Author Topic: [IC] GMK Ocean Dolch (GB is closed)  (Read 49396 times)
Offline hoq
    • wolfmark.work
« on: Thu, 09 February 2017, 23:54:01 »
GB Thread: https://geekhack.org/index.php?topic=87773.0
Hi, Guys! I'd like to show you my new idea about a GMK keyset, I call it Ocean Dolch.
     I applied cyan color (GMK color code TU2) on all the keycaps, and the keycaps color are contrary to the classic dolch color. Hope you like it!
GB is live on :
https://en.zfrontier.com/collections/keysets/products/gmk-ocean-dolch
Keyboards layout  support:
・ANSI  60/87/104
・Cherry 1800 series
・WKL
・ ISO (4 keys)
・FC660M
・68 customized keyboard, split Shift( 1.75u Shift, 1u Fn)
・HHKB style customized keyboard
・75% customized keyboard.
・96 customized keyboard.
Some renders for your reference:
Mod Edit: added link to GB thread.
« Last Edit: Tue, 20 June 2017, 23:56:43 by infiniti »
Offline hoq
    • wolfmark.work
Re: [IC] GMK Ocean Dolch
« Reply #1 on: Thu, 09 February 2017, 23:54:36 »
reserved
Offline honeynugget
    • /u/honeynugget on reddit
« Reply #2 on: Thu, 09 February 2017, 23:55:25 »
looks good, would buy!
Offline fublamchu
  • ㅋㅋㅋ
« Reply #3 on: Fri, 10 February 2017, 00:05:16 »
looks pretty good, might get in on it if it comes to fruition
LZ-CE VBlacks
910-CE
Offline oatmicro
« Reply #4 on: Fri, 10 February 2017, 00:30:05 »
Awww, This set looks good, I like it!
Offline ArchDill
« Reply #5 on: Fri, 10 February 2017, 00:34:55 »
I like this! Would use the Alphas with Skeletor Mods!
Offline Sensorium
« Reply #6 on: Fri, 10 February 2017, 00:39:30 »
Dare I say this looks better than Sky Dolch? Such a small change actually makes a pretty big difference. Good job!
Offline -musubi
  • Spam rice 'n eggs
« Reply #7 on: Fri, 10 February 2017, 00:53:53 »
I'm always a fan of the dark gray N9 alphas, looks nice!
Offline Weiss
  • Impulse buying at its finest
« Reply #8 on: Fri, 10 February 2017, 01:30:24 »
Looks really nice, would probably be interested!  :thumb:
Offline FioraCorp
  • AKA ABC
    • My insta
« Reply #9 on: Fri, 10 February 2017, 01:47:34 »
ikr this takes what I like about sky dolch and photo studio and combines it...
Instant win for me.
Offline LXuelin
« Reply #10 on: Fri, 10 February 2017, 03:41:09 »
I will buy this to ues for decorate my fc660m . :)
Offline hoq
    • wolfmark.work
« Reply #11 on: Fri, 10 February 2017, 04:10:20 »
Yes, this set can be used for this keyboard, and also for some main stream customized keyboards.  :))
Offline bkw1209
« Reply #12 on: Fri, 10 February 2017, 04:42:42 »
I m interested in
Offline wishful_cynic
« Reply #13 on: Fri, 10 February 2017, 06:16:57 »
White legend on enter is gross tbh
Maybe go for cyan mods with dark gray to set it apart from Sky Dolch
Offline a_ak57
« Reply #14 on: Fri, 10 February 2017, 08:46:18 »
Looks nice, the inverted dolch is pretty spiffy.  Any chance you could add a 00 key?
Offline autobot
« Reply #15 on: Fri, 10 February 2017, 09:25:42 »
I love it!
I'm definitely interested in buying this!
Offline hoq
    • wolfmark.work
« Reply #16 on: Fri, 10 February 2017, 10:00:04 »
I tried to put the CC color on the cyan keycaps. the contast look very lower, it not very good I think.
Offline autobot
Re: [IC] GMK Ocean Dolch (About to launch on en.zfrontier.com)
« Reply #17 on: Fri, 10 February 2017, 10:24:36 »
I think the dark grey would be quite readable, perhaps better than the white.
I have Sky Dolch accent w/ dark grey text, and is very readable.
See below (not my board, but another member's)
Offline Asbrodeus
« Reply #18 on: Fri, 10 February 2017, 10:37:10 »
I agree I think I'd like it more without the white legends. Looks great though would be in for one for sure.
Offline ArchDill
« Reply #19 on: Fri, 10 February 2017, 11:21:21 »
I was planning on cutting myself off after Terminal but this is nice.
Also, I already posted on Reddit but I agree on the accent. The white just doesn't fit.
Offline a_ak57
« Reply #20 on: Fri, 10 February 2017, 11:52:52 »
I also think that the grey would look better, especially given autobot's example of how bright the cyan actually is.
Offline h3xadat
« Reply #21 on: Fri, 10 February 2017, 12:37:24 »
I second that. +1 for grey legends.
Offline autobot
« Reply #22 on: Fri, 10 February 2017, 13:22:23 »
Color is quite a funny thing when applied to real world objects vs. pixels. When viewing on screen, you're not getting a true impression of what it will look like in person. The teal shown in the screen shot is way off. I recall on some projects at work, I would input color codes based on Pantone Color Codes in Adobe Illustrator's Pantone Books, and even then, the color is off because of the computer monitor. Sometimes the viewing angle of the monitor can make colors look odd. And then trying to print accurate colors from a printer...sigh... :(
Which is why I'd always recommend working from physical color samples if possible.   ;)
Does GMK issue color sample packs anyone can order? I recall seeing GMK keycaps in all of their available colors with the color codes side printed...
If so, does anybody know how much they cost?
Regardless, I'm loving your set! I'd love to participate in this group buy!
« Last Edit: Fri, 10 February 2017, 13:24:00 by autobot »
Offline GreyAmbience
  • I can stop when ever I want
« Reply #23 on: Fri, 10 February 2017, 16:31:50 »
Pretty dope. Would love to see it on a darker board
Sent from my microwave oven using alternating current
Offline Chaosti
  • Plastic Enthusiast
« Reply #24 on: Fri, 10 February 2017, 17:14:28 »
This looks pretty great! Missed out on Sky Dolch, probably going to pick this up as a very nice replacement.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #25 on: Fri, 10 February 2017, 17:59:53 »
Wow, I like it! Someone else mentioned this & I have to agree, it is surprising such a small change makes such a big difference. :eek: I'd vote for dark grey instead of white for the legends on the cyan caps but other than that it's a beautiful set IMHO. I got a set of GMK Sky Dolch coming from Originative's latest GB of it & I think there would be many awesome combos that could be made with this & that set. Hmm, might have to open the coffers for this one here. :thumb:
Offline inosint
« Reply #26 on: Fri, 10 February 2017, 18:24:32 »
I'm in and also agree it looks better without the white legends. You can never have too much dolch.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #27 on: Fri, 10 February 2017, 18:33:32 »
Is there any possibility to add the bare minimum keys to support ISO keyboards (just the bare minimum: ISO Enter, 1.25u Shift, 1x1u R4 <> key and 1x1u R3 |\ key)
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline Dyaems
« Reply #28 on: Fri, 10 February 2017, 20:35:25 »
cyan legends are always good, im in
   B.face X2
  65g Zealios
Offline shower_king
  • Pain is weakness leaving your body
« Reply #29 on: Fri, 10 February 2017, 21:10:11 »
i agree with ,to some extent , some persons' advice, white legend is not so good. Other color combination is perfect.
Offline ideus
  • Björkö.
« Reply #30 on: Fri, 10 February 2017, 21:40:53 »
No ISO support?
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #31 on: Fri, 10 February 2017, 21:58:09 »
I kind of like the inverted colors!
Offline hoq
    • wolfmark.work
« Reply #32 on: Fri, 10 February 2017, 22:07:37 »
Since so many people hope the cyan keycaps change their legends to more dark color (N9 or CC) , l'll try to make more mock ups to see how they look like.
Mock ups are not real world things, but they make sence for reference on color matching.
Just wait a moment. :))
Offline Hako
« Reply #33 on: Fri, 10 February 2017, 22:49:46 »
Any chance that you could offer row 5/A-profile bottom row keys too?
Offline ticktwo
  • -kbdfan
« Reply #34 on: Sat, 11 February 2017, 01:15:44 »
interested :thumb:
Sent from my SM-G935F using Tapatalk
HHKB | Leopold FC750R | Mech27 (soon) | TX-75 (soon)
Offline hoq
    • wolfmark.work
« Reply #35 on: Sat, 11 February 2017, 02:15:15 »
which kind of cyan keycaps do you like?
From left to right is N9, CC, WS1
Offline shower_king
« Reply #36 on: Sat, 11 February 2017, 02:28:27 »
aMong there legend colorS, i prefer to N9 :p
Offline Vloshko
« Reply #37 on: Sat, 11 February 2017, 06:27:06 »
Definitely want.
Also, N9 for sure
« Last Edit: Sat, 11 February 2017, 06:28:45 by Vloshko »
Keycap Compendium
Discord: Vloshko#1327
Key Cap Wishlist
2019: Configure Optimal Audio Settings
HHKB Pro 2, Model M, Unicorn X Legend, ESPECTRO 96, SaiB CP, E8-V1.
Offline h3xadat
« Reply #38 on: Sat, 11 February 2017, 07:42:35 »
+1 for N9.
Offline neon_tom
« Reply #39 on: Sat, 11 February 2017, 07:45:31 »
N9 definitely
Offline duynguyenle
« Reply #40 on: Sat, 11 February 2017, 08:02:13 »
N9 is a must, in order to fit with the rest of the set
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #41 on: Sat, 11 February 2017, 08:27:29 »
N9 looks best imo
Offline Enz0man
« Reply #42 on: Sat, 11 February 2017, 09:00:07 »
N9 is definitely the best of the three there.
Offline ticktwo
  • -kbdfan
« Reply #43 on: Sat, 11 February 2017, 09:37:16 »
+1 for N9.
+1
Offline inosint
« Reply #44 on: Sat, 11 February 2017, 10:05:05 »
Agree with N9, the contrast pops the most imo
Offline krisst
« Reply #45 on: Sat, 11 February 2017, 11:25:04 »
This set looks good. Hopefullly, the price is low enough to encourage more buyers.
Also, N9 for enter key makes it looks the sharpest.
Offline Chaosti
« Reply #46 on: Sat, 11 February 2017, 12:22:08 »
Mm, dat N9...
Offline poolside
« Reply #47 on: Sat, 11 February 2017, 12:49:15 »
Why is 'Alt Gr' being used with this US ANSI layout keyset?
N9 would look great as the legend color of the accented cyan Enter if one was to put together the N9 mods from Sky Dolch and the N9 alphas from Ocean Dolch. However, it would be more logical for this cyan Enter cap to have a CC legend as CC is the base color of the Ocean Dolch modifiers.
Offline ideus
  • Björkö.
« Reply #48 on: Sat, 11 February 2017, 12:52:49 »
It comes useful for people using US International Alternate Characters.
Offline FioraCorp
  • AKA ABC
    • My insta
« Reply #49 on: Sat, 11 February 2017, 13:24:34 »
That n9 legend looks FANTASTIC imo
 :thumb: :thumb:
