Author Topic: [GB] M65-A | Made with RAMA.WORKS (Complete)  (Read 1784421 times)
Offline jchan94
  • Keyclack Inc
  • * Moderator
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
Re: [GB] M65-A | Made with RAMA.WORKS
« Reply #200 on: Fri, 13 January 2017, 02:47:51 »
Great. Now I'm starting to wonder if I had a typo on my email.
check your PM for your PP email. I have it.
My invoice shows the base and an additional base - did I make an error or is this correct? Can't really remember the form anymore :-/
If you have an error, or think there is an error.
Email me -> jchan@keyclack.com
Trying to steam roll this and make live changes as people get them.
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline q1w2e3r4t5z
« Reply #201 on: Fri, 13 January 2017, 03:01:43 »
Thanks, sent
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #202 on: Fri, 13 January 2017, 03:48:46 »
Thanks, sent
Sorted out <3. Looks like someone got too excited about champagne and wanted two champagne base alu sets :)
Offline Crossfire
« Reply #203 on: Fri, 13 January 2017, 04:16:47 »
That happens when products like M65-A go viral. :)
Choo choo, all aboard!
Offline q1w2e3r4t5z
« Reply #204 on: Fri, 13 January 2017, 04:26:33 »
Thanks, sent
:cool: Well, more is always better
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #205 on: Fri, 13 January 2017, 05:45:58 »
Hi everyone,
Invoicing is complete.If you didn't get an invoice, please email -> jchan@keyclack.com with your username that you input into the form, and your PP email.
If you need any clarification for anything that you are to receive please let me know.
All kits will come with (by default)
1. Screws required.
2. Cherry Stabilizers
3. Brass Weight
4. Rubber Feet that matches your Top Piece
5. Plate (ALU6061 or Brass Upgrade)
6. Main Rigid Frame
7. Base (ALU6061 or Nylon)
8. PCB
Below are some examples of what you should have gotten in the invoice. It also includes shipping prices, and the terms and conditions denotes your shipping method (USPS, DHL, or FEDEX).
1. Space Grey w/ Nylon Base
2. PCB
1. Space Grey w/ Alu Base
2. Base - Silver Aluminum
3. PCB
3. Brass Plate Upgrade
4. PCB
5. Mousepad
2. Additional Base - Silver
4. PCB
5. Mousepad
« Last Edit: Fri, 13 January 2017, 05:47:42 by jchan94 »
Offline kawasaki161
« Reply #206 on: Fri, 13 January 2017, 06:37:57 »
Aaaand paid  :thumb:
Ended up more expensive than I hoped, but I know that it'll end up being worth it.
Offline squeakypizza
« Reply #207 on: Fri, 13 January 2017, 07:02:38 »
Invoice paid!  Super excited.  Can't wait to get this!
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #208 on: Fri, 13 January 2017, 07:05:13 »
Aaaand paid  :thumb:
It starts out affordable,  but as you add extras, it can get pricey. Extra base, brass plate, mousepad.
I did my best with shipping. Pulled all the live quotes manually for every order and charged the most affordable one unless someone noted they wanted DHL. This was done manually for everyone based on their specific weight and order. It was definitely a pain.
Cheers and thanks for joining!
« Reply #209 on: Fri, 13 January 2017, 07:15:09 »
Thanks for all your work on this Jchan. When it come time for these to ship will we be able to update our addresses? I will be moving before it ships but I don't have my new address yet.
Sent from my E5823 using Tapatalk
Offline PriusProblems
  • No ISO, no interest.
« Reply #210 on: Fri, 13 January 2017, 07:19:09 »
Paid earlier today, so glad that we could work everything out (and one less thing for me to worry about jchan).
Once all the invoices are paid, can we get numbers of the amount of people in this group buy, just out of interests sake? I was thinking that it would be a lot, but the kit ended up quite a bit more expensive than I originally assumed.
Offline pon10
  • looking at my keycaps..
« Reply #211 on: Fri, 13 January 2017, 07:19:35 »
Done, Paid!
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #212 on: Fri, 13 January 2017, 07:19:52 »
Mid April is our projection.
You can update whenever you move by emailing me your order number,  current address, and new address at any time.
Time for sleep... It's 5am.
Offline pon10
« Reply #213 on: Fri, 13 January 2017, 07:49:14 »
Thanks for the work you have put into this, JChan :thumb:
Offline jjwax
« Reply #214 on: Fri, 13 January 2017, 08:26:12 »
Super pumped for this, just paid!
Offline Malenky
« Reply #215 on: Fri, 13 January 2017, 09:54:39 »
I have supplied the email address that is attached to my PayPal, however I don't use this email address for actual correspondence. Is there a way to provide a contact email that is different to PayPal email?
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #216 on: Fri, 13 January 2017, 10:38:20 »
PAID  :thumb:
Aaaand paid  :thumb:
REALLY appreciate the effort made for the shipping  :-*
Offline Arallu
« Reply #217 on: Fri, 13 January 2017, 10:44:06 »
Thanks Jchan  :thumb:
« Last Edit: Fri, 13 January 2017, 10:46:53 by Arallu »
Offline BAS1C
« Reply #218 on: Fri, 13 January 2017, 11:01:45 »
Thanks dood this is awesome!!! HYPE.
Q: Can we get the case side-screw dimensions to source our own colour variants?
Offline Brammm87
« Reply #219 on: Fri, 13 January 2017, 11:30:03 »
Hex screws like these will look baller I think. Might just do black ones to go with the Hydro.
pls gief bbv2
Offline BAS1C
« Reply #220 on: Fri, 13 January 2017, 11:44:44 »
Indeed, I'd like to get some brass ones!
Offline Valaris
« Reply #221 on: Fri, 13 January 2017, 14:25:05 »
Jchan I'm going to apologize again but I had to send you another email. I totally confused brass plate with the brass weight that goes under the base (I blame English not being my first language) and when I told you I was missing the brass plate from my order, I was wrong -_- I don't want the brass plate, I want the brass weight and thought that was sold separately.
Mea culpa
Offline Tally810
« Reply #222 on: Fri, 13 January 2017, 14:46:32 »
Paid!
Offline childofthehorn
« Reply #223 on: Fri, 13 January 2017, 15:06:45 »
Hey for anyone else who selected all of the "standard' lower priced options, what did your kit total out to?
I got a paypal invoice for $276 when I selected only the stuff for the $210 options and $25 CONUS shipping so with paypal fees I guess ~$240 right?
Offline Arallu
« Reply #224 on: Fri, 13 January 2017, 15:08:34 »
The PCB, $40 is on all orders too I believe.
Offline Zanduby
« Reply #225 on: Fri, 13 January 2017, 15:09:49 »
+$40 for the PCB.
Offline Photoelectric
« Reply #226 on: Fri, 13 January 2017, 15:14:31 »
See this:
I probably just missed it in the thread but I thought the $210 price included the PCB. Just wanted to make sure I didn't accidentally select an extra PCB when filling out the form. If it's correct I'll pay the invoice right away!
The PCB was not included in the base price of the case, those prices were independent of one another.
$210 w/ Nylon Base
$230 w/ Alu Base
$40 PCB
$210 and $230 are prices of the case kit with aluminum plate.  +$40 for PCB, $35 to change aluminum plate to brass, as per the OP.
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #227 on: Fri, 13 January 2017, 15:42:25 »
What photoelectric said is accurate.
As I've said, the shipping is the lowest we can get it for manually calculated for everyone's specific order weight, and destination.
If you are in cali, you got way cheaper shipping, at 15 usd from usps, but then you were subjected to sales tax (state law thing).
While in other places like Utah or Arizona, you got shipping at 15 usd and no sales tax. It's all processed and we spent a good chunk of the time in the process.
Ill be checking emails soon regarding any changes and they'll happen later tonight (it's like 2pm pst).
Offline Tally810
« Reply #228 on: Fri, 13 January 2017, 15:45:22 »
Houston Texas here and with standard nylon plus pcb plus mouse pad it was 30 shipping.  Didn't seem too bad to me.  Thanks Jchan
Offline Potatoes
« Reply #229 on: Fri, 13 January 2017, 16:23:30 »
$325 for me in Vegas. Nylon, brass plate, and mousepad. Shipping was 15.
Also, paid.
Offline _cramil
« Reply #230 on: Fri, 13 January 2017, 16:26:28 »
See this:
$210 w/ Nylon Base
$230 w/ Alu Base
$40 PCB
Yea I kinda did the same double-take because for some reason I was also thinking the PCB was part of the "kit" price. Se la vie at this point and I see where I missed that detail. Still stoked for this awesome keyboard!! However, much as I want to jump in and pay my invoice right away I am inclined to wait for my 1965 refund to process or the 17th deadline.
Offline CMYK
« Reply #231 on: Fri, 13 January 2017, 17:21:15 »
I've agonized over it, and just decided to pay the invoice. Blue top and bottom is incoming.  If it doesn't work out, maybe someone would be willing to trade bottom pieces.
« Reply #232 on: Fri, 13 January 2017, 17:29:36 »
See this:
$210 w/ Nylon Base
$230 w/ Alu Base
$40 PCB
Thanks guys! I'm still in just was wondering!!!!
« Reply #233 on: Fri, 13 January 2017, 17:31:50 »
I might be if you decide you want rose gold bottom :D  Had that in mind for a while, but not 100% sure.
Offline Tally810
« Reply #234 on: Fri, 13 January 2017, 17:35:57 »
I feel ya I got black on black (yea that's ****in ross). I gotta feeling there will be lots of trading.
Offline CMYK
« Reply #235 on: Fri, 13 January 2017, 17:36:07 »
However the color turns out, I know they are going to turn out very well.  I got to see one Rama65 in person, and was very impressed.
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #236 on: Fri, 13 January 2017, 18:35:15 »
Hi everyone,
I just went through all the support emails for this.
If you have anything else, please email me -> jchan@keyclack.com
I'll try to respond asap.
Offline LadyGrey_MN
« Reply #237 on: Fri, 13 January 2017, 21:04:02 »
Invoice paid.  Jchan, you are a Keyboard Star!  Grand Budapest SA is going to look mighty fine with the rose gold case!  This will be the first keyboard that I'll put together myself. No worries, that son of mine has all the cool tools I can steal, I mean borrow.  Yeah, that's it, I'll borrow them.  Now just to decide what switches... Zealios 65g or Gateron Greens.
Offline _cramil
« Reply #238 on: Fri, 13 January 2017, 22:05:51 »
Just wanted to put in a shout out to jchan!! Even with a ton going on with this M65 GB happening, Hydro shipping, SA1965 wrapping up etc, etc, etc he has still been super responsive with communication and that is what really matters to keep people happy! Thanks again jchan for taking on some great stuff that supports this community!!
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« Reply #239 on: Sat, 14 January 2017, 00:59:45 »
Yesssss big shout out to him!!
Offline tanker666
  • Izaayaaa!
« Reply #240 on: Sat, 14 January 2017, 01:48:20 »
What is the size and type of the side screws?
I plan to source different colored ones if there are any somewhere.
  PurePro
Offline Perfex
« Reply #241 on: Sat, 14 January 2017, 02:17:20 »
I believe M3x8MM
Offline Fullcream
« Reply #242 on: Sat, 14 January 2017, 04:04:33 »
I gave you my money and I am excited.
I would have liked the black version more but space gray will match a broader range of my keysets.
wishing you all the best.  :-* mwah
Offline obviouslygene
« Reply #243 on: Sat, 14 January 2017, 04:11:02 »
paid! cant wait for this to come.
probably will grab some mod-h switches n wait for a nice key set to release too.
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #244 on: Sat, 14 January 2017, 04:22:24 »
Glad everyone is hyped. It's been a  long week.
Hope to get everyone processed soon. I'm already talking to the manufacturer about bulk production and working internal logistics. So far, working off of the Google doc has been way better to organize this buy, but we'll build for the future in our next crazy purchase.
If you think about it, there were an insane number of skus possible.
6 top colors, 7 base choices, 2 plate material choices, optional 6 base addons, and optional Mousepads.
Get hyped. Working hard towards our mid April delivery. Will keep everyone updated as we work towards that.
Just an FYI, I will be moving offices during this time, so there may be a slight delay with all of this. Such is life, as we move onto bigger and better things.
Thanks for supporting the M65,  and this collaboration between  Rama and I. We've been working at this since September and it's been a long time coming.
Time to go to sleep now... It's 2am and I slept at 5am last night. Have a good day wherever you are in the world ;)
Offline Atredl
« Reply #245 on: Sat, 14 January 2017, 04:27:31 »
You have so much hype I think you forgot what sleep is!
Offline kawasaki161
« Reply #246 on: Sat, 14 January 2017, 04:54:53 »
Congratulations on finally moving out of that tiny room, it was already small when I visited, but now after this business has grown so much I can't even imagine how cramped it is now.
Offline testplsignore
  • I am one with the Cup Rubber...
« Reply #247 on: Sat, 14 January 2017, 05:59:10 »
Has anyone considered stainless steel as an alternative for the plate?
Would it be better or worse than aluminium?
Realforce 10AE 45g Type-S & 55g    HHKB BT & Type-S    Realforce RGB Hype-S    FC980C    FC660C    Filco BT TKL
Offline kawasaki161
« Reply #248 on: Sat, 14 January 2017, 06:49:13 »
Would be preference, I like stainless steel, but jchan made a poll asking how many people are interested in which plate materials and it seems like there weren't enough people interested in stainless steel for it to make it.
Offline Hydra04
« Reply #249 on: Sat, 14 January 2017, 06:54:12 »
Congratulations! Now I'm looking forward to hear something about the sandwich case :thumb:
