Author Topic: Help me make some MX Super Blacks from normal Blacks!  (Read 3370 times)
Offline happylacquer
  • BS Apologist
    • BHOBuds
« on: Sat, 18 February 2017, 19:04:11 »
Okay so with only 7 available at an absurd price I am gonna go the DIY route...
http://www.ebay.com/itm/CHEERY-MX-SUPER-BLACK-150cn-150g-keyboard-switch-Extremely-RARE-/281135270615
Thinkin about a JD40 build so I guess spring replacement wouldn't be so terrible.
My question is where do I get the springs heavy enough to turn them into 150g buttons?
I considered using white, green or grey MX, but 80 cN is not enough for my fingers of steel to be happy... I really wanna 150g it.
The heaviest I have found are 100g.
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1868
« Last Edit: Sat, 18 February 2017, 19:07:31 by happylacquer »
Re: Help me make some MX Super Blacks from normal Blacks!
« Reply #1 on: Sat, 18 February 2017, 19:18:15 »
Pen springs
  • BS Apologist
    • BHOBuds
« Reply #2 on: Sun, 19 February 2017, 04:41:26 »
Pen springs
Dang what pens have perfectly size springs in them  :confused:
Offline Phenix
« Reply #3 on: Sun, 19 February 2017, 06:01:08 »
Switchtop
Winter is coming.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Sun, 19 February 2017, 06:19:47 »
Man, I can't believe you'd actually want to type on superblacks xD .
« Reply #5 on: Sun, 19 February 2017, 12:28:55 »
Pen springs
I don't recall exactly, but I remember years ago I put pen springs in a switch and it was gnarly hard to push.
  • BS Apologist
    • BHOBuds
« Reply #6 on: Sun, 19 February 2017, 16:07:40 »
a JD40 with all 150g keys would be god damn glorious
Offline Potatomonkey
  • Tsangan best row
« Reply #7 on: Mon, 20 February 2017, 19:16:19 »
You may be happy to learn that Switchtop just opened a group buy for gold springs that have a 150g option. http://gb.switchtop.com/product/gold-plated-switch-springs
Offline zpcomstock17
« Reply #8 on: Tue, 21 February 2017, 00:24:44 »
Pen springs
Can confirm.
I experimented with pen springs for the fun of it, G2, Uniball, Bic, etc.
Uniball pens work the best and stimulate a super stiff switch too. They fit the best in the housing and actually doesn't fight back the clips unless you didn't secure them firmly enough.
You should order some 150g springs from switchtop and use a pen spring as substitutes until the real thing comes.
« Last Edit: Tue, 21 February 2017, 00:28:51 by zpcomstock17 »
Offline nmur
  • ಠ_ಠ
« Reply #9 on: Tue, 21 February 2017, 00:34:33 »
i tried putting a pen spring in a gateron black a while ago in the office when i was bored
it was super stiff, must have been like legit 300g
i was just pressing it and sliding my finger off to release it, and it shot the sadster that was on it into the air. to this day i don't know where it went, perhaps it's in low earth orbit
