Author Topic: Buckling springs keycaps  (Read 2982 times)
Offline Entropia
« on: Thu, 23 March 2017, 16:34:49 »
A simple question: are all buckling screen keycaps the same or are they different depeding on the row, as happens with Cherry or OEM profiles?
Re: Buckling springs keycaps
« Reply #1 on: Thu, 23 March 2017, 16:47:48 »
All the same
« Reply #2 on: Thu, 23 March 2017, 16:51:20 »
« Reply #3 on: Thu, 23 March 2017, 16:55:47 »
They are different depending on the row. The bottom row uses what's called a space bar, and is a lot longer. Others use two Shifts, one has  Backspace, etc. Those are all different.
« Reply #4 on: Thu, 23 March 2017, 16:56:41 »
well played
« Reply #5 on: Thu, 23 March 2017, 16:58:27 »
Touché
« Reply #6 on: Thu, 23 March 2017, 20:54:33 »
They are uniform profile - it is a curved plate that gives the impression of a sculpted profiles.
