Author Topic: Do matias clickies actuate and bottom out the same as Alps whites?  (Read 2463 times)
Offline bluejeans
« on: Thu, 02 February 2017, 23:15:45 »
Got a keyboard with alps whites and hoping I don't need to get a matias clicky, I was wondering if the alps requires 60g to actuate and only 30g to bottom out, like the matias?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Do matias clickies actuate and bottom out the same as Alps whites?
« Reply #1 on: Fri, 03 February 2017, 06:12:54 »
No, Alps switches have completely different travel profiles. 70 gf, 1.5 mm to actuate.
Offline bluejeans
« Reply #2 on: Fri, 03 February 2017, 06:17:01 »
I thought they were meant to be replacements for the alps?
The click switch (part no PG155B02) is a clone of the Alps SKBM White switch and is intended as a direct replacement for it.
https://deskthority.net/wiki/Matias_switch#Click
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Fri, 03 February 2017, 08:04:11 »
White Alps =/= SKBM white. Also, Matias changed quite a few things themselves.
Offline bluejeans
« Reply #4 on: Fri, 03 February 2017, 08:23:56 »
What are the characteristics of SKBM whites?
Offline chyros
  • a.k.a. Thomas
« Reply #5 on: Fri, 03 February 2017, 09:24:08 »
https://deskthority.net/w/images/6/68/Forward_Electronics_--_spec_--_SKBMFA.pdf
Offline bluejeans
« Reply #6 on: Fri, 03 February 2017, 10:22:42 »
Is it conceivable that I wouldn't even notice the matias having 60g actuation and 30 to bottom out?
