Author Topic: [GB] E8-V1 Custom TKL - SORTING THE BOARDS  (Read 1697634 times)
Offline pixelpusher
Re: [GB] E8-V1 Custom TKL - SORTING THE BOARDS
« Reply #1150 on: Mon, 20 November 2017, 20:33:45 »
Got mine finished today. Nice build.  I'll have to upload pictures sometime later b/c I'm headed out of town.  I didn't have any issues with the PCB.  I did notice that I shocked myself on the case and it rebooted the keyboard one time.  It could have been static shock I suppose.  I think the usb port touches the case just slightly.  That makes sense, right?
Anyway, very nice board.  I really like the bootmapper client software too.  I have 67g zealios in mine and I love the typing sound.  I ended up keeping penumbra on it, but I'll probably switch back and forth between that and hyperfuse.  Since this is my first top mounted board, I was curious to know if I could tell a difference from tray mount.  Yep, it's slight, but it does sound a lot nicer.
I did have one non E8-V1 related problem and I just thought I would mention it here.  I might make a post about it in the keycaps section as well.
I ordered some ePBT purple on beige keycaps to go on this board.  It looked perfect.  It would have been the dream.  However, I simply could not use those caps with cherry stabilizers. My best guess is that the purple set is a bit more shrunken from the molding process.  It definitely fits very tight on the stems.  I tried and tried all of the stablizers I had, but couldn't find a set that didn't feel like they were binding.  Long story short, it was the ePBT caps. I've experience similar issues with some pbt caps (industrial) from Signiture Plastics that were about 1mm off spec from stem center to stem center.  It pulls the stabilizers inward and makes them bind.   I will have to use the purple on beige set on a costar mount board, as they work fine there.  Boo.  I have a red on beige ePBT set that doesn't have this problem.
Oh well... Laser will look amazing on this keyboard some time down the road too.
You don't have any pcb issues? What happens if you turn off your computer with RGB sideglow on?
My rgb sideglow stays on once I turn off my computer.
Rgb stays on when computer off.
Offline Auxo
  • Formerly CJD_Anthony
« Reply #1151 on: Mon, 20 November 2017, 21:35:39 »
My board came in....
182528-0
182530-1
182532-2
182534-3
Offline Oscar2177
Offline Auxo
« Reply #1153 on: Mon, 20 November 2017, 21:37:55 »
those blemishes make me pretty bummed out tho, idk what to do, especially with all that's happened with this GB :(
Offline pixelpusher
« Reply #1154 on: Mon, 20 November 2017, 21:52:22 »
That really is unfortunate that you have two in such prominent spots, but I bet you will mostly forget about them once you put some keycaps on it.
I do have good news to report on the SA front.  I can confirm that sliding the plate up as far as possible will let you use SA, both all R3 and sculptured.  I pulled out my industrial set from PMK... looks pretty amazing on the dark gray case.  I've never left these keycaps on a board for more than a day, so we'll see if this one stands the test.
« Reply #1155 on: Mon, 20 November 2017, 22:02:22 »
you're boned
can try to take them to a local shop to see what they can do, if you'd like
Offline Auxo
« Reply #1156 on: Mon, 20 November 2017, 22:10:51 »
If it were that easy to forget haha, im like.. really nitpicky unfortunately
you're boned
Yeah, lol. I am... considering just sucking it up, but im not sure if I'll be happy in the long run with it
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #1157 on: Tue, 21 November 2017, 00:30:20 »
get it sand blasted and cerakoted ?
-Dana
Offline Auxo
« Reply #1158 on: Tue, 21 November 2017, 00:35:01 »
ill just go to town on it and go for a "beaten" look rofl
« Reply #1159 on: Tue, 21 November 2017, 00:35:20 »
i do not recommend this approach
Offline Kafka
  • i like clean things
« Reply #1160 on: Tue, 21 November 2017, 00:45:45 »
i recommend this approach
Offline Vloshko
« Reply #1161 on: Tue, 21 November 2017, 15:15:13 »
Well if we can find a way for SA profile to work then you could make it Fallout inspired to make you feel better.
Keycap Compendium
Discord: Vloshko#1327
Key Cap Wishlist
2019: Configure Optimal Audio Settings
HHKB Pro 2, Model M, Unicorn X Legend, ESPECTRO 96, SaiB CP, E8-V1.
Offline OfTheWild
« Reply #1162 on: Tue, 21 November 2017, 17:44:21 »
I'm not gonna lie... i actually thought about what it might be like to do a "distressed/relic" look. It could be pretty cool. Or a total waste of an otherwise pretty nice board. Either way i support YOU doing it  :p
-Dana
Offline pixelpusher
« Reply #1163 on: Tue, 21 November 2017, 19:07:33 »
SA works if you slide the plate up.  At least for me it did
Offline afrokobe
« Reply #1164 on: Tue, 21 November 2017, 20:34:17 »
im having issues with gmk shift keys hitting the blockers (my og poms are fine)... my plate was a bit rough and moved it up as high as I can.  Anyone having issues?
« Reply #1165 on: Tue, 21 November 2017, 21:59:45 »
are they hitting the blockers or the sides of the case?
Offline alveeno
« Reply #1166 on: Wed, 22 November 2017, 00:50:08 »
I'm not having any issues.
Offline afrokobe
« Reply #1167 on: Wed, 22 November 2017, 10:03:13 »
they are rubbing against blockers like the top side when the key is depressed
Offline excluisve
  • Making & Thinking.
« Reply #1168 on: Sat, 25 November 2017, 09:06:44 »
Thanks a lot .ppl receive it
E8 was my first design so it may have some issue
We are doing better on the road thanks
The blocks against it need put plate upfront
Offline actualglacier
  • ¯\_(ツ)_/¯
« Reply #1169 on: Sat, 25 November 2017, 09:53:55 »
Sent a few emails to Kuang with zero replies.
actualglacier on youtube
Offline nevaenuf
« Reply #1170 on: Sat, 25 November 2017, 10:15:45 »
Got mine.  Board has one small blemish next to arrow keys.  What I thought was a scratch on the bottom turned out to be some kind of sticky material.  I was about to rub it off with my thumb.  My problem is that two of the M2 screws are so tight, I can't get them out.  I've tried two different 1.5mm allen wrenches.  Anyone got any suggestions?
Offline pixelpusher
« Reply #1171 on: Sat, 25 November 2017, 18:57:16 »
I used a t6 driver on mine.  Worked well
Offline nevaenuf
« Reply #1172 on: Sun, 26 November 2017, 00:26:33 »
Thanks.  I ended up using the same.  Amazon same day is lovely.
Offline kuang2
« Reply #1173 on: Sun, 26 November 2017, 02:04:57 »
Hi all,
It's seem that all of Batch 2 had come to you all. I will start Batch 3 this week. Please check my update sheet: https://docs.google.com/spreadsheets/d/14lYDVr2Y6TSb7o_OJVbKxBEAn1Ct7PbE8NZRSLaID6Y/edit?usp=sharing
  • ¯\_(ツ)_/¯
« Reply #1174 on: Sun, 26 November 2017, 03:25:51 »
Hi all,
Hi Kuang, I've sent you an email about my order (E74).
Thank you.
Offline kuang2
« Reply #1175 on: Sun, 26 November 2017, 07:12:46 »
Hi all,
Thank you.
got it
  • ¯\_(ツ)_/¯
« Reply #1176 on: Sun, 26 November 2017, 10:05:34 »
Hi all,
Thank you.
got it
Woo that looks great! I haven't received an invoice for the shipping + assembly though. Would also appreciate a reply to the latest email I sent, but I know you're busy. Take your time.
Thank you.
Offline Shados
« Reply #1177 on: Sun, 26 November 2017, 17:01:56 »
Hi all,
I did send a follow-up email confirming I'd be fine paying the shipping fee, you might wanna check your emails...
Offline balotelli00
« Reply #1178 on: Sun, 26 November 2017, 18:33:06 »
Hi all,
Hi,
when are you going to send the invoice for order E53?
Offline pixelpusher
« Reply #1179 on: Mon, 27 November 2017, 10:29:24 »
Going to swap these out for GMK muted later today, but this is the best I’ve ever seen my SA industrial set looking.  No stepped caps but you get the idea.  Also if you turn down rgb brightness it does help to make the in switch leds much brighter.
183054-0
More pics here: https://imgur.com/gallery/tFKSZ
Offline gt1989
« Reply #1180 on: Mon, 27 November 2017, 10:59:58 »
Do you have any issues with the SA caps rubbing or getting stuck with the spacers?
Offline pixelpusher
« Reply #1181 on: Mon, 27 November 2017, 11:13:47 »
I do not have issues as long as the plate is pushed up as far as I can get it to the top of the board.  The only issue I have is that any little bit of static buildup shocks the case and makes it reset in windows.  I just have to make sure I discharge my static electricity on something after I sit down and before I touch my keyboard.
I'm fairly certain it's static buildup but does anyone else have this problem?  I suppose it's possible that some of the pins are touching the metal base inside, but I would think that would cause a shock quite often.  I've never had it shock me while I was using it, only when I first sit down, after walking around.  And if I discharge the static on a metal stand nearby it doesn't shock me.
« Last Edit: Mon, 27 November 2017, 11:25:36 by reececonrad »
  • ¯\_(ツ)_/¯
« Reply #1182 on: Mon, 27 November 2017, 12:08:30 »
damn that looks great! can you grab a few 3/4 or side profile shots? really want to see how well the diffuser works
also the issue you had with static discharge is pretty disconcerting. sounds like something that could potentially kill the keyboard
thanks for sharing!
« Last Edit: Mon, 27 November 2017, 12:19:14 by notglacier »
Offline pixelpusher
« Reply #1183 on: Mon, 27 November 2017, 12:30:00 »
Already took the SA caps off :(
But the good news is, muted looks quite amazing
183064-0183066-1
Just have to remember to discharge the static :)
I might think about putting some electrical tape around the usb connector inside the case.  That’s more than likely the spot that makes contact
Offline pixelpusher
« Reply #1184 on: Mon, 27 November 2017, 12:32:47 »
thanks for sharing!
Diffuser looks really nice.
183068-0
  • ¯\_(ツ)_/¯
« Reply #1185 on: Mon, 27 November 2017, 12:38:52 »
thanks for sharing!
That actually looks amazing, thank you! Do you just touch something metal before using the keyboard to prevent the static? That's not too bad I guess.
Can't wait to receive mine.
Offline pixelpusher
« Reply #1186 on: Mon, 27 November 2017, 12:59:10 »
thanks for sharing!
Yep. I have a metal shelf to the right of my desk that I touch when I sit down
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #1187 on: Mon, 27 November 2017, 13:38:34 »
Looks awesome man! Muted really works well with those LED colors
« Reply #1188 on: Mon, 27 November 2017, 15:24:42 »
the plate being pushed up like that makes for a really ugly gap at the bottom
Offline roostrc0gburn
  • its just plastic
« Reply #1189 on: Mon, 27 November 2017, 15:33:45 »
just hush, puddsy. you're not even in this group buy. dont ruin it for the rest of them
Offline pixelpusher
« Reply #1190 on: Mon, 27 November 2017, 15:53:05 »
The created gap isn't bad. There is roughly 1mm more gap on the bottom than the top.  When you are using the keyboard, and not hovering directly above it, you cannot see the extra gap at all.  Seems like a silly oversight when the blockers should have been at least  2mm shorter.  Howver, it is still is one of the nicest boards I own.
Offline afrokobe
« Reply #1191 on: Mon, 27 November 2017, 16:51:15 »
rip I cant even push mine that far up. guessing you have no issues with gmk shift keys
Offline pixelpusher
« Reply #1192 on: Mon, 27 November 2017, 17:25:00 »
Correct, I don’t.  I wonder if you could file down the plate edge along the top screw area to give yourself room to slide the plate.  It couldn’t hurt anything as long as you don’t file all the way to the hole
Offline trungminhtp
« Reply #1193 on: Mon, 27 November 2017, 23:37:04 »
Hi Kuang, I've sent you an email about my order (VN05).
Thank you.
Tgr Tris | Tgr x Singa Unikorn x Mechlovin' & GSK | Tgr Alice | Tgr 910se | Tgr Jane v2 | Tgr Jane v2ce Silver | Tgr Jane v2ce | Tgr Police | OTD 356 Mini
Offline OfTheWild
« Reply #1194 on: Tue, 28 November 2017, 00:48:46 »
I'm still messing with mine. I've already desoldered a bunch of switches and sip sockets. The PCB and Pads are holding up fine at 685F temps on the iron.
-Dana
Offline Vloshko
« Reply #1195 on: Tue, 28 November 2017, 20:29:02 »
Unpacking the boards: https://imgur.com/a/VSfYf
Keycap Compendium
Key Cap Wishlist
Offline excluisve
« Reply #1196 on: Tue, 28 November 2017, 21:05:22 »
[/quote]
This is the solution
Offline Vloshko
« Reply #1197 on: Tue, 28 November 2017, 21:11:22 »
I have outfitted one PCB with some Holtites I got from Zeal, they all fit wonderfully. In addition I have some Lead Switch and LED Holtites coming from Winkeyless and will update yall on the fit. Invyr Panda switches don't fit.
« Last Edit: Wed, 29 November 2017, 02:22:54 by Vloshko »
Keycap Compendium
Key Cap Wishlist
Offline OfTheWild
« Reply #1198 on: Tue, 28 November 2017, 22:05:17 »
Cool thanks for the follow up . Your boards look pretty nice. Love seeing all these color options people went with.
-Dana
Offline Vloshko
« Reply #1199 on: Tue, 28 November 2017, 23:17:29 »
Anyone know what numpad would pair well with this?
« Last Edit: Wed, 29 November 2017, 01:31:55 by Vloshko »
Keycap Compendium
Key Cap Wishlist
