Author Topic: Redundant title title?  (Read 4026 times)
Offline ander
  • I type, therefore I am
« on: Fri, 05 May 2017, 17:43:31 »
Erm, not to be annoying or anything, but isn't "Keyboard Keycaps" redundant, like "PIN number"?
Not to mention that the term caps is widely misused in the MK community. The proper term, used throughout the entire classic MK era by manufacturers and users alike, is button. ("Key" is also acceptable, though it was used mostly in the context of operation.)
KB and computer people didn't start referring to "caps" till IBM invented the two-piece button, consisting of a cap on a stem. You don't call the buttons on any other switching devices "caps", do you? For some reason, though, MK people started using the term for one-piece buttons. It's surprising this misuse continues, considering how much MK people are into accuracy, otherwise.
If you're interested (and I won't be surprised if you're not, as I'm used to being a "voice in the wilderness" on this), we're having a discussion about it here.
Re: Redundant title title?
« Reply #1 on: Fri, 05 May 2017, 18:02:44 »
Right. So just say "keycaps."
Offline libertycannon
« Reply #2 on: Fri, 05 May 2017, 22:35:58 »
No its not the same as a PIN number.  You aren't an outlier here you are just wrong.  Good info on keycaps though!
Offline gnmar2723
« Reply #3 on: Sat, 06 May 2017, 23:18:59 »
I'm with romevi on this one
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #4 on: Sat, 06 May 2017, 23:59:07 »
Wow, I didn't know that it was IBM that popularised that word.
To be honest though, I usually just end up calling them 'keycaps' (without the preceding 'keyboard') so it's not a huge issue for me.
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
« Reply #5 on: Sun, 07 May 2017, 00:11:30 »
The subforum is called keyboard keycaps. That's what he's getting at, I think.
Offline _haru
« Reply #6 on: Sun, 07 May 2017, 01:03:49 »
That's what I was referring to, but yeah, I agree.
« Reply #7 on: Sun, 07 May 2017, 22:05:51 »
There's not many devices that use keycaps other than keyboards (numpads are little keyboards, Nostromos are game input devices with a mini built-in keyboard), so it kinda goes without saying that they are keycaps for keyboards.
Although good luck getting the title changed :p
Offline Auk
« Reply #8 on: Sat, 20 May 2017, 04:49:41 »
This thread isn't annoying, but the title is clumsy and I certainly do find it jarring and awkward. Every time I want to navigate to this forum I'm finding it requires just slightly more thought and focus than elsewhere. I think the row with 'keyboard of the month' child forum isn't helping either, it breaks the flow. Intuitively I expect the index page to read:
  • Keyboards
  • Keycaps
but I can't see admin changing it unless they are extremely bored, or indulging in some severe procrastination to avoid doing something else.
Offline fanpeople
« Reply #9 on: Sat, 20 May 2017, 04:58:05 »
yeah been drinking sob**** IT ANDER IS RIGHT START THE REVOLUTION CHANGE THE TITLE
