Author Topic: Model M / MX11800 / Filco Brown / HHKB pro2  (Read 7604 times)
Offline elbowglue
« Last Edit: Sun, 07 February 2010, 12:38:31 by elbowglue »
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline didjamatic
« Reply #1 on: Sun, 07 February 2010, 12:51:29 »
I'll try to get some more posted as well.  It's just a matter of finding time to do it.
Offline elbowglue
« Reply #2 on: Tue, 09 February 2010, 11:59:21 »
Man I can't believe nobody picked up that Compaq MX11800 - I would have bought it except I already have 2 of them.  Ohwell maybe I'm the only one who likes PCB mounted cherry browns with standard layout for the main keys in a spacesaver format. :P
Offline ricercar
  • mostly abides
« Reply #3 on: Tue, 09 February 2010, 18:57:03 »
Quote from: elbowglue;157313
Saw one for $19 at a store down the road. Dirty as cursing at mudwrestling ****s. Thought it was blacks. Browns are worth $19 maybe.
Offline itlnstln
« Reply #4 on: Tue, 09 February 2010, 19:30:38 »
Quote from: ricercar;157437
This made my day.
Offline didjamatic
« Reply #5 on: Tue, 09 February 2010, 21:13:55 »
I cancelled the auction since I thought of a project I could utilize it for :)
Offline elservo
« Reply #6 on: Tue, 09 February 2010, 22:28:21 »
Why you selling the Filco, Didja?  It looks purdy.
Majestouch Tactile Click (Work)
AEKII(Home)
Offline elbowglue
« Reply #7 on: Tue, 09 February 2010, 22:41:09 »
Compaq mx11800 + Cherry g80-11900 ($20 shipped from chicago liquidators) = instant board with cherry reds with relatively small form factor.  Good for gaming.
Offline elservo
« Reply #8 on: Tue, 09 February 2010, 22:43:36 »
Do you have to solder the switches or can you just switch out the whole production?
AEKII(Home)
Offline elbowglue
« Reply #9 on: Tue, 09 February 2010, 22:53:26 »
Quote from: elservo;157482
PCB mounted cherry switches require no soldering.  Just pop the top off the switch, keep the cherry brown switch, use the cherry black stem, replace the top.  It's very easy as long as you don't lose any springs.
Plate mounted cherry switches must be de-soldered (plate mounted includes filco, das.. PCB mounted are all the cherry boards, MX 11800..)
Offline elservo
« Reply #10 on: Wed, 10 February 2010, 10:53:03 »
Fascinating!
AEKII(Home)
Offline itlnstln
« Reply #11 on: Wed, 10 February 2010, 11:08:21 »
I also find the PCB-mounted switches also have a better feel, but YMMV.
Offline SLM
« Reply #12 on: Thu, 11 February 2010, 21:31:34 »
What's the little doodad on the Focus boards under the logo door?  Maybe a switch or something?  I can't tell from the pics. :(
Offline elbowglue
« Reply #13 on: Thu, 11 February 2010, 21:47:50 »
Quote from: SLM;157894
Probably an XT/AT switch if you want to use the board with your modern PC or your old IBM XT computer
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #14 on: Thu, 11 February 2010, 22:06:20 »
Friend has a 5001, on that board it is a set of two switches which together function as an AT/XT switch.
kishy.ca
Offline SLM
« Reply #15 on: Thu, 11 February 2010, 22:15:07 »
Thanks.  I thought maybe it was some sort of a switch.  I'm pretty new to these old keyboards.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #16 on: Thu, 11 February 2010, 22:29:26 »
Quote from: SLM;157897
No problem. And just in case you're not aware, the function of the AT/XT switch is to allow the keyboard to function with the IBM PC and XT keyboard protocol which was pretty much out of use on computers by the end of the 80s. AT mode gives you (of course) AT compatibility, PS/2 compatibility, and thus USB compatibility using a suitable converter.
Anyone want me to grab a photo of the DIP switches under the logo plate on a 5001?
kishy.ca
Offline SLM
« Reply #17 on: Thu, 11 February 2010, 22:46:45 »
Thanks!  I didn't know how that all worked.  I didn't get into computers until around '95 or so.  My first system was a donated PII 233.  The keyboard was a NMB with AT to ps/2 adapter.  I still have the board actually.
Offline elbowglue
« Reply #18 on: Fri, 12 February 2010, 23:16:04 »
OMG cherry brown otaku tenkeyless for 118 + 10 shipping on ebay? Christ!
Offline SLM
« Reply #19 on: Sat, 13 February 2010, 15:43:29 »
I just kinda wanna try the Alps!
Offline Viett
« Reply #20 on: Sat, 13 February 2010, 19:43:30 »
Didn't win the Focus 2001. Damn.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline ricercar
  • mostly abides
« Reply #21 on: Sat, 13 February 2010, 19:49:30 »
Quote from: SLM;158166
You're not missing anything. Move on.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #22 on: Sat, 13 February 2010, 19:52:33 »
Quote from: ricercar;158199
Exactly. Make people think this so the prices drop and I can accumulate more keyboards with awesome white Alps switches (simplified preferred).
kishy.ca
Offline SLM
« Reply #23 on: Sat, 13 February 2010, 23:59:40 »
Quote from: Viett;158195
If you mean the one Didjamatic sold, that's because I did.  There's another one listed here... http://cgi.ebay.com/Focus-2001-Mechanical-Clicky-AT-keyboard-Great-shape_W0QQitemZ220555120405QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item335a1c0f15 if you're interested.
Offline Viett
« Reply #24 on: Sun, 14 February 2010, 14:42:19 »
Thanks, but that's a bit more than I wanted to spend on a trial board, hence why I lost Didjamatic's. Plus, that guy is charging almost twice as much on shipping.
Offline SLM
« Reply #25 on: Sun, 14 February 2010, 14:50:04 »
Yea, I saw his shipping is almost insulting.  $17.00 bucks should cover UPS second day air let alone Postal parcel post.  But that board includes the dust cover.  That alone probably makes it worth a few bucks more I'd think.
