Author Topic: Do you lube Topre? If so, why? If so, which lube? Thick or thin?  (Read 7148 times)
Offline brianjking
  • always carry a towel.
    • @brianjking
Hi,
I have a HHKB Pro 2 Type-S and a HHKB Professional JP and am interested in hearing about lubing Topre. I've read quite a bit throughout Geekhack and on /r/mechanicalkeyboards and can't seem to get a consensus so hopefully this thread will help me out with making a decision.
In addition to the questions below I'd also greatly appreciate some links showing lubing guides as the only times I've opened up my HHKB's is to install a Hasu controller.
Questions:
  • Do you lube topre? If so, why? If not, why not?
  • If you do lube, which lube do you use? Where do you buy it?
  • Thick lube or thin lube? I have read threads here and on /r/mechanicalkeyboards indicating using only one over the other but there seems to be a lot of conflicting info
Thank you!
Offline schoolbus
Re: Do you lube Topre? If so, why? If so, which lube? Thick or thin?
« Reply #1 on: Wed, 29 March 2017, 09:03:21 »
I've lubed two novatouches w/ the red lube from elitekeyboards.
truthfully I don't know how much it really effects things- I suppose it's a little bit smoother. I only did it because I was also adding hyperspheres and figured I'd kill two birds w/ one stone while I had it open. I can't say it's really worth it to just lube topre unless you've got time to kill- others might disagree.
I don't think there are really any negatives, except if you end up using a lube that drips and causes corrosion on the domes.
I can't find the guide I used, but it's as simple as using a little paintbrush and applying some lube on where the sliders connect, I didn't use a lot but you could tell it had an impact immediately because the sliders weren't just moving w/ gravity anymore.
« Last Edit: Wed, 29 March 2017, 09:06:11 by schoolbus »
Offline Moistgun
  • Slippery When Wet
Offline brianjking
    • @brianjking
« Reply #3 on: Wed, 29 March 2017, 09:37:17 »
Offline Moistgun
  • Slippery When Wet
« Reply #4 on: Wed, 29 March 2017, 09:40:09 »
I lube because it helps make it feel nicer and sound quieter.
I think most people would say you should Use thick lube
I get lube from Techkeys
Offline cutterline
« Reply #5 on: Thu, 30 March 2017, 03:20:49 »
Just test it for yourself, let's say do 5 keys lubed (thin/thick) and see if you like them lubed.
I don't like them lubed as I like it out of the box and lubing them makes them somehow weird.
Edit: I use RF board
« Last Edit: Thu, 30 March 2017, 03:24:05 by cutterline »
