Author Topic: Lubing your Topre with the wrong lube melts your dome sheet (?)  (Read 4390 times)
Offline menuhin
« on: Thu, 02 February 2017, 12:09:49 »
I'm planning to further improve the experience of my HHKB Pro 2, but then I ran into a post about lubricant deforming the rubber dome sheet in a 660C. I believe they might have used some vaseline / petroleum jelly.
Will the usual 105/205 mixture have similar reaction for the long run?
http://www.kbdmania.net/xe/best_article/9204139#100
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline exitfire401
  • The Force is Re/\l
Re: Lubing your Topre with the wrong lube melts your dome sheet (?)
« Reply #1 on: Thu, 02 February 2017, 13:04:33 »
I've been using 105/205 on my Topre boards since I started collecting and have never seen anything like that. They had to have been using something with a petroleum base to get that effect.
Offline Rayoui
« Reply #2 on: Thu, 02 February 2017, 17:43:21 »
Krytox is made of fluorocarbon compounds and is inert. It won't react with anything inside your keyboard.  :thumb:
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
Offline zslane
« Reply #3 on: Thu, 02 February 2017, 17:48:31 »
Krytox 205 ftw.
« Reply #4 on: Thu, 02 February 2017, 18:19:07 »
Looks like white lithium grease or similar
Only need to make the mistake of putting that on plastic once to learn a very valuable lesson.
Offline yuppie
« Reply #5 on: Sun, 05 February 2017, 03:03:08 »
Which lube is best lube for topre? I'd like to learn more about lubing and I'm also looking for some landing pads/silence mods.
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline E3E
« Reply #6 on: Sun, 05 February 2017, 13:05:26 »
I think the dome sheet is silicone, so just be sure not to use any silicone-based lubes on a Topre board.
This also makes me think about what I've read about restoring plasticizers in old brittle plastic/rubber, and soaking or keeping the part in a sealed bag with silicone oil is supposed to help restore them (it has helped for some old boards I've restored). The other way that I've read about is putting the plastic/rubber in warm or hot water for a while. I wonder if this would work to soften Topre domes that have stiffened from age.
Yeah, this sounds about right.  :-X
« Last Edit: Sun, 05 February 2017, 13:10:04 by E3E »
Offline q1w2e3r4t5z
« Reply #7 on: Sun, 05 February 2017, 13:37:21 »
I am using "Finish Line Extreme Fluoro" and it works like a charme
