Author Topic: Gons pcb with phantom tkl mounting plate, will it work?  (Read 2590 times)
Offline hgoel89
« on: Tue, 27 December 2016, 23:04:45 »
I have been looking around to get a TKL hand built. I have been moving between Gons and phantom parts.
Phantom PCB is only available at mechanicalkeyboards.com and the shipping alone is greater than the price of PCB itself.
The shipping price at Gons is more reasonable, but I could not find any compatibility guide / post for gons pcb.
I have downloaded the phantom mounting plate from deskthority.net and will be using the ANSI 125 layout.
Will this plate work with gons pcb?
Sent from my ONE A2003 using Tapatalk
Offline mike52787
  • Alps Aficionado
Re: Gons pcb with phantom tkl mounting plate, will it work?
« Reply #1 on: Wed, 28 December 2016, 00:02:38 »
I dont see why not, It'll be the same layout. As long as the case youre using fits the gon pcb I dont see where there would be a problem.
Offline diqkiq
« Reply #2 on: Wed, 28 December 2016, 00:29:02 »
The Phantom plate will not work with the Gon PCB. The Phantom Plate spacing between the function row and the number row is greater than the Gon PCB.
Filco Majestouch TKL, Noppoo Choc Mini, Realforce 87 55g, Model M TKL, Ducky Shine 3 TKL, KC60, Planck.
Offline hgoel89
« Reply #3 on: Wed, 28 December 2016, 00:48:24 »
Anywhere I can get the layout design for it?
Offline diqkiq
« Reply #4 on: Sat, 31 December 2016, 13:24:07 »
I only know of the layout for the Phantom. You can find it in the wiki i believe
Sent from my Nexus 6 using Tapatalk
Offline hgoel89
« Reply #5 on: Sat, 31 December 2016, 13:27:37 »
I have the plate file with me...  But as quoted above, GONS has different spacing for fn row....  And the arrow cluster too is more closer to the main key
Offline diqkiq
Offline hgoel89
« Reply #7 on: Sat, 31 December 2016, 20:53:01 »
https://deskthority.net/group-buys-f50/ansi-iso-jd40-styled-plate-case-t11302.html
Hit up the OP for the files
You are a rockstar. Thank you.
I tried Google the plate, but could not find any thing. Will try to reach the OP
