Author Topic: Suggest a keyboard  (Read 2495 times)
Offline racecar
Suggest a keyboard
« on: Sat, 31 December 2016, 13:19:54 »
Hi,
I am looking for a new keyboard for me. I like the MX Blue. Choosing between illuminating and not illuminating.
I found: Filco Ninja Majestouch-2, Ducky Shine 5.. or something from Topre? Like this http://www.keyboardco.com/keyboard/usa-topre-realforce-87ub-variable-mini-black-on-black-keyboard.asp ?
I'd like to buy in Europe.
Any more ideas and suggestions?
Thanks.
« Last Edit: Sat, 31 December 2016, 16:33:08 by racecar »
Offline HerrVoennchen
Re: Suggest a keyboard
« Reply #1 on: Sun, 01 January 2017, 06:46:41 »
Maybe a Ducky one. According to this video
they are assembled in Taiwan. The Shine in China which results in a slightly better quality for the one. Cannot say if this is valid for a general assumption.
@work: Keychron K8 Pro w/ Gateron Ink Black v2
@home: CoolerMaster Masterkeys Pro S RGB (MX-Brown)
retired until fixed: Ducky One 2 SF (MX-Black, US-Layout)
Retired: Varmilo Miya Pro DualOS Custom (MX-Black, US-Layout)
Offline moh18one
« Reply #2 on: Sun, 01 January 2017, 07:08:40 »
Ducky lol :D
Take a Leopold or Varmilo (yes in Europe)
http://candykeys.com/ and https://mykeyboard.eu/ are selling Leopold (ISO-DE coming in January)
And http://shop.caps-unlocked.com/category/keyboards for Varmilo. They're selling ISO layout too. Actually the TKL version is coming early January and I think you can probably contact them to buy the VA109M if you want a full size
These are two better option than Filco and D..ucky
« Reply #3 on: Sun, 01 January 2017, 08:00:00 »
What's wrong with Ducky? I'm using mechanical keyboards for a while but in depth I'm fairly new to his topic.
Offline moh18one
« Reply #4 on: Sun, 01 January 2017, 08:37:15 »
Ducky isn't bad if you want a RGB keyboard(the best brand with Vortex) but for the same price or less you have Leopold and Varmilo which come with stock PBT keycaps (backlight and full magnesium case for the Varmilo).Also, you can buy a Varmilo with gateron switches  :cool:
« Last Edit: Sun, 01 January 2017, 08:41:13 by moh18one »
« Reply #5 on: Sun, 01 January 2017, 09:47:33 »
The Varmilo looks very interesting indeed. Since I just bought my Pro S I'll keep an eye on Varmilo. Thanks for the hint. :)
Offline seville57
« Reply #6 on: Sun, 01 January 2017, 09:49:04 »
The only things I don't  like about the Shine 4/5 RGB is the "Bigfeet" design and that you can't turn off the both Win keys with the Dip switch + the Calculator key on Ducky One.  I have some ISO/Nordic Shine 2/3 and some ANSI Shine 3/4 + 2 ANSI Ducky One.
« Last Edit: Sun, 01 January 2017, 09:52:33 by seville57 »
Offline moh18one
« Reply #7 on: Sun, 01 January 2017, 10:01:18 »
no problems  :thumb:
Offline 1391406
« Reply #8 on: Mon, 02 January 2017, 20:11:36 »
Topre.
Offline Moistgun
  • Slippery When Wet
« Reply #9 on: Mon, 02 January 2017, 21:56:09 »
Silenced and lubed HHKB with a mousemat underneath
