Author Topic: Cherry MX11900 $20 BIN Free Shipping  (Read 3072 times)
Offline SCTony
« on: Thu, 04 February 2010, 15:39:26 »
(Remanufactured?/tested) More than 10 available. PS2 w/ touchpad. Link
IBM PC-AT Model F ;  Model M-
    1391401 Aug 89, 92G7453 Nov 95, 42H1292 Jul 97
Compaq KB-9963 (rubber dome);
Cherry MX-SPOS:typing:
Offline wolf
  • Ah, yeah, g'day.
« Reply #1 on: Thu, 04 February 2010, 17:28:41 »
many thanks for the link, I was searching for one of those. they use the cherry browns, soft tactile, correct?
Have keyboard, will travel...
Offline Viett
« Reply #2 on: Thu, 04 February 2010, 17:31:53 »
Black cherry. The MX11800's are brown.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline wolf
  • Ah, yeah, g'day.
« Reply #3 on: Thu, 04 February 2010, 17:37:29 »
Thanks, Viett
What are linear keys like, feel-wise?
« Last Edit: Thu, 04 February 2010, 17:39:43 by wolf »
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #4 on: Thu, 04 February 2010, 17:57:57 »
Quote from: wolf;156326
Thanks, Viett
If I may:
Linear switches slide from top to bottom with no click that you can hear or feel when they actuate. They slam rather unpleasantly (subjective of course) into the bottom of the keyboard exactly like - in some cases worse than - rubber domes, since rubber domes will often bottom out softly while a linear switch is quite rough.
kishy.ca
Offline SCTony
« Reply #5 on: Thu, 04 February 2010, 18:29:10 »
I was happy with my MX11900 black switched board- until I got a Cherry brown switched board :) I would recommend the browns much more than the blacks, but that is a good price to try out the blacks. Typing on the blacks now feels heavy (compared to the browns) and the tactile feedback of the browns helps a lot.
Offline wolf
  • Ah, yeah, g'day.
« Reply #6 on: Thu, 04 February 2010, 18:41:39 »
Thank you, Kishy, for that excellent description.
I currently use rubber dome keyboards - mix of hp/compaq boards and budget ("Rock" mini) boards.
I don't mind them so much.
