Author Topic: Did someone just blow up my alps keyboard?  (Read 1703 times)
Offline bluejeans
« on: Mon, 06 February 2017, 04:22:12 »
Got someone to put a ps/2 plug on my DIN alps white, even though he was following instructions (use a multimeter because the wire colors don't necessarily match) he blew up his usb and ps2 ports.  How likely is it that the keyboard will still work if I get an adapter locally?  He was obviously not willing to use his (not for sale) adapter on another of his computers.
Offline happylacquer
  • BS Apologist
    • BHOBuds
Re: Did someone just blow up my alps keyboard?
« Reply #1 on: Mon, 06 February 2017, 04:25:51 »
Even if the board is shot it's not like any of the switches are going to be unusable. Worst case you got a dead pcb.... they are replacable, and there are pcb's for taking alps too.
Offline bluejeans
« Reply #2 on: Mon, 06 February 2017, 04:28:26 »
I might not worry if that's the case, alps whites feel very very stiff and with a very low-pitched click, although that might have just been the keys.  This is the model in case you're curious: https://deskthority.net/wiki/NTC_KB-6251
« Reply #3 on: Mon, 06 February 2017, 07:12:16 »
People often get confused with mirror images in plugs and sockets. Remember that "left" on the plug is "right" on the socket.
If you got it backwards and swapped current and ground, you can do damage.
- D Trump 2026-10-24
