Author Topic: [GB] Duck Viper/Eagle V2 Kustom Group Buy [Closed] - 2nd Batch Shipped  (Read 419004 times)
Offline moitorpsychoo
Re: [GB] Duck Viper/Eagle V2 Kustom Group Buy [Closed] - 2nd Batch Shipped
« Reply #1250 on: Thu, 24 May 2018, 22:13:49 »
https://imgur.com/a/To3YgWz
I fixed my blackbird's underglow and recorded it there, maybe it'll give you some insight. I'd usually try to put more some brainpower into helping you out, but I'm swamped with work right now.
Note that I did fix it incorrectly, because I wired the data lines wrong and will correct that soon. The LEDs are WS2812Bs.
Now I’m thinking maybe I should get some new LEDs to test...thanks for the detailed repair walkthrough!!
Offline p_blaze
« Reply #1251 on: Thu, 24 May 2018, 22:38:00 »
If they all flash when plugged in I wouldn't imagine they're broken. Sounds to me like they are turned off in memory, change the LED mode and make sure brightness is on full.
In the programming software(can't remember the name of it) open the led menu and reset it to default, save and flash.
You mean O2D right? I did what you said, and still no underglow. I went ahead for more testing: I used a 3mm LED to touch the contact point of each underglow LED, and it lit up(as shown in the pic). Now I’m suspecting this is not a problem on software level....but let me know if this isn’t the right way to test.
I recommend pulling out a multimeter, taking a look at the ws2812b data sheet, and just checking voltages between connected pins. The first LED might be borked, or you might have an issue with the microcontroller or its pins. Also check the USB port and see if there is cracked solder there. If you can't find an issue, maybe look into reflowing the microcontroller and the usb pins if you can do it safely. I'm sure that someone else will ahve better advice than me, but these are the guesses I can make from fixing my own board with basically the same architecture.
Offline aya3154
« Reply #1252 on: Wed, 30 May 2018, 09:53:27 »
Wish I got into KBs a year back.. but looking forward is there any projection for when the Raven might be happening here?
« Reply #1253 on: Wed, 30 May 2018, 11:19:28 »
no
Offline aya3154
« Reply #1254 on: Wed, 30 May 2018, 12:07:42 »
no
:-X
gonna keep an eye out for it then :eek:
« Last Edit: Wed, 30 May 2018, 12:09:30 by aya3154 »
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
« Reply #1255 on: Tue, 05 June 2018, 18:01:55 »
Hello all... IC is up for the weights:
https://geekhack.org/index.php?topic=95953.0
Offline mdlt97
  • This **** is still better than Keebtalk
« Reply #1256 on: Thu, 07 June 2018, 10:28:44 »
regret not getting a eagle
TX60 | Duck TC-V3 | Duck Eagle V2 1/1 Bottom | Zephyr r2 | Duck Sidewinder | Mech27v2 | TX75 | LZ CLS | Duck Viper v2 | Orion v3 | HHKB pro 1 | TGR 910 | Omega60
« Reply #1257 on: Thu, 07 June 2018, 12:53:41 »
Hoping for the next round!
Offline Etherealsound
« Reply #1258 on: Fri, 10 August 2018, 09:19:01 »
Has there been any indication of a viper/eagle v3? Maybe it will be run with the Raven?
« Reply #1259 on: Sun, 12 August 2018, 11:20:42 »
No
Offline anthorix
  • Finally Awake
« Reply #1260 on: Thu, 16 August 2018, 18:27:55 »
« Reply #1261 on: Thu, 16 August 2018, 19:27:47 »
orange films are a nice touch
Offline Vadurr
  • Valar Morghulis
« Reply #1263 on: Thu, 25 July 2019, 17:11:19 »
Does anyone happen to know where I could buy the foam/rubber feet for the V2?
Offline vaughno
« Reply #1264 on: Wed, 02 October 2019, 17:15:49 »
Any indication of an eagle v3 or another run for the eagle?
Unikorn | Orion v3 | GSKT-00
« Reply #1265 on: Wed, 02 October 2019, 18:20:18 »
so, duck has said he doesn't want to do it again, but he's running v3s in the same sequence that he ran v2s, so wait and see what happens after octagon v3
i have heard nothing confirming or denying
Offline vaughno
« Reply #1266 on: Wed, 02 October 2019, 18:21:41 »
Thank you
« Reply #1267 on: Wed, 02 October 2019, 21:02:43 »
Duck viper v3 pleaaaase
Offline Visionaire
« Last Edit: Wed, 04 December 2019, 08:43:04 by Visionaire »
Offline vaughno
« Reply #1269 on: Wed, 04 December 2019, 08:42:33 »
Offline jtrussell
« Reply #1270 on: Wed, 04 December 2019, 18:15:57 »
Can't wait for the Viper V3 to be live!!  :p
« Reply #1271 on: Tue, 14 January 2020, 01:04:13 »
Does anyone know when the v3 will be live? Sorry, I'm new to the community.
Offline Seoulcialite
    • MechSeoul
« Reply #1272 on: Tue, 14 January 2020, 12:07:16 »
Domestic (Korea) GB for Viper/Eagle v3 happened last month. If the time span between domestic GB and Geekhack GB for the last Octagon is any indication, an international GB may be in February or March.
Offline ranker
    • keyboard porn
« Reply #1273 on: Thu, 16 January 2020, 04:35:04 »
Is 3 happening?
Offline Nigolski
« Reply #1274 on: Thu, 16 January 2020, 11:37:53 »
Offline i_tekneek
« Reply #1275 on: Thu, 05 March 2020, 19:46:00 »
Is there any RGB presets pre installed on the v2 PCBs? What I mean is can you change the RGB lighting with any keys from the default config? Or do you need to use O2D or QMK to be able to change the RGB.
Offline merlin64
    • MechMerlin
« Reply #1276 on: Sun, 08 March 2020, 20:36:59 »
In QMK it uses regular RGB underglow. So you can use the RGB_XXX keycodes. You can also use VIA for it for dynamic lighting changes.
Offline i_tekneek
« Reply #1277 on: Tue, 10 March 2020, 12:25:15 »
Thanks to merlin64 I created a sub-reddit dedicated to these awesome boards and wrote up a pretty comprehensive guide to programming the viper/eagle v2/v3 with QMK and VIA. I had some trouble finding all the info I was looking for so I hope this makes it easier for everyone else too.
https://www.reddit.com/r/DuckKeyboard/comments/fg8u4d/programming_your_duck_keyboard/?utm_medium=android_app&utm_source=share
