Author Topic: [IC] GMK Night Sky - The Beauty Of The Night  (Read 7045 times)
Offline janglad
  • qoda.studio
    • Clavier.xyz
« on: Mon, 10 April 2017, 17:31:42 »
Hi!
Inspired by the beauty of the night, I present you: GMK Night Sky!
Both colours and kit design are not final, every suggestion is very valuable!
Here is a Google form for input on the kit design and colours.
Current colour and kit design
The kit is designed to both work with popular layouts and still be relatively cost efficient. Some of the current supported layouts are:
  • 104 key
  • 96 key
  • 75%
  • HHKB Layouts
  • WKL Layouts
  • Clueboards/660 layouts
To do:
  • Get some more renders
  • Finalise colours
  • Finalise kit design
  • Design novelties, if wanted
  • Design a Planck and ErgoDox kit, if wanted
« Last Edit: Thu, 13 April 2017, 10:09:42 by janglad »
Offline Tally810
Re: [IC] GMK Night Sky - The Beauty Of The Night
« Reply #1 on: Mon, 10 April 2017, 17:32:33 »
Looks like nautilus kinda to me but I do like it.  Not enough yellow sets
Sent from my SM-G928V using Tapatalk
« Last Edit: Mon, 10 April 2017, 17:35:30 by Tally810 »
Offline oatmicro
« Reply #2 on: Mon, 10 April 2017, 18:41:03 »
Is this the Night Sky that Sherryton was talking about on https://geekhack.org/index.php?topic=88776.0#msg2399467  ?
But... Why Massdrop?
Or they just have the same name by accidentally?
Offline fatpolomanjr
« Reply #3 on: Mon, 10 April 2017, 18:46:38 »
Like a GMK Calm Depths x Nautilus. I'm really digging it.
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
Offline sherryton
  • Kībōdo
    • Originative
« Reply #4 on: Mon, 10 April 2017, 18:50:50 »
I didn't know someone already had a similar name, but this isn't the one we were doing haha.
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #5 on: Mon, 10 April 2017, 18:54:38 »
That seems to be pure coincidence! We probably came up with the same name or something? Although I did start using the name Night Sky more than 2 months ago now.
Offline oatmicro
« Reply #6 on: Mon, 10 April 2017, 18:58:58 »
Can't believe something like this would happened  :))
Offline sherryton
  • Kībōdo
    • Originative
« Reply #7 on: Mon, 10 April 2017, 19:02:01 »
Sorry about that! If I can give a recommendation though... your set has hints of yellow in it which matches the stars. You should definitely name it Starry Night!
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #8 on: Mon, 10 April 2017, 19:07:18 »
That actually was the original name! I believe I got the idea for this set when looking at Starry Night, the painting. But I went with Night Sky in the end since I thought it just sounded better :)
Offline Vigrith
« Reply #9 on: Tue, 11 April 2017, 00:04:11 »
I like it! Pretty similar to Nautilus but still different enough.
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« Reply #10 on: Tue, 11 April 2017, 01:02:31 »
Yay after this set then JG60% case, super excited!!!! :thumb:
Offline midnight2903
« Reply #11 on: Tue, 11 April 2017, 03:45:04 »
Seems quite good, but my wallet's thin.
Offline amnesia0287
  • Formerly Amnesia
« Reply #12 on: Fri, 23 February 2018, 15:25:50 »
bring it back bump :O
Offline azachhh
« Reply #13 on: Fri, 23 February 2018, 16:32:35 »
Yes, I would like to see this happen!
Offline amnesia0287
  • Formerly Amnesia
« Reply #14 on: Fri, 23 February 2018, 16:46:50 »
Batman Approves
