Author Topic: [GB] MIRA SE - Custom 80% Keyboard (CLOSED)  (Read 3188125 times)
0 Members and 18 Guests are viewing this topic.
Offline Okonomiyaki#2832
  • Eating Okonomiyaki
Re: [GB] MIRA SE - Custom 80% Keyboard (CLOSED)
« Reply #1800 on: Sun, 06 January 2019, 23:26:03 »
Almost everyone had paid up except one. I am proceeding to follow through my local shipping team with Photoelectric in the loop, since details contains everyone addresses.
Things are packed. Pending customer account creation and payment for the freight person.
https://imgur.com/a/wHxx9IY
« Last Edit: Sun, 06 January 2019, 23:28:20 by Mikiberry »
« Reply #1801 on: Mon, 07 January 2019, 02:54:39 »
Please ship to the address I used for the PayPal invoice if it's different from what you have on file. Photoe will know why.
« Reply #1802 on: Mon, 07 January 2019, 04:02:41 »
Will confirm address for all again before i send.
« Reply #1803 on: Mon, 07 January 2019, 09:25:37 »
I have sent the agent my detail to create a corporate account.
For all moon and mira RMA, I will reconfirm address individually before registering airwaybill.
Offline HerrGartenzwerg
« Reply #1804 on: Sat, 12 January 2019, 10:35:46 »
I just got around to finishing my board.. it took some time...
Can someone help me out, is there a way to dim the Key-LEDs?
The "LED Mode" buttons in JigOn just cicle on/off/breathing for me.
« Reply #1805 on: Sat, 12 January 2019, 11:57:08 »
Update the firmware. There's a brightness setting, but it only works if the version on the PCB matches the client version.
« Reply #1806 on: Sat, 12 January 2019, 21:34:24 »
Guy is coming to pick up the stuff from my place on Monday and ship it. FYI.
Offline Pemdas
« Reply #1807 on: Sat, 19 January 2019, 04:19:45 »
Got the replacement weight in today! Thanks a ton! It is much appreciated :thumb:
Picture of old weight for reference
Offline Captainbuttmonkey
« Reply #1808 on: Sat, 19 January 2019, 11:43:58 »
Anything ever happen with the metal gasket on this? To replace the diffuser?
« Reply #1809 on: Sat, 19 January 2019, 14:42:01 »
Not that I've heard or seen
Offline Etherealsound
« Reply #1810 on: Mon, 21 January 2019, 18:48:28 »
Does anyone know if the plate and pcbs available on kin's txkeyboards are compatible with this board?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1811 on: Mon, 21 January 2019, 19:15:18 »
Plate no, PCB yes
« Reply #1812 on: Mon, 21 January 2019, 19:21:22 »
Plate no, PCB yes
Is there anywhere I can get replacement plates for the board?
« Reply #1813 on: Mon, 21 January 2019, 19:50:22 »
Plate no, PCB yes
it's a jane/27/orion plate, so it's not especially hard
Offline wholypantalones
  • text and icon mods plz.
« Reply #1814 on: Mon, 21 January 2019, 20:33:12 »
Plate no, PCB yes
Mechmarket.
« Last Edit: Tue, 22 January 2019, 06:41:03 by wholypantalones »
« Reply #1815 on: Mon, 21 January 2019, 21:46:13 »
Mainly looking for a polycarb/acrylic plate/halfplate if possible.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1816 on: Tue, 22 January 2019, 01:54:37 »
No such half plates that I've seen. I'd suggest looking for someone with the files and making the changes for a DIY project. Or could always get a full plate and snip it with some flush cutters.
« Reply #1817 on: Tue, 22 January 2019, 06:02:05 »
Ah shame, ty
« Reply #1818 on: Tue, 22 January 2019, 16:12:40 »
got my replacement weight today
thanks much
i should prolly take it out of the box huh
Offline crusader_alex
« Reply #1819 on: Sun, 05 May 2019, 12:53:03 »
Anyone here got plate files? Also will the SE plates fit the mira proto?
« Reply #1820 on: Sun, 05 May 2019, 15:21:01 »
dunno about the proto but the plate file is the same as jane v1/mech27/orion
i have the mech27 file so just add me on discord (puddsy#3434) and i'll send it to you
« Last Edit: Sun, 05 May 2019, 15:23:03 by Puddsy »
Offline PoochZag
« Reply #1821 on: Mon, 20 May 2019, 07:51:56 »
Does anyone know how much clearance there is between the switch pins and the bottom of the case?
I am thinking about using some thin washers between the plate and top case to try and lower the plate a little bit and make it a little more "high profile" as the bottom of keycaps sit a tad bit higher than normal (still looks great of course)
TX-CP, TX60, Campine Mk. III, Mira SE
« Reply #1822 on: Mon, 20 May 2019, 11:37:27 »
idk try it and see what happens
Offline gabbbe
« Reply #1823 on: Thu, 23 January 2020, 00:03:23 »
It's time for another run, no?
Offline loud_asian
« Reply #1824 on: Fri, 24 January 2020, 04:17:44 »
« Reply #1825 on: Fri, 24 January 2020, 15:25:05 »
no chance
Offline Photoelectric
« Reply #1826 on: Wed, 29 January 2020, 15:18:29 »
No other runs, sorry.  This group buy was long in the making, long in the fulfilling, and overall is a finished book.
Offline tonyjones
  • I like big butts and I cannot lie.
« Reply #1827 on: Sun, 31 May 2020, 10:23:34 »
Does anybody know how to fix a Leeku PCB TX87 that is not recognized by windows... I get the  "Unknown USB Device (Descriptor Request Failed)" message in device manager, the rgb underglow lights up and the per key rgb lights up when i hit the keys but windows doesn't recognize it.
Offline clik_clak
« Reply #1828 on: Sun, 31 May 2020, 10:47:41 »
How to fix a crappy Leeku PCB 101:
Buy a Hiney PCB
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1829 on: Sun, 31 May 2020, 12:09:35 »
Buy a Hiney PCB
Lol, truth.
If you haven't tried, try a different cable and/or different USB port. It's likely the connection isn't good.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #1830 on: Sun, 31 May 2020, 13:16:39 »
You can get both a new PCB and plate for the Mira from Hiney's store, so unless you're really attached to the switches you don't even need to bother with de-soldering the old one.
QMK + Via is a pretty sweet upgrade.
« Reply #1831 on: Sun, 31 May 2020, 17:55:10 »
agree with above
tx87s were the best we had at the time but now that we have a via compatible 87 PCB, if your leeku one dies it's more worth it to rebuild with a hiney than it is to fix the old one
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #1832 on: Mon, 01 June 2020, 17:13:59 »
I have an extra PCB from the mira se group buy if someone needs the original. I too agree that hineybush built/builds a way better pcb.
-Dana
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #1833 on: Sun, 27 November 2022, 01:37:22 »
MIRA SE #5 has finally been dusted off and built. Too lazy to order new upgraded parts so I went in raw with the original build.
67g Rosélio® Silent Linear switches. Krytox GPL205 lube on these cursed stabs. GMK Modern Dolch 2 Mist keycaps because I had it unopened. SS plate (the biggest pain in the ass I've ever worked with, wish I could go back and order brass.)
Thank you again Ninjadoc, Photoelectric, et al for seeing this through :thumb:
Sorry for the necrobump, I don't see much about the MIRA anywhere
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline techmattr
« Reply #1834 on: Sat, 14 January 2023, 23:09:15 »
I don't come around the mkb community much anymore so when I saw this thread it made me smile. I just looked at my Mira #34 the other day and thought about building it. Then put it back on the shelf. Maybe someday. Or maybe I'll just sell it.  :-X
« Reply #1835 on: Mon, 23 January 2023, 21:47:20 »
bad pics but mira 34 is built now
zealios v1 redux/zeal stabs/h87a
sent techmattr a DM offering to buy it basically as soon as i saw him post, got it in the mail day before yesterday and built it this evening
34 is my favorite number, excited to have this board
still have mira 29, it's been my daily for at least 4 years
if anyone has a pink mira (ideally numbered) they're not attached to let me know
« Last Edit: Mon, 23 January 2023, 21:56:58 by Puddsy »
Offline treeleaf64
    • treeleaf64
« Reply #1836 on: Wed, 25 January 2023, 15:10:45 »
Hello puddsy and mira Keyboard
That one is your favorite
Everyone must pay the cat tax
Offline techmattr
« Reply #1837 on: Wed, 25 January 2023, 23:20:12 »
Awesome! Glad to see it finally built :D
I had been sitting on it way too long.
Offline pr0ximity
« Reply #1838 on: Thu, 26 January 2023, 10:28:06 »
It warms my heart to see this built.
Still lowkey lust after the lunar grey color from this GB. Really awesome color.
Offline mason
  • have fun with her, ryan
« Reply #1839 on: Sat, 08 April 2023, 15:11:00 »
Changed out the keycaps to Hammer CRP R5 and figured I would log into the forum where it all started. Before this I had GMK Triumph Adler on since 2018.. time flies
298086-0
Offline IonutZ
  • Stay awhile and listen
    • SC
« Reply #1840 on: Mon, 02 December 2024, 09:48:28 »
Sorry to revive this... but recently had a static short and killed the lighting controller on the MIRA. All my LEDs are scrambled and no longer responding. Was wondering if anyone had an extra PCB willing to sell...
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1841 on: Mon, 02 December 2024, 09:54:37 »
You can probably get an h87a or any similar PCB. Something like this.
Offline IonutZ
    • SC
« Reply #1842 on: Mon, 02 December 2024, 10:58:31 »
Amazing! Since you're in the know, what other PCBs of the same form come to mind?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1843 on: Mon, 02 December 2024, 11:46:22 »
You can just look up "h87a compatible" and results should come up.
https://cafege.com.au/products/jels-h87a-h88a-pcb Something like this can work too.
