Author Topic: Best Foam for Dampening Your Keyboard?  (Read 36765 times)
Offline Encabulator
« on: Tue, 09 May 2017, 09:11:20 »
Once in a while I see people line the bottom of their 60% case with a thin sheet of foam to reduce the reverberation that the hollow metal case creates. I'm somewhat interested in experimenting with this and trying to coat the entire interior of the case (if possible). What material should I be using for this?
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline kmba
  • Formerly tameone
Re: Best Foam for Dampening Your Keyboard?
« Reply #1 on: Tue, 09 May 2017, 09:14:53 »
Neoprene foam, sometimes called sponge neoprene. 1/16th or 1/8" thickness, depending on the gap you have. You can get rolls on Amazon.
keyboards.
« Reply #2 on: Tue, 09 May 2017, 09:17:35 »
https://www.google.com/search?q=site%3Ageekhack.org+foam+liner&ie=utf-8&oe=utf-8
^^ this is a neat trick to find a lot of things before posting a new thread
This thread https://geekhack.org/index.php?topic=89231.0 has a link to here https://www.reddit.com/r/MechanicalKeyboards/comments/63invd/news_hhkb_vibration_absorbing_mat/dfuo37t/ which links this http://i.imgur.com/7wpxLvZ.jpg and in the comments @OfTheWild says it is just 1/8" neoprene foam you can google that...amazon has some
oh and if anyone wants to go totally crazy http://www.foamforyou.com/CustomCutFoam.htm
There is totally a business opportunity here as well...buy a huge sheet...cut it up for specific keyboards....mark it up....profit...  8)
Oh hey this is cheap http://www.ebay.com/itm/Neoprene-Foam-Closed-Cell-Sponge-EPDM-1-8-thick-x-12-x-12-FREE-SHIPPING-/282021453877?
« Last Edit: Tue, 09 May 2017, 09:23:41 by SpAmRaY »
Offline zslane
« Reply #3 on: Tue, 09 May 2017, 11:52:18 »
I would recommend sorbothane acoustic dampening sheets. You can buy them from Amazon.
Offline Encabulator
« Reply #4 on: Tue, 09 May 2017, 16:52:00 »
Kinda reminds me of somebody who bought rubber and cut it for sound dampening pads in the classified ;)
« Reply #5 on: Tue, 09 May 2017, 17:24:44 »
Fohats matt's are great for going under the keyboard.
Offline ander
  • I type, therefore I am
« Reply #6 on: Wed, 10 May 2017, 04:36:02 »
Just go to a craft store and get some craft foam like this. It's super-cheap and it works great.
Offline killyou
« Reply #7 on: Wed, 10 May 2017, 11:08:59 »
I just bought shelf liner for 2$, cut it into pieces and put it inside my Magicforce 68. Also I've put two pieces together and cut to the size of the board and that's what I keep between my keyboard and the desk to isolate them. I don't hear any ping nose nor the wood echo, just keycaps clacking. Total cost 15 minutes of work and 2$. If you ask me the isolation of the keyboard from the desk helps more for the ping "issue" than stuffing foam inside.
Offline lunas
« Reply #8 on: Wed, 10 May 2017, 22:50:39 »
Second this. It's not cheap, but they are the most effective. 1/10" thickness is plenty.
Amazon link
Pok3r Whitefox
Offline klennkellon
  • I like bottoming out
« Reply #9 on: Wed, 10 May 2017, 22:56:14 »
Go to a local hardware store and buy a roll of shelf liner. Preferably the non-mesh one. Cheap and works.
If you want to go all of the way go buy the acoustic dampening sheets.
Offline DaBubbs
« Reply #10 on: Thu, 11 May 2017, 20:56:56 »
Amazon link
Do people put this inside a HHKB., especially a Type-S? If so, what exactly does it do?
When you are dead, you don't know that you are dead. It is difficult only for the others.
It is the same when you are stupid.
Offline drewafx
« Reply #11 on: Thu, 11 May 2017, 21:56:18 »
« Last Edit: Fri, 25 November 2022, 22:42:22 by drewafx »
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #12 on: Thu, 11 May 2017, 22:06:23 »
Amazon link
Not a drastic difference, and definitely one thats tough to hear on camera however I made a comparison video actually:
-Dana
Offline killyou
« Reply #13 on: Fri, 12 May 2017, 07:08:16 »
You would gain more if you would cancel the bottom out noise with the hypersphere rings or chinese MX compatible stems with the rings preinstalled.
Offline PleaseBeMyFriend
  • formerly honsoo
  • reddit /u/PleaseBeMyFriend
« Reply #14 on: Sat, 13 May 2017, 12:25:27 »
Would this work as well in an FC660C?
Offline OfTheWild
« Reply #15 on: Sun, 14 May 2017, 12:01:45 »
In my opinion, the fc660c is already rock solid and I don't think there was any impact from adding foam.
-Dana
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #16 on: Sun, 14 May 2017, 13:54:53 »
I have some of the above mentioned sorbotane mats in my FC660M and it does make a difference. But you are right, those boards are already rock solid and don't need much dampening.
|||My other keyboards :
x
  • formerly honsoo
« Reply #17 on: Sun, 14 May 2017, 16:30:27 »
Thanks for the input. I do enjoy the steel plates Leopold puts in their boards.
