Author Topic: Looking for some help understanding TMK  (Read 2452 times)
Offline apanzerj
« on: Tue, 25 April 2017, 00:27:07 »
Is there a good intro article or something that goes over the very basics? I'm just trying to get layer switching working. I can't seem to switch layers back after going forward. IE: I can get to layer 1 but then I can't get back.
I'm using a USB-to-USB converter.
#include "keymap_common.h"
const uint8_t keymaps[][MATRIX_ROWS][MATRIX_COLS] PROGMEM = {
   KEYMAP_ALL(
              F13, F14, F15, F16, F17, F18, F19, F20, F21, F22, F23, F24,
    ESC,      FN1,  F2,  F3,  F4,  F5,  F6,  F7,  F8,  F9,  F10, F11, F12,           PSCR,SLCK,PAUS,    VOLD,VOLU,MUTE,PWR,     HELP,
    GRV, FN1,   2,   3,   4,   5,   6,   7,   8,   9,   0,   MINS,EQL, JYEN,BSPC,     INS, HOME,PGUP,    NLCK,PSLS,PAST,PMNS,    STOP,AGIN,
    TAB, Q,   0,   E,   R,   T,   Y,   U,   I,   O,   P,   LBRC,RBRC,     BSLS,     DEL, END, PGDN,    P7,  P8,  P9,  PPLS,    MENU,UNDO,
    CAPS,A,   S,   D,   F,   G,   H,   J,   K,   L,   SCLN,QUOT,     NUHS,ENT,                         P4,  P5,  P6,  PCMM,    SLCT,COPY,
    LSFT,NUBS,Z,   X,   C,   V,   B,   N,   M,   COMM,DOT, SLSH,     RO,  RSFT,          UP,           P1,  P2,  P3,  PEQL,    EXEC,PSTE,
    LCTL,LGUI,LALT,MHEN,HANJ,     SPC,      HAEN,HENK,KANA,RALT,RGUI,APP, RCTL,     LEFT,DOWN,RGHT,    P0,       PDOT,PENT,    FIND,CUT
    KEYMAP_ALL(
    ESC,      F1,  FN0,  F3,  F4,  F5,  F6,  F7,  F8,  F9,  F10, F11, F12,           PSCR,SLCK,PAUS,    VOLD,VOLU,MUTE,PWR,     HELP,
    GRV, 1,   FN0,   3,   4,   5,   6,   7,   8,   9,   0,   MINS,EQL, JYEN,BSPC,     INS, HOME,PGUP,    NLCK,PSLS,PAST,PMNS,    STOP,AGIN,
    TAB, Q,   W,   1,   R,   T,   Y,   U,   I,   O,   P,   LBRC,RBRC,     BSLS,     DEL, END, PGDN,    P7,  P8,  P9,  PPLS,    MENU,UNDO,
const action_t PROGMEM fn_actions[] = {
        ACTION_LAYER_TOGGLE(0),
        ACTION_LAYER_TOGGLE(1)
Offline henz
  • What?
Re: Looking for some help understanding TMK
« Reply #1 on: Tue, 25 April 2017, 08:12:58 »
toggle means switch to
what you are looking for is ACTION_LAYER_MOMENTARY,
which changes to lvl2 while holding down and when released you get back.
Offline TalkingTree
    • My projects
« Reply #2 on: Tue, 25 April 2017, 09:20:07 »
By the look of your code, everything should work as intended.
I don't know if it matters much, but your second line should read like this:
Code: [Select]
const uint8_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {You're missing PROGMEM.
Offline apanzerj
« Reply #3 on: Tue, 25 April 2017, 21:15:59 »
I didn't want to do the momentary, I wanted to actually switch to that layer.
I'll add PROGMEM in there and report back.
Offline Thereminz
« Reply #4 on: Tue, 25 April 2017, 23:02:05 »
i used
http://qmk.sized.io/
it makes it a bit easier
your tg(whatever layer) button should also be your trns button to go back to your previous layer
Offline apanzerj
« Reply #5 on: Tue, 25 April 2017, 23:53:10 »
I don't get what you just said there. What does tg mean? If one of my FN keys is set to toggle layer 1 then you can't use trns because that would just still do toggle layer 1, right?
Offline TalkingTree
    • My projects
« Reply #6 on: Wed, 26 April 2017, 05:10:49 »
Change this array:
Code: [Select]
to:
Code: [Select]
static const action_t PROGMEM fn_actions[] = {
    [0] = ACTION_LAYER_TOGGLE(1),
    [1] = ACTION_LAYER_TOGGLE(0)
Offline hasu
  • @tmk
« Reply #7 on: Wed, 26 April 2017, 08:50:57 »
TOGGLE just turns on/off specific layer.
So you will have to useTOGGLE(1) to turn off layer 1 if you activated it with TOGGLE(1).
these may help.
https://github.com/tmk/tmk_core/blob/master/doc/keymap.md
https://github.com/tmk/tmk_keyboard/wiki/FAQ-Keymap
« Last Edit: Wed, 26 April 2017, 08:55:32 by hasu »
