Author Topic: [IC] Alpha Keycap set inspired by Scrabble Tiles | PRICING TIERS ADDED  (Read 6599 times)
Offline CAPS UNLOCKED
    • capsunlocked
Hi,
This is an interest check for an alpha keycap set inspired by Scrabble Tile. None of the details have been finalised, I am open to suggestions.
This will be a dye-sub keycap set, produced by Signature Plastics. The profile will either be DSA or SA.
The production lead time will be approximately 12 weeks. I will add the pricing as soon as possible.
The MOQ will be 50 units.
[PRICING]
DSA DYE-SUB:
50 UNITS - $78
100 UNITS - $74
200 UNITS - $72
SA DYE-SUB:
50 UNITS - $86
100 UNITS - $83
200 UNITS - $81
If you want an entire keycap set inspired by Scrabble or if you are interested in some Scrabble Novelty Keycaps, please leave a comment below.
All feedback is appreciated.
Thank you.
[Design #1][02-03-2017]
161903-0
Colours:
- Keycaps: WAS
- Legends: Black
« Last Edit: Fri, 10 March 2017, 05:04:12 by CAPS UNLOCKED »
Offline LDobler
Re: [IC] Alpha Keycap set inspired by Scrabble Tiles
« Reply #1 on: Thu, 02 March 2017, 15:02:06 »
I'd be in for a set of SA profile alphas  :p
Offline zacheadams
« Reply #2 on: Thu, 02 March 2017, 15:04:08 »
SA R3 or DSA would be most appropriate for shuffling them around.  I'd say that if you do DSA you should do PBT to cut down on the queue.
    • capsunlocked
« Reply #3 on: Thu, 02 March 2017, 15:08:02 »
Thank you for the support! Which row configuration would you prefer?
I thought all dye-sub keycaps produced by Signature Plastics are always PBT, but please correct me if I am wrong. Thank you for the feedback!
Offline LDobler
« Reply #4 on: Thu, 02 March 2017, 15:10:14 »
I would prefer sculpted  :)
1-2-3-4
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #5 on: Thu, 02 March 2017, 15:27:05 »
cool idea
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #6 on: Thu, 02 March 2017, 15:36:24 »
Hahaha this reminds me I have to place my tiles on my Words With Friends games... Cool idea!
    • capsunlocked
« Reply #7 on: Thu, 02 March 2017, 16:03:02 »
1-2-3-4
Good to know! Thanks!
cool idea
Thank you for the feedback, it is great to know that people like the idea!
Offline JDragon
« Reply #8 on: Thu, 02 March 2017, 16:48:01 »
Cool idea! DSA or R3 SA would be preferred for me (I assume this would be dye sub). This would be a nice novelty keyset.
Offline unoab
« Reply #9 on: Thu, 02 March 2017, 20:41:44 »
Interesting concept, but I would think the default SP profile to go to first for a scrabble based set would be G20, it is square and looks like a tile already.  Have them make them in TT (a beige/tan PBT color), and then you could for the most part have simulated tiles.  You could even divide the large mods, which should be green, with black lines like the empty spaces on a scrabble board.
    • capsunlocked
« Reply #10 on: Fri, 03 March 2017, 09:05:49 »
Another user has also suggested R3 SA, so I will definitely consider it! The keycap set would be dye-sub. Thank you for the feedback!
Thank you for the suggestion and feedback! I would prefer to stick to DSA/SA at the moment, and I am a bit hesitant about making and entire set. If there is a large demand for and entire set, including add-on kits, then I will consider designing it.
    • capsunlocked
Re: [IC] Alpha Keycap set inspired by Scrabble Tiles | PRICING TIERS ADDED
« Reply #11 on: Fri, 10 March 2017, 05:06:33 »
Pricing tiers have been added!
Offline AuthenticDanger
« Reply #12 on: Sun, 12 March 2017, 22:47:40 »
I'm 100% in for DSA. Looks awesome!  :thumb:
F Keys belong on the left.
Offline jebbra
  • jebbra.net
« Reply #13 on: Mon, 13 March 2017, 12:47:42 »
At the very least, DSA will do too.
I think because scrabble design is 'too plain' to start of, only the additional number point to indicate that it is a scrabble, we need a bolder design here.
Ivory base with dark green letters and this particular font type and size will do the job
