Author Topic: issue resetting Pok3r  (Read 1740 times)
Offline mniels
« on: Thu, 06 April 2017, 11:15:45 »
Not sure if anyone else has seen this, but the red LED on the spacebar is lit and I am unable to change layers or reset back to default (by holding Fn+R.)
At this point the board is not functioning at all.  It is acting as if in the middle of programming even though it is not.
Anyone have a fix for this?
« Last Edit: Thu, 06 April 2017, 11:22:11 by mniels »
Re: issue resetting Pok3r
« Reply #1 on: Thu, 06 April 2017, 11:48:43 »
I assume you've tried the obvious unplug and plug it back it etc.
https://geekhack.org/index.php?topic=76242.0
Maybe this thread might have some helpful info?
Offline mniels
« Reply #2 on: Thu, 06 April 2017, 11:53:35 »
Turned out it was the fourth dipswitch, back up and running now.
