Author Topic: [GB] MIRA SE - Custom 80% Keyboard (CLOSED)  (Read 3125694 times)
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [GB] MIRA SE - Custom 80% Keyboard (CLOSED)
« Reply #1750 on: Fri, 13 July 2018, 15:02:16 »
replacement parts rip?
Waiting... Last I got a PM was 1 month ago or so.
Offline roostrc0gburn
  • its just plastic
« Reply #1751 on: Fri, 13 July 2018, 15:24:49 »
same
Offline Photoelectric
« Reply #1752 on: Fri, 13 July 2018, 15:46:30 »
Hi,
Those who are waiting for replacement parts, I'm trying to push for that to happen soon. We have a list of what needs to be replaced, and I hope zzyjayfree will be contacting you soon with details. Looks like EVE said that sending in defective parts won't be necessary. I'm really sorry it's taken so long.
Offline lunr
« Reply #1753 on: Sat, 14 July 2018, 11:58:04 »
Is there still going to be a GB for additional parts?
Hi,
« Reply #1754 on: Sat, 14 July 2018, 12:01:22 »
From what I know, ninja worked on getting some quotes for local shops (that are USA-based), and all the numbers were pretty high.  Not sure what the status of that is at this time.
Offline lishi
  • Luxury Taste Buds
    • Personal Website
« Reply #1755 on: Sun, 15 July 2018, 17:16:38 »
Only took 6 months to get around building...  :p
WKL MIra SE
65g Lubed Vintage Blacks
OG Desko
All the kustom 60s
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1756 on: Sun, 15 July 2018, 17:18:43 »
WKL MIra SE
OG Desko
Very nice! Looks awesome, as are most of your other boards :D
Did Desko originally come with those nipple F/J homing keys? I thought that was BSP Desko.
Offline lishi
  • Luxury Taste Buds
    • Personal Website
« Reply #1757 on: Sun, 15 July 2018, 17:25:10 »
WKL MIra SE
OG Desko
Harvested this off a desko board i bought on ebay years ago, these are og
All the kustom 60s
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1758 on: Sun, 15 July 2018, 17:56:50 »
Cool, thanks; TIL about F/J being nipple on Desko boards.
Offline eksuen
  • Ambassador of explosions.
« Reply #1759 on: Mon, 16 July 2018, 18:44:26 »
WKL MIra SE
OG Desko
Looks fantastic. I quite like the orange on those mods.
I still haven't gotten round to building mine yet.  :))
Offline Etherealsound
« Reply #1760 on: Tue, 17 July 2018, 12:59:13 »
WKL MIra SE
OG Desko
That is seriously one of the nicest boards I've seen in a while.
Offline EVE
  • Outstanding because of professionalism
« Reply #1761 on: Wed, 25 July 2018, 02:36:34 »
Mira SE I have filled 5 sets of keyboard, including copper weight, you don't need to make up for the express delivery, everything is ready for me to make up for what you need. I will always be here ~ thank you for understanding and tolerance ~ @ninjadoc zzyjayfree Photoelectric thank you.
Designer and Manufacture of Metro, Nebula, Taichi, Plant(ICing), Moon.
Manufacture of Mira, MiraSE, Moon, Tank, Canoe, Canoe2, CanoeFE, Volt, Lite, Kira 80%, Kira Pad, Keycult 02, Ares HHKB, Evil 80, Evil 82, Evil 96,EQUALZ Zero 80%, EQUALZ 104, Origin 80%........
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1762 on: Wed, 25 July 2018, 02:38:10 »
Do you know if we can get confirmation as to whose parts are being prepared? I can PM too
Sent from my mobile using Tapatalk
Offline EVE
« Reply #1763 on: Wed, 25 July 2018, 02:43:48 »
Ah, but I only have these after sale lists from ZZ. :-[ :-[ :-[
« Reply #1764 on: Wed, 25 July 2018, 10:38:08 »
I have a detailed list, and I’m always available to discuss it or offer assistance.
  • its just plastic
« Reply #1765 on: Wed, 25 July 2018, 11:38:13 »
where is eason anyway
Offline Captainbuttmonkey
« Reply #1766 on: Wed, 25 July 2018, 18:02:33 »
Fairly sure my PCB is dead, works for a short time when I plug it in (between 10 secs - 1 min) and then I get 'usb device not recognised'. Have tried re-flashing and re installing the bootloader via isp programmer (the process of which works fine). Any suggestions or suitable alternative pcb recommendations most welcome =].
Offline att1cus
« Reply #1767 on: Sat, 11 August 2018, 14:32:04 »
Having some trouble with my PCB after soldering in-switch LED's.  Tested switches after soldering them, they worked fine.  About halfway through soldering LED's, I started getting "USB device has malfunctioned".  Anyone else had this issue?
Edit: happens both on USB 2.0 and 3.0 ports, tested on 2 PC's.
« Last Edit: Sat, 11 August 2018, 14:35:52 by att1cus »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1768 on: Sat, 11 August 2018, 15:59:31 »
Before you keep using the keyboard, unplug it. Check each LED that you've soldered and make sure you aren't shorting the two pins/pads.
Offline att1cus
« Reply #1769 on: Sat, 11 August 2018, 16:27:42 »
Here's some shots of the PCB: https://m.imgur.com/a/AokBoOJ
I have already tried unscrewing the stabs to make sure they're not responsible.
« Last Edit: Sat, 11 August 2018, 16:33:47 by att1cus »
  • its just plastic
« Reply #1770 on: Sun, 12 August 2018, 15:48:37 »
that screw bridging the two led pads on the iso enter looks concerning... did you use anything to isolate your stab screws from the pcb?
see my post here: https://geekhack.org/index.php?topic=87310.msg2578357#msg2578357
kapton tape is cheap, easy to get, and easy to use. if you shorted the led circuit, who knows what could have happened. i dont think there is any protection in that circuit
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1771 on: Tue, 28 August 2018, 00:14:51 »
Any updates from EVE on parts?
« Reply #1772 on: Wed, 29 August 2018, 11:12:36 »
I've been talking to EVE directly for the past couple of weeks.  He's making replacement parts.  I thought that was winding down, but the last message said 3 more weeks.  For those who need a top or bottom replacement, he's making both top and bottom parts together for anodized color consistency.
I will be contacting people who need replacements shortly to get up-to-date shipping address information.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1773 on: Thu, 30 August 2018, 06:13:20 »
Thank you. This should apply for Moon as well, right? I also have stuff there to get.
« Reply #1774 on: Thu, 30 August 2018, 11:35:31 »
I don't have anything to do with the MOON group buy :(  I can ask though.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1775 on: Thu, 30 August 2018, 11:48:14 »
Ah, my bad. EVE also did Moon, and zzyjayfree has been largely absent, so I thought they were being handled simultaneously.
« Reply #1776 on: Thu, 30 August 2018, 14:35:05 »
I have now contacted everyone on my list of people who reported defects and wanted replacements.  I wrote asking to confirm the replacement parts as well as to get updated shipping address information.  If for some reason you were not on my list and have not been contacted (and did not report a defect earlier), please send me a message ASAP!
  • its just plastic
« Reply #1777 on: Thu, 30 August 2018, 23:01:05 »
thank you photo for following up on this
Offline att1cus
« Reply #1778 on: Mon, 10 September 2018, 18:19:00 »
Hey everyone - I have the blue colored case in perfect condition, but it wasnt quite a match to what i had in mind.
Looking to do a case or full board swap with anyone who might have a grey or silver Mira SE.
Offline lishi
  • Luxury Taste Buds
    • Personal Website
« Reply #1779 on: Wed, 12 September 2018, 16:56:22 »
Having issues with PCB too :/ sent pm to ninja/photo
All the kustom 60s
Offline idlemao
« Reply #1780 on: Wed, 12 September 2018, 18:49:11 »
Anyone have an alps plate and pcb they'd be able to part with?
« Reply #1781 on: Wed, 12 September 2018, 20:44:24 »
you'd have better luck on /r/mm since it's a jane plate board
Offline mason
  • have fun with her, ryan
« Reply #1782 on: Thu, 13 September 2018, 09:07:14 »
My first and last custom  :thumb:
203462-0
Offline Waateva
« Reply #1783 on: Thu, 13 September 2018, 09:47:32 »
Looks great, love the OG cable!
Offline techmattr
« Reply #1784 on: Fri, 14 September 2018, 13:14:42 »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1785 on: Fri, 14 September 2018, 13:17:40 »
Classy. Love how clean that looks.
Offline techmattr
« Reply #1786 on: Fri, 14 September 2018, 13:22:29 »
Thanks. Yeah I love the way this one turned out. I've been a bit strapped for cash recently though so I've been making a list of things to sell... this keeps making it to the list but every time I look at it... I don't want to sell it  :confused:
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1787 on: Fri, 14 September 2018, 13:24:58 »
I would say it's a keeper :cool:
Offline techmattr
« Reply #1788 on: Fri, 14 September 2018, 13:33:08 »
Yeah I have a numbered one in black, and a lunar grey one... I'm taking the black one to my grave. Not quite as attached to the other 2 :D
« Reply #1789 on: Sat, 15 September 2018, 01:10:06 »
send them to me
Offline sunnywala
« Reply #1790 on: Sun, 14 October 2018, 18:28:22 »
Any updates on replacement parts or number pad progression?
« Reply #1791 on: Sun, 14 October 2018, 23:46:53 »
I don't know if there's going to be a number pad.  Still waiting to hear back on when the replacement parts are finished.  Last I heard they were going through anodizing.  j
I don't have you noted for any replacement parts.
Offline Okonomiyaki#2832
  • Eating Okonomiyaki
« Reply #1792 on: Mon, 15 October 2018, 03:25:01 »
PM you
Offline Hayte
« Reply #1793 on: Mon, 15 October 2018, 07:41:14 »
God, I wish this keeb had a round 2...
Offline sunnywala
« Reply #1794 on: Mon, 15 October 2018, 08:46:48 »
Eason confirmed that a replacement SS Plate would be sent to me. I sent you a PM on Mon, 15 January 2018, 20:16:46 and you confirmed that it would.
« Reply #1795 on: Mon, 15 October 2018, 15:18:05 »
I've just had to remove my previous message as I've figured out what happened.  Your order is under different username (reddit), so I didn't remember a PM directly from this account. Yes we do have a replacement SS plate listed for that order.
(To be pedantic, I didn't confirm that you'd get a replacement, I said that zzyjayfree was in contact with EVE about replacement parts and that we were told we would get replacement parts.  Of course I very much hope everyone will receive the parts they need ASAP, but I personally have no control over the manufacturer and can't actually confirm that you will get anything.)
« Last Edit: Mon, 15 October 2018, 16:03:31 by Photoelectric »
Offline sunnywala
« Reply #1796 on: Mon, 15 October 2018, 16:17:28 »
Sounds good, thanks for clearing it up. So to confirm, at this point there is no updates or time frame from zjayfree or EVE?
« Reply #1797 on: Mon, 15 October 2018, 16:21:14 »
I just got these pictures from EVE:
205469-0 205471-1
I believe the parts are slowly but surely getting made.  I don't have any word on when they will actually be shipped.  As soon as I know, I will give an update.
(P.S.: tops are made together with bottoms for color consistency).
« Reply #1798 on: Sun, 06 January 2019, 19:02:04 »
Got shipping invoice for remade parts. Finally.
Offline Pemdas
« Reply #1799 on: Sun, 06 January 2019, 23:08:42 »
Got my invoice for parts as well! Paid and thanks can't wait to get them  :thumb:
