Author Topic: Hand wiring LEDs  (Read 1769 times)
Offline HeroXLazer
Hand wiring LEDs
« on: Fri, 20 January 2017, 18:08:08 »
I want to use a Teensy 2.0, 38 switches and 38 LEDs. What LEDs (based on current, beccause of the 1000 mah limit on USB) should I use for through switch and how would I wire the LEDs? I want to also use white or gold LEDs.
Offline Cortes
Re: Hand wiring LEDs
« Reply #1 on: Fri, 20 January 2017, 20:21:36 »
Uses leds of 3mm or leds 2x3x4mm.
If you are going to use them in a teensy, you should program them in the PWM pins, since using them there, you can program them to consume much less amps.
I am now fighting with the programming led for a teensy in TMK, and I will use 93 leds, and if I can, +44 leds more to illuminate the case.
Offline HeroXLazer
« Reply #2 on: Fri, 20 January 2017, 20:56:24 »
Should I use a seperate controller or just the Teensy?
Offline Tactile
« Reply #3 on: Fri, 20 January 2017, 21:10:05 »
You'll need to add a resistor for each LED. The resistor value you choose will determine the current through the LED.
I like 1.8mm leds for switches. They fit nicely in the little recess in the switch housing.
REΛLFORCE
