Author Topic: NMB RT6855T+  (Read 3395 times)
Offline Gungthar
NMB RT6855T+
« on: Wed, 21 December 2016, 01:20:41 »
Hello everyone. First post here so I'll try to keep it quality.
Today I was exploring the local thrift stores, and stumbled across a somewhat odd keyboard. At first glance, the NMB RT6855t+ seems to be a standard rubber dome keyboard. Only after pulling it apart did I realize that something quite interesting was going on. It seems as though this keyboard is bolt modded. I'm not sure if this was a mod or if this is how the keyboard was manufactured. Regardless of whether or not this is the default assembly, it seems quite odd that this level of craftsmanship made it onto a rubber dome. Could anyone shed any light on this?
Some pictures:
Re: NMB RT6855T+
« Reply #1 on: Wed, 21 December 2016, 06:46:56 »
I am not familiar with that exact product number, but it might well be a black NMB Hi-Tek. If the switches are clicky, it probably is ("T"=tactile and the "+" usually indicates the click).
If you remove a key cap, be very careful. They are hard to get off and you need to do it from the sides - not the corners. Also, be careful not to lose the spring or bend any of the delicate "fingers" of the contacts when you put it back together.
- Oliver Willis 2026-08-01
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: NMB RT6855T+
« Reply #2 on: Wed, 21 December 2016, 07:20:14 »
That's an NMB dome with slider board innit? Those come with bolts by default iirc. Decent switches too.
Offline Gungthar
Re: NMB RT6855T+
« Reply #3 on: Wed, 21 December 2016, 12:39:18 »
Oddly enough, it's not a space invader nor is it even a rubber dome with slider. it's just a straight up green rubber dome. I have to say, it is by the the best rubber dome I've ever used.
Offline chyros
  • a.k.a. Thomas
Re: NMB RT6855T+
« Reply #4 on: Wed, 21 December 2016, 14:50:28 »
Can you give a picture of what it looks like under the keycap?
Offline Gungthar
Re: NMB RT6855T+
« Reply #5 on: Wed, 21 December 2016, 15:01:29 »
A few more images:
Not entirely sure of the purpose of this copper bar, but the steel plate, and assembly lay on top of it.
The keycaps are dye sublimed PBT
It does also appear to have N-Key rollover.
« Last Edit: Wed, 21 December 2016, 15:10:29 by Gungthar »
Offline davkol
  •  Post Editing Timeout
Re: NMB RT6855T+
« Reply #6 on: Wed, 21 December 2016, 15:19:19 »
So, rubber dome *without* a dedicated slider.
Offline Gungthar
Re: NMB RT6855T+
« Reply #7 on: Wed, 21 December 2016, 15:32:28 »
Yep. Makes the build quality on this seem quite out of proportions. This is probably the sturdiest keyboard I own, and somehow it's a rubber dome.
