Author Topic: [GB] MIRA SE - Custom 80% Keyboard (CLOSED)  (Read 3125642 times)
Offline roostrc0gburn
  • its just plastic
Re: [GB] MIRA SE - Custom 80% Keyboard (SHIPPING + POLL on extra parts)
« Reply #1600 on: Mon, 12 February 2018, 14:54:41 »
ninja, thanks for the update. if you still need a measurement for the diffuser, hmu. i can send you some caliper measurements when i get home later.
looking forward to seeing the main gb finalized, as i will not be able to resolve the manufacturer defects with my kit until all other orders have been fulfilled (per eason)
really excited to see the spacer, brass plate, and numpad moving forward!
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
« Reply #1601 on: Mon, 12 February 2018, 16:53:47 »
What about an ISO alps plate? Or is that impossible? :(
Offline Pemdas
« Reply #1602 on: Tue, 13 February 2018, 01:31:26 »
I'm not in the group yet, I just blue myself. by thosepeoples, on Flickr
Tealios by thosepeoples, on Flickr
My Zeal order shipped so finally got to try Tealios and finish my build! Well almost, still need to get some bumpers/feet for the bottom but my ghetto bubblewrap mat is serving me well.
Board feels great! Caps are really discolored... maybe just dirty should give them a wash :p
Some issues I had.
My weight has some lines on it, It's inside the board so it's not really that important but I'd love to get it shiny. How would I go about polishing this?
All my screw holes on the top case part have a bit of rust on them. Is this something I should be concerned about?
Last thing is one of my screws wasn't threaded :confused: I had an extra screw so it's not a problem, but never saw this problem before ha.
« Reply #1603 on: Tue, 13 February 2018, 02:36:58 »
ohai, it's sifo's LZ-S, but also not
i like this board a lot
what blank set is that?
Some issues I had.
machine marks, can't really do anything about those on stainless steel since it's so hard
i also have this issue on my SS weight
also have this, nothing to worry about
what in the ****
never seen that before, kinda neat
Offline user 18
Re: ATTENTION - a little bit of everything
« Reply #1604 on: Tue, 13 February 2018, 16:45:36 »
Spacer - I’m making it with a cut-out in the center to prevent the weight from being scratched and to reduce the weight of it. A solid sheet of stainless steel is heavy. I know people have mentioned aluminum and brass but a certain nmber need to be made to reduce cost.  Also can someone with a micrometer measure the thickness of the thin rim and send it to me?
i think i can borrow a caliper in the next week
I can do a measurement late next week as well, if that would be helpful.
Avatar by ashdenej
Offline Unforgivable
« Reply #1605 on: Tue, 13 February 2018, 16:57:10 »
Just got my Mira today. The blue is really great. I regret not getting a Winkeyless top though.
Sadly mine too was plagued with those weird dark lines around the logo.
And the screw holes look rusted, any confirmation that it won’t be an issue? :(
Do I contact Ninja or Pho about the dark marks?
Edit: Just noticed my Acrylic is missing a piece in the front too, or wasn’t cut correctly. :(
Can’t wait to get my 2x PCB’s from Ninja to eventually build this puppy up. Really happy I went with blue.
Edit: Just noticed mu Acrylic is missing a piece in the front too, or wasn’t cut correctly. :(
« Last Edit: Fri, 02 March 2018, 20:14:41 by Unforgivable »
Offline Photoelectric
« Reply #1606 on: Tue, 13 February 2018, 21:04:13 »
Yes, please document everything with the best photos you can take and send me a PM with a detailed list of defects.
Offline Pemdas
« Reply #1607 on: Tue, 13 February 2018, 21:18:54 »
I got the Mira S.E. (Sifo's Edition) :p
Keyset is Imsto blue blanks, and thanks for the ease of mind, was a bit worried about the rust.
« Reply #1608 on: Tue, 13 February 2018, 21:25:06 »
ah, i figured that's what set it was
good color
« Reply #1609 on: Tue, 13 February 2018, 23:30:34 »
Sifo's LZ is exactly what I thought of when I saw your pictures.  Good "Sifo's Edition"  :)) :)) :))
Offline iArson
« Reply #1610 on: Fri, 16 February 2018, 00:47:57 »
Mira SE by iArson, on Flickr
« Reply #1611 on: Sun, 18 February 2018, 15:30:04 »
Nice!
@Ninjadoc: I was at a mechanical keyboard meetup today and while it was good fun, I‘ve returned with a little dent on it, which buggs me a little bit. Those things can happen at a meetup, but it’s still a bit unfortunate. It‘s on the backside and thus not visible during regular usage, but I know it‘s there...
Do you carry bottom replacements? If you do, please let me know.
« Reply #1612 on: Sun, 18 February 2018, 18:17:56 »
Nice!
Let me add this to the list of defective parts that need to be replaced.  It will most likely be a replacement for a fee in this case (to be determined what that would be).
Offline Etherealsound
« Reply #1613 on: Mon, 19 February 2018, 16:08:38 »
Kinda crossing my fingers here but there wouldn't happen to be any spare kits leftover from the gb?
« Reply #1614 on: Mon, 19 February 2018, 17:07:26 »
no
Offline ika
« Reply #1615 on: Mon, 19 February 2018, 17:33:31 »
I also received a board without PCBs, so I will be needing two of them. I didn't respond to his PM so I thought my case would be delayed until zzjayfree was able to acquire PCBs and shipped together but I guess not? I'm not in any rush so no need for special treatment, just putting this out there.
Quick thoughts, the blue is a little lighter than I expected but should look great with certain keysets. Anodizing is ok overall, quite a few minor darkened or splotchy areas, but this is fine. There is only one really noticeable splotcch and it's filling about 70% of the small "o" in the logo so it's fine as well. Wondering what the best way to clean this thing and maintain a uniform texture would be - probably just water and a clean cloth?
« Last Edit: Mon, 19 February 2018, 17:38:47 by ika »
« Reply #1616 on: Mon, 19 February 2018, 19:04:00 »
Extra/missing PCBs that were needed to complete all the orders will be coming from a different source, so the last 8 MIRA kits were shipped from the manufacturer without the PCBs.  The PM you did not respond to was probably a notification that you'd be getting your kit shipped without the PCB.  I think the aforementioned PCBs have recently arrived, so they will be shipped to those missing them shortly.
« Last Edit: Mon, 19 February 2018, 19:07:01 by Photoelectric »
« Reply #1617 on: Mon, 19 February 2018, 23:44:06 »
Nice!
I‘m fine with that. Do you need pictures of the dent? I could provide that in the evening, given that I manage to get out of Uni at a reasonable time.
Do you by any chance know how good the ano matches the original bottom part?
« Reply #1618 on: Tue, 20 February 2018, 11:36:18 »
Since the dent was not caused before you got the part, it's not really relevant where it is or what size it is, if you're asking for a replacement. It's up to you if you'll want to pay for a replacement top and its shipping cost.  I don't have an answer about what that would be yet.  I have no idea about your last question as we don't share the same color.  Typically there can be some slight variation in top and bottom colors among many kits (like TX84/87, red TGR Jane, etc.), it just varies on how *noticeable* this difference is.  It helps to have kits with acrylic spacers so if there is any slight difference in anodizing, the two differing parts won't be right against each other.
« Last Edit: Tue, 20 February 2018, 11:39:36 by Photoelectric »
Offline Dreamre
    • kbdlife
« Reply #1619 on: Tue, 20 February 2018, 15:32:29 »
Nice!
Sorry to hear this. How did the damage happen?
« Reply #1620 on: Tue, 20 February 2018, 16:46:16 »
Without a price, I cannot say if I really want one or not. So if you could please give me an exact quote once you can figure that out, I‘ll consider it. I‘m not in a rush, so take your time.
Alright, I‘ll keep that in mind with the acrylic spacer.
Nice!
No clue, really. I didn’t guard my MIRA the whole event, so it could‘ve happened at any point. I just noticed it when we all packed our stuff and it was pretty disappointing to see, to be honest. There‘s always a small risk, but because my board is affected, this‘ll make me think twice before attending another meetup. Don‘t get me wrong, the meetup itself was super cool and I really enjoyed the Sunday afternoon, but the dent is one thing, that I wouldn‘t miss... :D
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #1621 on: Tue, 20 February 2018, 18:56:46 »
I'd definitely be interested in another round, hope you'll consider it despite the obstacles of the first one :thumb:
Offline DJ Shoko
« Reply #1622 on: Wed, 21 February 2018, 03:11:13 »
Certainly would also be interested in a Round 2 for the Mira actually.
Offline ninjadoc
« Reply #1623 on: Wed, 21 February 2018, 22:53:01 »
Currently I'm not planning on a round 2 in the foreseeable future. I do plan on a numpad. After that we will see.
Offline p_blaze
« Reply #1624 on: Wed, 21 February 2018, 23:02:57 »
I remember you mentioning a 75% in the works, will that happen after the numpad?
« Reply #1625 on: Thu, 22 February 2018, 11:07:19 »
i don't remember seeing that at all
Offline p_blaze
« Reply #1626 on: Thu, 22 February 2018, 11:10:15 »
Mistype, it was a 65%
Offline techmattr
« Reply #1627 on: Wed, 28 February 2018, 13:28:07 »
Got my missing PCB in the mail today so that completes my order  :D
Thanks again for all the great work by everyone involved.
Do I need Plate Mount, PCB Mount or Screw In stabs?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1628 on: Wed, 28 February 2018, 13:30:02 »
PCB mount or screw in.
Sent from my mobile using Tapatalk
Offline techmattr
« Reply #1629 on: Wed, 28 February 2018, 13:31:43 »
Thanks for the speedy reply. That's what I though but wanted to double check so I could order some before I went home today.
Offline iArson
« Reply #1630 on: Wed, 28 February 2018, 14:51:10 »
Oh missing parts are starting to ship?
« Reply #1631 on: Wed, 28 February 2018, 15:51:32 »
some orders had PCBs ship later due to some technicalities
iirc you got a PCB with yours, but i've been wrong before
Offline iArson
« Reply #1632 on: Wed, 28 February 2018, 15:54:10 »
I'm just waiting on my brass weight and my stabs.
« Reply #1633 on: Wed, 28 February 2018, 15:55:16 »
ah, alright
i got nothing then
Offline henz
  • What?
« Reply #1634 on: Fri, 02 March 2018, 02:31:02 »
i cant decide what kind of switches to put in mine. i have alot of vintage blacks and springs at home, but what i love is hiroses, and also have an urge to try silent silvers. HALP
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #1635 on: Fri, 02 March 2018, 09:02:20 »
Hiroses, leggo meme board
« Reply #1636 on: Fri, 02 March 2018, 09:57:45 »
Clearly the correct answer is MX Clears (stock spring).
« Reply #1637 on: Fri, 02 March 2018, 12:31:14 »
mx black spring
but yeah
« Reply #1638 on: Fri, 02 March 2018, 12:46:26 »
mx black spring
That would be a downgrade, as the MX Clear spring is special in its characteristics, giving that extra cushioned feeling if bottoming out.  It's a big part of why I love stock MX Clears. (MX Blacks and their spring are nice too, but just not the same).
Offline Captainbuttmonkey
« Reply #1639 on: Fri, 02 March 2018, 12:48:10 »
mx black spring
B-b-but what about the scratchiness?
« Reply #1640 on: Fri, 02 March 2018, 12:52:22 »
What scratchiness?  If you mean that some stems and housings are scratchy, it's unfortunately true.  That's why hunting for smoother switches and also lubricating helps a lot.  I usually stick with old stock Cherry switches for MX Black, Brown, and Clears (but prefer newer MX Blues, as vintage MX Blues just sound broken to me).  Does not need to be "vintage" with large logo--some older batches are just very smooth either through some use or combination with better manufacturing tolerances for those batches.
« Reply #1641 on: Fri, 02 March 2018, 12:58:11 »
Nah I was just being a bit flippant. Personally I don't really rate most cherry switches. Having said that the new tooling made silent blacks one of my favourite switches and I would imagine that will carry over to most of the others produced from recently onwards. I'll still think browns are awful though regardless =P
« Reply #1642 on: Fri, 02 March 2018, 13:09:23 »
mx black spring
strong meme
Offline eksuen
  • Ambassador of explosions.
« Reply #1643 on: Fri, 02 March 2018, 13:10:22 »
My problem with stock Browns is that they are too light. Swapping in a heavier spring improves their feel significantly, IMO.
« Reply #1644 on: Fri, 02 March 2018, 13:17:20 »
I personally think stock MX Browns have their charm, though for some odd reason I find them by far the best with thin ABS OEM profile keycaps, especially those with that "soft touch" rubberized coating.  Recently I got a sampler of Kailh switches from NovelKeys, and I think everyone who hates Cherry MX Browns should give Kailh Browns (regular and BOX Browns) a serious consideration.  The bump is strong and quick, which is the complaint about Cherry Browns.  But I actually like the "long bump" of Cherry MX Clears and Cherry MX Browns -- it's just different and to me has nice tactility, combined with long travel distance.  I feel like I'm getting a relaxing finger massage typing on MX Browns with OEM profile keycaps, trying to not bottom out.  (I don't have any of those anymore, but I used to have a couple of keyboards like that, and sometimes I still try them on store displays).
« Reply #1645 on: Fri, 02 March 2018, 13:35:07 »
Ah that's interesting, I'm ok with the weight, it just doesn't feel like there is enough of a bump for me. Like a switch that is in between a tactile and a linear or something. I've been trying to decide what switches to use for my M65 and that gives me some food for thought. I've only heard great things about the new kailh box/non box switches but there are so many and a lot of them are clicky which I'm not sure I'm after. Maybe I should have a look at the browns or burnt orange? (I think there was something a bit off with the first burnt orange batch but it has been fixed now right?) Also, I assume they can be opened and lubed the same as a regular mx/clone, just a different mechanism for opening and closing? Are the particularly pingy at all or loud on the upstroke? Even if they are I find lube usually minimises this from my experience.
« Reply #1646 on: Fri, 02 March 2018, 16:41:18 »
who are you and what have you done with photoelectric
Offline hervuli
« Reply #1647 on: Fri, 02 March 2018, 16:41:41 »
Potentially stupid question - just built my Mira, first time I've had a board with a Leeku PCB and I've having trouble programming it. I can flash the basic firmware (version L3_171209) just fine it seems, but JigOn gives me a "connection fail" error every time I try to connect to set up my keymap. If I understand correctly, there's no bootloader mode right? What am I missing?
Tried using several different USB cables and ports as some folks have said to do; same outcome every time.
JD40v2 MX Grey | HHKB BKE Heavy | E6-V2 78g Tealios | ZealX60 72g MX Zilent | TGR 910 RE 78g MX Zilent | Singa Vintage MX Black | Octagon V2 MX Grey | Orion V2 MX Clear | Novatouch BKE Extreme
Offline eksuen
« Reply #1648 on: Fri, 02 March 2018, 17:07:38 »
Putting in a heavier spring makes the bump a little more pronounced. I am currently in the process of swapping 68g springs into MX/Gateron Browns.
« Reply #1649 on: Fri, 02 March 2018, 19:11:47 »
I’m confused...  This has been my opinion about Cherry switches for years.  Nothing new.
I agree that there are far too many MX-compatible switches now to make an informed decision.  For Kailh, I recommend a switch tester pack like the one from novelkeys.  There are still a bunch of other brands beyond those as well, for which you can also get samples.  I decided I’m fine not knowing how every switch compares to every other switch as long as every one of my boards is different enough from others and is enjoyable to type on (and I only keep a handful of keyboards).
