Author Topic: [IC] ACE-XT40 [Group buy Running]  (Read 5835 times)
Offline wangbwhz
« on: Fri, 31 March 2017, 12:13:53 »
2017/04/04
Group buy is running now
https://geekhack.org/index.php?topic=88652.0
2017/06/04
Update from the designer: the ACE-XT40 will be compatible with plank PCB
The price for the 1 case, 1plate, fixing bolts and rubber pads is $135. The pcb are not sold individually.
Hey guys
A 40% layout keyboard. Are you interested?
As the layout is similar with Planck. Previously I have PM the OLKB and receive affirmation and praise from him.
The keyboard is design by the member of wolf team.
Sample Picture:
164457-0
164459-1
164528-2
164530-3
More Pictures on
http://imgur.com/a/xnBI7
Tech Specification:
  • MX aluminum Reinforcement Plate (Aluminum 6063)
  • Case has an angle of 5 degrees for the Aluminum 6063 (the case does not support other 40% PCB)
  • Blue PCB presoldered based on Bface(resistors, diodes,etc, but not switches)(still under negotiation)
  • Fixing bolts and rubber pads
Group buy Information:
  • Estimated Price: 150 USD excluding the PP fee and shipping fee
  • Weight: 2KG after package
  • Limit of 128 sets
  • Switches and stabilizers are not included (Requires Cherry PCB mounted stabilizers)
Layout option:
164455-4
Color option:
Black
164441-5
Gray
164443-6
Silver
164445-7
Blue
164447-8
Red
164449-9
Green
164451-10
Rose Gold
164453-11
« Last Edit: Wed, 05 April 2017, 22:58:38 by wangbwhz »
My Precious¬
Re: [IC] ACE-XT40
« Reply #1 on: Fri, 31 March 2017, 12:26:34 »
I'm not about that 40% life but that is a sexy keyboard.
Re: [IC] ACE-XT40
« Reply #2 on: Fri, 31 March 2017, 13:14:55 »
I dig. Price estimate? Been considering a 40%, this might be the one.
Offline neon_tom
Re: [IC] ACE-XT40
« Reply #3 on: Fri, 31 March 2017, 13:36:16 »
These look really nice!
Offline Zammux
Re: [IC] ACE-XT40
« Reply #4 on: Fri, 31 March 2017, 14:34:40 »
That case looks so nice.
Offline gnmar2723
Re: [IC] ACE-XT40
« Reply #5 on: Fri, 31 March 2017, 14:41:26 »
Yes same here. If you do a 60%/TKL case design though, I'm down for that!  :thumb:
Offline Trente
Re: [IC] ACE-XT40
« Reply #6 on: Fri, 31 March 2017, 17:51:02 »
Same here, 60% or 75% I will be in!
Offline wangbwhz
Re: [IC] ACE-XT40
« Reply #7 on: Sat, 01 April 2017, 11:45:55 »
Estimated price is updated, around 150USD
« Last Edit: Sun, 02 April 2017, 05:51:52 by wangbwhz »
My Precious¬
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: [IC] ACE-XT40
« Reply #8 on: Sun, 02 April 2017, 21:50:05 »
I'd probably be down for one. I love the hi pro case.
$150 for what? Case, plate, pcb, ...?
Offline sandwich113
Re: [IC] ACE-XT40
« Reply #9 on: Tue, 04 April 2017, 03:09:31 »
Is that same as a planck layout?
  • (⌐■_■)⊃━☆゚.*・。゚
Re: [IC] ACE-XT40
« Reply #10 on: Tue, 04 April 2017, 06:56:02 »
Yea it is.
wangbwhz, how is this reprogrammed? I assume this will use TMK/QMK?
Offline wangbwhz
Re: [IC] ACE-XT40
« Reply #11 on: Tue, 04 April 2017, 09:48:37 »
Yea it is.
We use Bface(Source: http://blog.winkeyless.kr/) instead.
My Precious¬
  • (⌐■_■)⊃━☆゚.*・。゚
Re: [IC] ACE-XT40
« Reply #12 on: Tue, 04 April 2017, 18:28:19 »
Yea it is.
In light of this, I think I will have to pass. Good luck with the GB though  :thumb:
