Author Topic: Kneepads  (Read 2695 times)
Offline ghostjuggernaut
Kneepads
« on: Mon, 09 January 2017, 18:14:39 »
Personally I like these.
One drawback though, is after you've been kneeling for a while the straps can get a bit bothersome on the back of your knee.
Re: Kneepads
« Reply #1 on: Mon, 09 January 2017, 18:44:08 »
I'll have to grab a pair of these for all the **** I suck
Offline Blackehart
Re: Kneepads
« Reply #2 on: Tue, 10 January 2017, 11:21:05 »
If you're a baller, you could just build up calluses.
*gigglesnort*
If you're a baller...
*chuckle*
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Kneepads
« Reply #3 on: Tue, 10 January 2017, 11:33:52 »
I think pretty much all kneepads will hurt round the back if you kneel for too long. If you are in the same place and keeling down for ages, I would recommend a pad to put down instead.
Or trousers with incorporated pads.
Re: Kneepads
« Reply #4 on: Tue, 10 January 2017, 15:52:15 »
If you are doing that many, you should probably take a break and walk around for a minute after about every third one.
- D Trump 2026-10-24
Offline katushkin
  • Just the guy
Re: Kneepads
« Reply #5 on: Tue, 10 January 2017, 19:21:26 »
If only to wash your mouth out
Offline happylacquer
  • BS Apologist
    • BHOBuds
Re: Kneepads
« Reply #6 on: Tue, 10 January 2017, 20:08:00 »
Disappointed every other reply after this isn't just an emptyquote
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Kneepads
« Reply #7 on: Wed, 11 January 2017, 01:20:09 »
I've rested my knees on the edges of attic/crawl space truss connectors on a few occasions. Prob have dents in my kneecaps to prove it lol. Those would have helped! Gel's good it'll grip where other kneepads won't. I'd rather something dig into the gel then slip out and possibly tear something that shouldn't be torn :confused:
Re: Kneepads
« Reply #8 on: Wed, 11 January 2017, 01:36:45 »
Offline ntw
Re: Kneepads
« Reply #9 on: Wed, 11 January 2017, 02:09:31 »
Offline kurplop
  • THE HERO WE DON'T DESERVE
Re: Kneepads
« Reply #10 on: Wed, 11 January 2017, 07:37:37 »
I only use the lower straps. They aren't quite as secure that way but it significantly reduces the discomfort at the back side if the knee.
Re: Kneepads
« Reply #11 on: Wed, 11 January 2017, 16:15:38 »
Noting these. My knees are really messed up so I would like to consider getting some pads.
