Author Topic: Alternatives to a phantom PCB?  (Read 4523 times)
Offline cactusplants
« on: Sun, 19 February 2017, 21:15:36 »
I've hand-wired my own KB but I feel it needs a proper pcb. Thing is, only can find a phantom on mechkeys website, and It costs more to post it over to the UK than it does to buy the PCB.
Just looking for other alternatives I may be able to go with that won't cost an arm and a leg in for me to get in the UK.
Re: Alternatives to a phantom PCB?
« Reply #1 on: Sun, 19 February 2017, 22:35:00 »
could get a KMAC PCB off classifieds for not too much
or try winkeyless.kr
Offline klennkellon
  • I like bottoming out
« Reply #2 on: Sun, 19 February 2017, 23:11:30 »
could buy a cheap chinese keeb and just desolder all of the switches. some have surprisingly good plates.
« Reply #3 on: Mon, 20 February 2017, 02:37:41 »
Don't think I have enough rep/postcount to go and venture to the classifieds.
Winkeyless looks good. I can't seem to figure out if I can use my teensy 2.0 with their PCB's nor do I know of the postage cost to the UK.
Offline TalkingTree
    • My projects
« Reply #4 on: Mon, 20 February 2017, 05:25:28 »
You might need reputation and post count to sell in the classifieds but as a buyer you certainly don't.
I assume you want a TKL keyboard. If your layout is standard (6.25u spacebar and four mods on its right), you could buy some cheap mechanical keyboard on Amazon and replace the switches with your favourites. The only downside is that you'll have no way to reprogram it.
Ultimately, you can design your own PCB.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #5 on: Mon, 20 February 2017, 09:42:16 »
As a buyer, your post count doesn't really matter. As long as you're paying with Paypal as merchandise, there's really no risk on either end. What would you be wanting to do with your Teensy? WKL PCBs are great for their programmability and easy to use software. As for postage, you're probably looking at around $30 or so for EMS from SK
« Reply #6 on: Mon, 20 February 2017, 11:25:20 »
I would like the ability to reprogram. I was going to make a WTB post in the classifieds asking for a phantom pcb to the UK. But I couldn't find the make a new thread button.
I've already built a 60% and hand wired it. But I use the arrows and the numpad quite often, so I'd be looking at either a fullsize or a TKL with extra 5 buttons around the arrowkeys.
My mounting plate doesn't hold my ISO enter nor does it work with stabs so I can't use my space bar without hitting the centerpoint.
Offline TalkingTree
    • My projects
« Reply #7 on: Mon, 20 February 2017, 14:05:49 »
Right, you need 25 posts to post a classified thread. That shouldn't take you long. Meanwhile you can check mechmarket on reddit.
