Author Topic: Which Alps compatible cap has the smoothest corners and edges?  (Read 3326 times)
Offline Tye
« on: Thu, 01 December 2016, 16:53:07 »
I use a Planck and the bottom corner keys are used to switch to my navigation layer. I have them turned upside down to lessen the edge and use the palm of my hand to push them. Unfortunately, they are still very sharp and are really starting to hurt where my palm hits the edges.
With Alps switches being so rare, is there anything out there that a smoother edge?
Offline zombimuncha
Re: Which Alps compatible cap has the smoothest corners and edges?
« Reply #1 on: Wed, 11 January 2017, 09:24:20 »
Matias caps are fairly rounded at the edges.
These seem to be identical (except legends) to the the stock Apls caps KBParadise uses.
I haven't compared to DSA tho.
Offline Tye
« Reply #3 on: Fri, 20 January 2017, 10:57:08 »
Thanks for the input. I'm currently using the Matias -- still a little sharper than I'd prefer. The DSAs are pricey but I'm going to give them a try. If I find anything interesting, I'll report back.
Offline h1ggs
  • @switzcaps
« Reply #4 on: Fri, 20 January 2017, 16:17:20 »
Not sure I fully understand what you mean but SGI caps have a very nice roundness to them. Not the best pic but you can kinda see whats doin w my caps
