Author Topic: Rare Lexmark-branded M13  (Read 3874 times)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« on: Wed, 24 February 2010, 15:13:58 »
Here's an M13 with a Lexmark logo instead of an IBM logo, with all the documentation. In addition, it has a serial/DIN Y cable instead of the more common PS/2 version.
Offline ch_123
« Reply #1 on: Fri, 26 February 2010, 03:53:48 »
Nice find. That Serial/AT combination is something that I thought was only used by Unicomp.
Now what really interests me is what they did with the PS/2 passthrough port on the back. Is it blanked out? Did they hack a serial port on it? I asked the seller to find out.
Offline TexasFlood
« Reply #2 on: Fri, 26 February 2010, 07:19:47 »
Unfortunately not a good thing for many folks as many newer PCs don't have a serial port.
« Reply #3 on: Fri, 26 February 2010, 07:52:52 »
My computers do.
I heard of those serial/AT cables and have been looking for one for a while to use with my M5-2.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #4 on: Fri, 26 February 2010, 12:36:39 »
M13s don't have detachable cables, MW. That means the cable you're looking for would need to have been supplied with an M5-2, so you'd be advised to look for those.
kishy.ca
Offline TexasFlood
« Reply #5 on: Fri, 26 February 2010, 14:40:25 »
Quote from: microsoft windows;160833
My computers do.
You might be able to pick this one up on a good deal then.
Offline EverythingIBM
« Reply #6 on: Sun, 07 March 2010, 21:58:59 »
Quote from: TexasFlood;160826
These workstations still have the old dual-serial port setup: http://cgi.ebay.com/LOT-OF-5-IBM-IntelliStation-M-Pro-CORE-2-DUO-2-66GHZ-PC_W0QQitemZ290408862724QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item439db79404
And they were made fairly recently.
But yeah, standard "I bought it at bestbuy" computers don't have serial.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #7 on: Sun, 07 March 2010, 22:07:18 »
Quote from: EverythingIBM;162420
Some might, just pins on the mobo though with no header. Best not to expect it though.
kishy.ca
Offline didjamatic
« Reply #8 on: Sun, 07 March 2010, 22:12:52 »
All my computers have a serial port:
« Reply #9 on: Sun, 07 March 2010, 22:28:42 »
Quote from: didjamatic;162424
Yeah, and one less USB port =p
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #10 on: Sun, 07 March 2010, 22:32:55 »
I think the USB based serial port controllers have compatibility issues with older software...I could describe why in laymens terms but not in a very technical sense:
Rather than referencing "COM1" the software may be attempting to access it by interrupt or IO port.
Maybe that's not so untechy.
kishy.ca
