Author Topic: [GB] Duck Viper/Eagle V2 Kustom Group Buy [Closed] - 2nd Batch Shipped  (Read 419088 times)
Offline zoomwalt
Re: [GB] Duck Viper/Eagle V2 Kustom Group Buy [Closed] - 2nd Batch Shipped
« Reply #1050 on: Thu, 01 June 2017, 22:57:03 »
Excuse my ignorance, but how difficult is it to have a new PCB manufactured?
Offline loud_asian
« Reply #1051 on: Thu, 01 June 2017, 23:30:06 »
If you've already got the PCB schematics, all you have to do is plug it into a PCB manufacturer's website and they'll make it for you
If you don't have the files, you'll have to reverse engineer it. Which may take a while depending on how much PCB design you know
Offline zoomwalt
« Reply #1052 on: Thu, 01 June 2017, 23:33:15 »
Interesting. PS I'm from 714 too.
Is Duck cool with sharing PCB files?
Offline Will_26
« Reply #1053 on: Fri, 02 June 2017, 05:20:13 »
Just got a Viper this week :) Love it! I may have missed it, but just wondered if there are any plans for a weight insert?
Also got it programmed last night, can anyone tell me which are the selections I need in the firmware to add hotkeys for LED colour change? I see the LED options, just not sure which one sets the colour.
Cheers! :)
« Reply #1054 on: Fri, 02 June 2017, 12:48:55 »
Cheers! :)
A weight is planned, as far as I know.
Probably not. Most Korean designers don't like to see copies of their work. Look at what happened with Koala...
Offline gaiden
« Reply #1055 on: Fri, 02 June 2017, 19:34:52 »
Cheers! :)
I'm interested to know what happened to the person you mentioned. Any context on it? Story time somebody :)
Sent from my SM-G935F using Tapatalk
Offline Dreamre
    • kbdlife
« Reply #1057 on: Sat, 03 June 2017, 11:51:29 »
What size indicators led would you recommend?
1.8mm LED if you're using SIP sockets, 1.8mm or 2x3x4 without the sockets.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #1059 on: Sat, 03 June 2017, 11:55:55 »
What about the layers leds - the same?
Yes
Offline loud_asian
« Reply #1062 on: Sun, 04 June 2017, 00:30:57 »
Yes
Frosted or clear?
doesnt matter
    • WTB/WTTF Thread
« Reply #1064 on: Wed, 07 June 2017, 07:07:22 »
Can I use SMD Gatistotle plate mountable switches with my Eagle V2? If I can do I need a plate mountable stabilisers?
You can use plate mount switches but need to use PCB mount stabs.
Offline darkslay3r
« Reply #1066 on: Thu, 08 June 2017, 07:48:10 »
i had viper v2, looking for some possibilty to get extra pcb or maybe elton should open GB for extra pcb since many people want it  ;D
Viper V2 | TGR 910 CE | TGR 910 Poly R1 | RF 55g
    • WTB/WTTF Thread
« Reply #1067 on: Thu, 08 June 2017, 07:56:38 »
Just because a lot of people want it, doesn't necessitate him doing it. There was a chance to buy extra PCBs and plates in the group buy.
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #1068 on: Thu, 08 June 2017, 13:05:38 »
Why not just use another 60% PCB and solder the USB cable straight to the board and route it out the middle?
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline Mizzazz
« Reply #1069 on: Sun, 11 June 2017, 05:48:02 »
Anyone have a black eagle top and is looking to trade for a viper one?
Viper V2
Offline byker
  • Literally Canada
« Reply #1070 on: Tue, 13 June 2017, 00:49:22 »
Finally built my 1st batch board, was my first board that I built myself!
Offline yonghf
« Reply #1071 on: Tue, 13 June 2017, 03:48:44 »
I just got a Viper v2 kit yesterday and am thinking about what to do with it. Can you share your specs please? Did you use sip-sockets for those in-switch LEDs?
Offline byker
  • Literally Canada
« Reply #1072 on: Tue, 13 June 2017, 10:00:16 »
I used lubed vintage browns and an acrylic plate. QUite a fun feeling as the plate is pretty flexy. I did not use sip sockets for the leds.
Thanks to wodan for the helpful build log and iNViSiBiLiTi for the programming guide!
Offline renzpwns
  • I didn't like money in my wallet anyways.
« Reply #1073 on: Tue, 13 June 2017, 15:08:18 »
Quick question, where can one find a good source for Vintage MX Browns? Fantastic looking board by the way!
Offline byker
  • Literally Canada
« Reply #1074 on: Tue, 13 June 2017, 19:57:38 »
Thanks! I am not sure to be honest, I got them from a friend. There was someone on mechmarket selling them a while back, called heroinbob iirc, not sure if he still has some though!
Offline renzpwns
« Reply #1075 on: Wed, 14 June 2017, 19:10:16 »
Thanks a lot, I'll ask if he still has em.
« Reply #1076 on: Wed, 14 June 2017, 20:13:20 »
The mx brown was introduced 1994 and it is thought that Cherry changed much of their tooling sometime between 1994-95. Does this mean there are essentially no true vintage browns aside from those in very early G80-5000s?
Offline hoanglh94
« Reply #1077 on: Sat, 17 June 2017, 05:20:02 »
Showing off some dusty keycap xD
Offline anthorix
  • Finally Awake
« Reply #1078 on: Sat, 17 June 2017, 11:40:55 »
you could buy a cheap and large paintbrush to clean the dust. can keep it forever, looks nice, helps with pictures.
Offline techfresh
« Reply #1079 on: Sat, 17 June 2017, 12:03:53 »
Guys, any info about the brass weight inserts? really wanna get one right now :(
Given how long it's taking in the BlackBird weight buy, it's going to be a loooooong time to get this (that prior buy needs to end before this one begins), so you might want to cut your hype for a while :(
Do you have the specs for the weight already or how would one go about getting the specs?  I was going to check to see if there are any shops in the Bay Area that could fulfill an order.
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« Reply #1080 on: Sat, 17 June 2017, 14:01:14 »
You could either pm merlin or send an email to duck for the spec
Offline mindxthinker
« Reply #1081 on: Sun, 18 June 2017, 07:19:22 »
Here comes my viper v2!!
    • WTB/WTTF Thread
« Reply #1082 on: Sun, 18 June 2017, 10:22:14 »
Very clean! That under glow leak on the right would irritate me though
    • WTB/WTTF Thread
« Reply #1084 on: Sun, 18 June 2017, 10:57:46 »
What leds are those? PCB's smds or in-switch ones?
In switch most likely.
    • WTB/WTTF Thread
« Reply #1086 on: Sun, 18 June 2017, 11:02:18 »
Do I need sip sockets for mine? any suggestions?
You don't need SIP sockets. If you plan on switching the LEDs than use SIP sockets.
Offline ihalatch
« Reply #1087 on: Tue, 20 June 2017, 02:51:25 »
I'm wondering whether to buy the mechanicalkeyboards.com MX Switch Top Removal Tool for the switches. Can they be opened while mounted into the pcb and the plate?
Offline loud_asian
« Reply #1088 on: Tue, 20 June 2017, 04:06:17 »
No, the included plate doesn't have the cutouts to allow for switch top removal
Offline ihalatch
« Reply #1089 on: Thu, 22 June 2017, 07:11:35 »
I bought the R6 Purple Zealio Switches (Tactile) for my vipear and eagle. Do I need to lube and sticker them? I'll open them anyway for the sip sockets.
Offline kawasaki161
« Reply #1090 on: Thu, 22 June 2017, 07:56:37 »
You don't NEED to do anything to them. But if you want you can lube them (I found that a very slim coat of lube on everything but the tactile legs on the stem works well for me, your results may vary).
The switches should not be stickered (like all tactile switches imo) as it makes the stroke longer and thus moves the bump further down the stroke. Gateron based switches also don't have that bit of play between the housings that Cherry switches can have which stickers are supposed to remove. Thus the sticker would also be pretty useless.
Offline ihalatch
« Reply #1091 on: Thu, 22 June 2017, 08:39:33 »
Thanks for the advice.
Offline kconfire
« Reply #1092 on: Fri, 23 June 2017, 15:07:50 »
If anyone wants to sell their unbuilt Viper v2 kit, PM me! :)
Thanks.
[Collection] Monokei Kei SE, Realforce R2 TKL, Leopold FC660C
[Soon TM] Monokei Tomo SE, GSKT-00
Offline aaron6301
  • Pixel Pusher
« Reply #1093 on: Fri, 23 June 2017, 15:24:37 »
Thanks.
I'll likely be selling mine in the near future. It's not a kit but I had a custom plate made which allows for switch top removal.
Offline iNViSiBiLiTi
« Reply #1094 on: Fri, 23 June 2017, 16:06:58 »
you should lube the side of the switches so it's not rattly.  The legs don't need lube IMO since a small amount is already applied.
60%: Prophet, GSKT-00 x2, Poly GSKT-00-Z, Weaven, Sangeo60, Unikorn R2.1, Ciel60, DNworks DM
TKL: TGR Jane V2, Jane V2 CE, KFE, Noxary 280 S, Acrylic Unicorn, Igris V1, LZ-GHv2, Bias R2, HMKB
Misc: Bulgogi Board (VA104M), Belle En Rose, Treeleaf 917, TGR 910 ME, ai03 Vega
Offline kconfire
« Reply #1095 on: Fri, 23 June 2017, 16:10:49 »
Thanks.
Let's see how that goes.
PM me if you're interested in selling and we can work something out later I suppose.  :thumb:
Offline dblack
  • Formerly ZuXzu
« Reply #1096 on: Fri, 23 June 2017, 16:19:19 »
Also looking for viper kits, built or not lmk if anyone wants to sell theirs.
Offline merlin64
    • MechMerlin
« Reply #1097 on: Fri, 23 June 2017, 16:57:00 »
Wow people still have unbuilt viper/eagles? How much would those go for?
Offline kconfire
« Reply #1098 on: Fri, 23 June 2017, 17:44:02 »
I've seen it from low 500s to 700s at one point.
But anything over 600 is considered excessive I would imagine regardless of the demand given that the original GB was ran at such "low" price point.
500-550 seems about right.
Offline techfresh
« Reply #1099 on: Sat, 24 June 2017, 10:32:33 »
I saw Eagles go for the 500s range and Vipers for the 600s range.  I think kits have a higher price point as well than already built.
