Author Topic: Reds, silent reds or reds with o-rings?  (Read 6148 times)
Offline Entropia
« on: Fri, 27 January 2017, 03:08:00 »
To anyone who has tried all these options...
Do you prefer reds, silent reds or reds with o-rings (for typing)?
Do reds with o-rings feel the same as silent reds but with reduced travel?
Have you tried silent reds with o-rings?
Is the reduced travel a good thing for typing?
Offline E3E
Re: Reds, silent reds or reds with o-rings?
« Reply #1 on: Fri, 27 January 2017, 03:29:38 »
I haven't tried silents, but I can tell you that one difference between O ringed reds and MX Silents is that the o rings only silence the downstroke whereas the silents silence both the up and downstrokes.
Silencing clips also do this too.
Offline Giorgio
« Reply #2 on: Fri, 27 January 2017, 05:05:33 »
I prefer silent reds which are very nice, and smoother than standard reds.
I don't like very much orings because they're too soft.
Silent reds with o-rings don't make sense.
Offline zpcomstock17
« Reply #3 on: Fri, 27 January 2017, 08:03:39 »
There's no such thing as a perfectly silent keyboard and silencing already silent reds would be a bad idea, it might dampen the feel of mechanical switch.
The cherry red switches are pretty light and a hair trigger if you're a heavy typer, I would recommend MX Silent Reds WITHOUT O-rings.
Offline zslane
« Reply #4 on: Fri, 27 January 2017, 11:54:26 »
I will echo was has been said so far. Silent reds are far superior to reds with o-rings.
However, silent reds are hard to come by right now. Especially in Chinese-branded boards. The only boards I know of that have them are Vortex Pok3r RGBs, Filco Majestouch-2s, and WASD V2s.
« Last Edit: Fri, 27 January 2017, 11:56:57 by zslane »
Offline dante
« Reply #5 on: Fri, 27 January 2017, 13:11:04 »
The Fission brand boards on MechanicalKeyboards.com also have silent red switches:
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2112
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2102
Also Ducky Pro's (none on MK at the moment) have silent reds as well.
« Last Edit: Fri, 27 January 2017, 13:19:08 by dante »
Offline Entropia
« Reply #6 on: Fri, 27 January 2017, 13:55:47 »
Isn't Leopold installing silent reds in some of their boards?
Offline dante
« Reply #7 on: Fri, 27 January 2017, 14:33:22 »
Yes they are, forgot about that one.
FC750R and FC980M.  No FC660M yet for some reason.
Offline RykoZin
« Reply #8 on: Fri, 27 January 2017, 15:31:42 »
For typing purposes have you tried Matias Quiet Clicks? I heard they're almost like blues but a lot quieter.
Offline zslane
« Reply #9 on: Fri, 27 January 2017, 15:37:58 »
I have a KBP V60 mini with the quiet clicks, and it is pretty good. Not as good as a silenced Topres, mind you. About as quiet as an MX silent red. Of course its main deficiency is the paucity of good keycaps available for the switch mount.
