Author Topic: [GB] Duck Viper/Eagle V2 Kustom Group Buy [Closed] - 2nd Batch Shipped  (Read 419058 times)
Offline zacheadams
Re: [GB] Duck Viper/Eagle V2 Kustom Group Buy [Closed] - 2nd Batch Shipped
« Reply #1000 on: Thu, 18 May 2017, 20:24:40 »
Anyone has a link for how to install holtites? pushing the holtites down into pcb is too painful because the hole is too tight, cant even feel my fingers anymore  :'(
Super seconded.  I'm hoping to use holtites on this board.
Search... Literally was the first hit on YouTube.
In some capacity, I was trying to get a more specific guide for this PCB.
I have heard that the backspace doesn't necessarily install but I can't figure out why from a Google search.  I don't have the holtites yet, I'm trying to ask so I don't tinker before having complete information on a very expensive board :/
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #1001 on: Thu, 18 May 2017, 22:38:49 »
Just did a full holtite install on my VE.A, your main enemy is lifting pads.
You don't want to keep the heat on them for too long so it took me a few passes per switch.
First pass you just want to get the collar about halfway into the pcb. Second pass is the attempt get them sitting flush.
For me, the third pass was just touching everything was perfect.
I lifted a few pads on the macros before figuring this out.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline Potage
  • L'omelette du fromage
« Reply #1002 on: Fri, 19 May 2017, 12:23:50 »
Little potato of my Eagle, it has 62g lubed clear, OG DyeSub, GMK CMYK :
HHKB Pro 2 | Winkeyless b.mini | Eagle v2
Offline anthorix
  • Finally Awake
« Reply #1003 on: Fri, 19 May 2017, 17:00:04 »
found a use for those leftover sticker pieces.  Dampen the clipped stablizers as they hit the pcb.
Offline Sneaky Potato
  • Gunslinger
« Reply #1004 on: Fri, 19 May 2017, 17:52:34 »
I like this.
Offline dubious
  • 쏘쿨
« Reply #1005 on: Fri, 19 May 2017, 18:15:50 »
that's a good idea! How do they compare with bandaids/cosmetic tape?
Offline Atredl
« Reply #1006 on: Fri, 19 May 2017, 20:21:40 »
I want to know this as well. I've done bandaid mod with my other builds and I still have the leftovers from the stickers.
Offline anthorix
  • Finally Awake
« Reply #1007 on: Fri, 19 May 2017, 22:47:39 »
i don't have any other mods to compare them to, but they're working just fine.  :thumb:
Offline yookwh
« Reply #1008 on: Sat, 20 May 2017, 19:01:37 »
Has anyone here used hot swap sockets for the PCB? If so, how did it go?
Offline ViệtNV
    • VNMK
« Reply #1009 on: Sun, 21 May 2017, 03:36:15 »
I got my eagle in last week  ;D
Completed in yesterday  :D
168853-0
168855-1
Offline anthorix
  • Finally Awake
« Reply #1010 on: Sun, 21 May 2017, 22:55:04 »
mmm that sticker  :thumb:
« Last Edit: Sun, 21 May 2017, 22:59:36 by anthorix »
Offline wodan
« Reply #1011 on: Mon, 22 May 2017, 00:02:05 »
I have taken a few pics of the kit components for the DT wiki before assembly in case anyone is interested.
https://m.imgur.com/a/B0FRA
Will be live-streaming the build of both Ducks on YouTube soon:
https://m.youtube.com/channel/UCOfwAlVn0JxymLljlDnOODQ
Offline donjoan666
« Reply #1012 on: Mon, 22 May 2017, 15:47:20 »
Just have a short question. Why do we need to put weight on Viper/Eagle?
They are already heavy enough?... it doesn't move at all when typed?..
Offline gaiden
« Reply #1013 on: Mon, 22 May 2017, 18:35:57 »
Here's a short answer: Super size me. We must do it because we can. Wallets must be emptied. It's​ a vanity plate for your luxury Keeb 🙂
Sent from my SM-G935F using Tapatalk
  • Gunslinger
« Reply #1014 on: Mon, 22 May 2017, 18:45:15 »
It's to weed out the weak from the strong.
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« Reply #1015 on: Mon, 22 May 2017, 19:27:12 »
I tried to install holtites into duck pcb today but it doesnt fit, i got these holtites from zeal and its very lose, not sure which model # are these, i think i need to solder the holtites to make it stay in
Offline yookwh
« Reply #1016 on: Mon, 22 May 2017, 19:46:20 »
Thanks for letting us know  :thumb:
Offline wodan
« Reply #1017 on: Tue, 23 May 2017, 01:20:14 »
Built my Duck Viper V2 last night, here's the stream in case anyone is intereste:
Offline SixtyLife
« Reply #1018 on: Tue, 23 May 2017, 01:28:58 »
wow the board sounds so good. thanks for the vid.
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline donjoan666
« Reply #1019 on: Tue, 23 May 2017, 02:44:07 »
I like vanity. I'm in.
Offline donjoan666
« Reply #1020 on: Tue, 23 May 2017, 02:44:50 »
Well described. I'm in.
Offline zacheadams
« Reply #1021 on: Tue, 23 May 2017, 13:45:35 »
169012-0
Offline inosint
« Reply #1022 on: Tue, 23 May 2017, 15:44:30 »
And there you guys have it! Thanks Aaron! Would you mind reposting the link..I've had a couple people ask me for it already.
I'm only doing the non HHKB btw.
Sure, here you go:
https://drive.google.com/open?id=0B2BotsTwxuB5djNyaXdSWGp0Vmc
Does anyone happen to have the proper dimensions for this plate? They don't seem included in the ai
Offline aaron6301
  • Pixel Pusher
« Reply #1023 on: Tue, 23 May 2017, 18:35:12 »
Sure, here you go:
What dimensions do you need and for which file?
Offline inosint
« Reply #1024 on: Tue, 23 May 2017, 19:08:12 »
Was looking for dimensions specific to the PlateOutline-HHKB.ai file. A dxf file including dimensions was requested, so just looking for measurements.
Offline aaron6301
  • Pixel Pusher
« Reply #1025 on: Tue, 23 May 2017, 20:07:41 »
Here's the info that Lasergist requested, let me know if you need anything other than what is listed.
Plate Thickness: 1.5 mm
Height: 103.9mm
Width: 285.75mm
Path Length(total): 4887.588mm
Additionally, I asked them to verify that the plate measures 11.25″ by 4.0906″.
Offline inosint
« Reply #1026 on: Wed, 24 May 2017, 14:09:56 »
Height: 103.9mm
Width: 285.75mm
Excellent, that should be more than sufficient. Thanks again!
Offline Grimspoon
« Reply #1027 on: Wed, 24 May 2017, 21:42:33 »
Any Zeal compatible diffusers available for sale?
Offline loud_asian
« Reply #1028 on: Wed, 24 May 2017, 22:01:29 »
anyone know what the screw size is on the bottom holes?
« Last Edit: Wed, 24 May 2017, 23:18:04 by loud_asian »
Offline onmybikedrunk
    • Danny Woods - Industrial Designer
« Reply #1029 on: Thu, 25 May 2017, 00:17:37 »
I have two left, PM me your PayPal.  **They're on hold until all orders are received but you're first up if all goes well**
« Last Edit: Thu, 25 May 2017, 00:19:27 by onmybikedrunk »
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #1030 on: Thu, 25 May 2017, 09:20:41 »
Finally built one of my PCBs for my Duck Viper v2! Vintage Blacks lubed and spring swapped to 67g with lubed Zeal stabs.
Offline Grimspoon
« Reply #1031 on: Thu, 25 May 2017, 14:37:03 »
PM Incoming, thanks for looking out. Much appreciated!!!
Offline Unforgivable
« Reply #1032 on: Thu, 25 May 2017, 15:11:09 »
Silly question for those who have used plate mount switches - Do you ever get a bit paranoid that it could possibly damage the PCB someday, since it's floating and only sustained by solder joints?
I was going to try buying some Vintage Blacks for a different keyboard but that thought made me hesitate. I know I'm probably worrying for nothing though, but I thought I'd ask since some of you have used them in these Viper 2's!
On a side note: If you want a good home for your Viper V2, let me know! :(
Offline HappyCatFish
« Reply #1033 on: Thu, 25 May 2017, 19:24:46 »
I use plate mounted switches for everything but the stabilized keys (and sometimes other mods on compatibility plates) and have never had an issue. I hate installing PCB mount switches as they are a pain to get seated properly and uniformly and I always worry about accidentally breaking or bending the plate or PCB.
I would go for it!
Offline WarCommand
« Reply #1034 on: Fri, 26 May 2017, 11:45:28 »
So... next round when?  :-[
Offline gaiden
« Reply #1035 on: Fri, 26 May 2017, 12:13:24 »
Given the timeframe from R1 to R2, 2 years maybe
Offline WarCommand
« Reply #1036 on: Fri, 26 May 2017, 12:19:58 »
Fk
Offline iNViSiBiLiTi
« Reply #1037 on: Fri, 26 May 2017, 15:27:16 »
They should be M3 threaded counter sunk screws for the front of the case.  The back are hex socket screws.
60%: Prophet, GSKT-00 x2, Poly GSKT-00-Z, Weaven, Sangeo60, Unikorn R2.1, Ciel60, DNworks DM
TKL: TGR Jane V2, Jane V2 CE, KFE, Noxary 280 S, Acrylic Unicorn, Igris V1, LZ-GHv2, Bias R2, HMKB
Misc: Bulgogi Board (VA104M), Belle En Rose, Treeleaf 917, TGR 910 ME, ai03 Vega
Offline BlackInk
    • TeamGSB
« Reply #1038 on: Sat, 27 May 2017, 16:25:29 »
Guys, any info about the brass weight inserts? really wanna get one right now :(
    • WTB/WTTF Thread
« Reply #1039 on: Sat, 27 May 2017, 16:29:47 »
Nothing from Merlin as he still working on other buys AFAIK.
Offline zacheadams
« Reply #1040 on: Sun, 28 May 2017, 08:11:13 »
Given how long it's taking in the BlackBird weight buy, it's going to be a loooooong time to get this (that prior buy needs to end before this one begins), so you might want to cut your hype for a while :(
Offline mtzgr
    • My youtube
« Reply #1041 on: Sun, 28 May 2017, 09:16:06 »
Thinking of changing the supplier to cut down on the time?
Offline heroinbob
« Reply #1042 on: Sun, 28 May 2017, 23:06:52 »
Disregard, figured it out. :)
Thank you,
Paul
« Last Edit: Mon, 29 May 2017, 03:16:06 by heroinbob »
Offline zacheadams
« Reply #1043 on: Mon, 29 May 2017, 07:43:39 »
He is, per that thread, but that still requires the current GB to end.
Offline Grimspoon
« Reply #1044 on: Thu, 01 June 2017, 16:53:59 »
Did many people purchase extra PCBs? Are there any available? I may have killed my board and will possibly need a replacement.
Offline BlackInk
    • TeamGSB
« Reply #1045 on: Thu, 01 June 2017, 17:11:20 »
Same, almost killed my board while desoldering, my pcb is ****ed up now but still able to work, not sure if i need to replace it in the future
    • WTB/WTTF Thread
« Reply #1046 on: Thu, 01 June 2017, 19:26:59 »
I purchased an extra plate and PCB to be safe. You should contact elton to ask but I would assume no.
This is why you purchase an extra to be safe.
Offline Grimspoon
« Reply #1047 on: Thu, 01 June 2017, 21:01:25 »
Got my kit new but second hand, I'd have bought a spare if I had been in the group buy.
Luckily my board is functional but it's lighting is messed up due to a unfortunate short. If I can't find a new PCB I may just see if anyone is interested in a spare case. Hate to see this thing go to waste.
Just exploring options at the moment. Would also entertain anyone who might be able to repair the PCB.
Offline retrochick
  • goodbye my wallet
« Reply #1048 on: Thu, 01 June 2017, 21:49:29 »
I'd be interested in a spare case. I'd also be curious to see where the short is in the PCB itself. Maybe it's an easy fix.
Offline Grimspoon
« Reply #1049 on: Thu, 01 June 2017, 22:31:26 »
I think it shorted near the right shift / enter key. The underglow RGB  near that spot just sort of flickers / freaks out a bit on that side. It's mostly an underglow issue, everything else seems okay.
I'm trying to figure out if theres a hard reset to default on the keyboard as opposed to booting into flash mode for firmware. I can load firmware just fine but i'd like to see how the board behaves when it's back to default, if that's even possible.
As it stands the board is fine as far as typing goes but I think the rgb is a just wrecked.
