Author Topic: RF 104 Silenced Dome Layout?  (Read 2049 times)
Offline DaBubbs
« on: Sat, 13 May 2017, 15:54:47 »
I see on EK's website the following chart for the gram accuation  layout for the silenced RF 104:
168349-0
So for the D and F keys for example, are the domes underneath 35g or 45g? The shading is throwing me off. The shading makes it look very gradual, like the G is 45g, the F is 42g, the D is 40g, the S is 38g, and the A is 35g.
55g domes are black,  45g domes are grey, and 35g domes are brown right? I assume when I open the RF 104 up, I will be able to tell which domes are which, right? And I assume that the RF 104 silenced is made up of only those three domes.
Any help clearing this up would be most appreciated. Thanks!
When you are dead, you don't know that you are dead. It is difficult only for the others.
It is the same when you are stupid.
Offline PleaseBeMyFriend
  • formerly honsoo
  • reddit /u/PleaseBeMyFriend
Re: RF 104 Silenced Dome Layout?
« Reply #1 on: Sat, 13 May 2017, 17:34:44 »
I was led to believe the alphas were all 35g but I could be wrong
Offline DaBubbs
« Reply #2 on: Sat, 13 May 2017, 19:27:32 »
The photo was taken right from the EK website: https://elitekeyboards.com/products.php?sub=topre_keyboards,rf104&pid=xf01ts
After some searches, it looks like the Realforce variable's come in big sheets and it is not separated by color / dome type: https://geekhack.org/index.php?topic=68076.0
