken. Thanks again!!
Offline BlackInk
    • TeamGSB
« Reply #738 on: Sun, 09 April 2017, 23:59:44 »
What kind of holtites did you use? and where to get it? (US)
Thanks man
Offline johnthedong
« Reply #739 on: Mon, 10 April 2017, 00:19:53 »
Thanks man
PS: Pretty sure they're the ones here: 8134-HC-8P3 or 8134-HC-8P2 for switches and 8134-HC-5P2 for LED's. I personally got mine at https://www.mouser.com, for a total of approx ~ $80 (150x each) with shipping.
Offline Shados
« Reply #740 on: Mon, 10 April 2017, 00:33:13 »
There's no wobble. They're pretty hard to get out again, actually -- you really need a pair of tweezers that curve in toward each other to remove the switches easily once they're in. Honestly, I think if you're using PCB-mount switches you could go plateless and they still wouldn't wobble. The holtites do indeed 'hold tight'.
Thanks man
johnthedong is right about the part numbers for the holtites. Specifically, I used 8134-HC-8P2 for switches and 8134-HC-5P2 for LEDs, both of which are the gold variants. The tin ones are much cheaper but I wanted completely invisible bling, for some reason.
As for where I bought them, I got mine from onlinecomponents.com, but there are many electronics suppliers that sell them. As electronics suppliers give you price-breaks on unit pricing as you purchase more units at once, in order to figure out where to buy them you'll want to do something like:
  • Decide roughly how many you want / can afford right now
  • Google up a bunch of suppliers for them
  • Figure out who is cheapest based on the amount you want and cost of shipping to you
And remember, you need 2 per switch.
Offline johnthedong
« Reply #741 on: Mon, 10 April 2017, 00:47:06 »
Thanks man
2 LED holtites and 2 switch holtites per switch - I accidentally ordered a few less due to this for another project before. I've found that mouser gives the cheapest quote if you're looking for smaller amounts too, and their shipping is usually really reasonable and fast. It's great to hear that they work pretty well - I'm assuming that the Duck Viper V2 board doesn't have any close holes (that might break if you insert them incorrectly) and such, right? Can't wait to get started on my kit!
Offline BlackInk
    • TeamGSB
« Reply #742 on: Mon, 10 April 2017, 01:59:20 »
Thanks man
Thanks guys, will it still work well without soldering iron, i actually dont have one thats why im planning to use holtites
Offline onmybikedrunk
    • Danny Woods - Industrial Designer
« Reply #743 on: Mon, 10 April 2017, 02:06:13 »
Diffuser Update:
So I got the plastic in!  We're almost ready to ship.  I'm going into the shop tomorrow to have the pieces cut while I wait!
Offline johnthedong
« Reply #744 on: Mon, 10 April 2017, 02:11:35 »
Thanks man
I am actually not sure - pretty sure that heat from the soldering iron would help with the seating of the holtites though but I've seen videos where people have inserted them without the soldering iron.
« Last Edit: Mon, 10 April 2017, 02:14:45 by johnthedong »
Offline johnthedong
« Reply #745 on: Mon, 10 April 2017, 02:13:07 »
Diffuser Update:
Damnn any spares available? Pretty sure(or not?) I filled in the gdoc form a few weeks ago, but I've not gotten any communication since. Thanks!
PS: I've refilled the form again, sorry for the trouble if I've already filled in once before.
« Last Edit: Mon, 10 April 2017, 02:18:29 by johnthedong »
« Reply #746 on: Mon, 10 April 2017, 04:46:20 »
Sorry for any confusion, we haven't invoiced yet... It will happen this week. Since it's going to be under $10 shipped (US) I figured there is no reason to have this long drawn out pay-period.  If anyone can't afford to pay this week just PM me and we'll work it out -- no worries!  On top of that, I'm sure we will have a few extra.  If you're not sure if you filled out the form just do it again and  leave a note of how many you actually want.
Offline johnthedong
« Reply #747 on: Mon, 10 April 2017, 10:36:55 »
Thank you again for everything! That sounds great!
Offline elton5354
« Reply #748 on: Mon, 10 April 2017, 11:54:07 »
Just heard from Duck that the 2nd batch will be delayed for a couple more weeks.
Offline zacheadams
« Reply #749 on: Mon, 10 April 2017, 11:59:27 »
