Author Topic: cut a spring  (Read 3026 times)
Offline Giorgio
cut a spring
« on: Sat, 21 January 2017, 07:29:18 »
Hello, I need to cut the first millimeter or so of a cherry spring, to make it shorter. The wires are very close to each other at the extremities, what tool would you use? A kind of cutting plier, with a flat side?
Offline majstor
Re: cut a spring
« Reply #1 on: Sun, 29 January 2017, 16:30:50 »
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: cut a spring
« Reply #2 on: Sun, 29 January 2017, 16:53:45 »
I would just use some flush cutters. $4.47 if you dont already have some, these are a must for this hobby: https://www.amazon.com/gp/product/B00FZPDG1K/ref=oh_aui_detailpage_o03_s01?ie=UTF8&th=1
-Dana
Offline Giorgio
Re: cut a spring
« Reply #3 on: Mon, 30 January 2017, 01:54:36 »
thanks! I'll buy it.
Offline Giorgio
Re: cut a spring
« Reply #4 on: Mon, 30 January 2017, 01:55:18 »
It should be sanded .
http://blueroofdesigns.com/2009/07/29/what-are-these-dremel-thingies-for/
It seems quite difficult to obtain a cut with repeatable precision!
Offline DamnDan
  • The Insane One
    • My Deviantart
Re: cut a spring
« Reply #5 on: Mon, 30 January 2017, 02:57:06 »
Make a jig, this way in either way you choose (flush cutters or dremel) you will get precise cuts every time.
E.g - drill a hole in piece of wood deep enough to fit the spring up to cutting point.
Offline majstor
Re: cut a spring
« Reply #6 on: Mon, 30 January 2017, 12:16:18 »
Take a metal tube in which you'll put a spring .The second part close to the desired length with something. Or take the rod on which you'll put the spring. I think you should Dremel or something.
Offline OfTheWild
Re: cut a spring
« Reply #7 on: Mon, 30 January 2017, 17:01:48 »
I like DamnDan's recommendation for a jig. Especially with inconsistencies in the number of 'dead' coils on each end of the spring. I would definitely take a little from each end to make sure you dont change the spring rate from 'active' coils... unless thats your intention.
-Dana
Offline Leslieann
Re: cut a spring
« Reply #8 on: Mon, 30 January 2017, 19:21:47 »
Sanding leads to heat, which will change the springs rating (it will soften it) and very inconsistently at that.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
