Author Topic: Looking for a hot swap keyboard  (Read 11041 times)
Offline Geass
« on: Wed, 07 June 2017, 08:51:02 »
Hi,
so I was looking for a hot swap keyboard. It should have an ISO (German) layout with possible RGB lighting. The size  doesn't really matter but TKL and full-size are preferred. I know that there are keyboards like the Glorious PC Gaming Race and the Input Club K-Type but these all have ANSI layout, so could there be a way of "changing" the layout to ISO? Well I just hope that somebody knows if there any keyboards like that!
« Last Edit: Wed, 07 June 2017, 08:55:03 by Geass »
Offline rioc
Re: Looking for a hot swap keyboard
« Reply #1 on: Wed, 07 June 2017, 08:59:08 »
Hi,
The easiest way to get that is to get a keyboard kit (pcb (that supports ISO), case, etc.) and then get Holtite sockets.
Holtites are installed very EASILY and also available for the led holes, so you can have it fully hot-swappable.
Sent from my MHA-L09 using Tapatalk
Offline Geass
« Reply #2 on: Wed, 07 June 2017, 09:04:36 »
Hi,
Ok that would be good. I've also alerady looked up DIY kits but I'm not sure which ones are the best for hot swapping, because I've read about PCBs that don't support the holtites. Do you know any kits which could be compatible?
Offline rioc
« Reply #3 on: Wed, 07 June 2017, 09:14:16 »
Hi,
sure, gimme a minute and I'll look for the compatibility table for you
Offline rioc
« Reply #4 on: Wed, 07 June 2017, 09:15:24 »
Hi,
Compatibility Table: https://docs.google.com/spreadsheets/d/1K1qt70E2mcuaHBXYrpPHXlpl7FNaXLo0u_TOe67cVdY/pubhtml?gid=986897710&single=true
where you can get them: https://docs.google.com/spreadsheets/d/1K1qt70E2mcuaHBXYrpPHXlpl7FNaXLo0u_TOe67cVdY/pubhtml?gid=1901814151&single=true
I myself have them in my RedScarf II+ ver.C (RS68), RedScarf III ver.A (RS96) and Sentraq S60-X at the moment. They are a perfect fit with those PCBs. (And got both gold and tin and for that small difference I suggest getting the gold plated ones)
« Last Edit: Wed, 07 June 2017, 09:17:17 by rioc »
Offline Geass
« Reply #5 on: Wed, 07 June 2017, 09:16:32 »
Thanks a lot!
Gesendet von meinem SM-G955F mit Tapatalk
Offline rioc
« Reply #6 on: Wed, 07 June 2017, 09:17:56 »
Thanks a lot!
Seems like you're from a German speaking area? (There are cheaper sources (shipping) within Europe such as MOUSER electronics (I'm from Switzerland, got them there).)
Offline Geass
« Reply #7 on: Wed, 07 June 2017, 09:18:26 »
Hi,
But I don't want to spend more than 200-250$ on the keyboard. Won't it cost more?
Offline rioc
« Reply #8 on: Wed, 07 June 2017, 09:18:55 »
Hi,
Could be depending on the kit and case you get...
Offline Geass
« Reply #9 on: Wed, 07 June 2017, 09:19:39 »
Thanks a lot!
Yeah, I'm from Luxembourg.
Offline Geass
« Reply #10 on: Wed, 07 June 2017, 09:21:07 »
Hi,
Can I get the Red Scarf kits on non-group buying sites?
Offline rioc
« Reply #11 on: Wed, 07 June 2017, 09:32:07 »
There might be some on TaoBao or Aliexpress...
Didn't find if it's compatible, but the Phantom is a cheap TKL PCB, but you'll wanna go sure they fit on that.
Offline Geass
« Reply #12 on: Wed, 07 June 2017, 09:33:37 »
But did you get yours on massdrop and how much did the sets cost then?
Offline rioc
« Reply #13 on: Wed, 07 June 2017, 09:36:41 »
yeah, the RSII was 145$ (with shipping) and the RSIII was 435$ (but I took all kits. Base price was 240$ or so iirc)
Offline Geass
« Reply #14 on: Wed, 07 June 2017, 09:39:02 »
Do the keycaps come with the kit and are they ISO, ANSI or both included?
Offline rioc
« Reply #15 on: Wed, 07 June 2017, 09:40:35 »
keycaps were extra (did come with a full GMK set though (which includes ISO))
But you can get good quality sets for a cheap price via aliexpress or over the classifieds thread
Offline Geass
« Reply #16 on: Wed, 07 June 2017, 09:47:57 »
Have you installed hot swap LEDs?
Offline rioc
« Reply #17 on: Wed, 07 June 2017, 09:49:58 »
yes... works well too :)
Offline Geass
« Reply #18 on: Wed, 07 June 2017, 10:05:28 »
Is there a lot soldering requiered?
Offline rioc
« Reply #19 on: Wed, 07 June 2017, 10:08:18 »
with holtites none! They're what is called "press-fit"... (only need to solder if they're too lose or won't fit)
Offline rioc
« Reply #20 on: Wed, 07 June 2017, 10:09:02 »
Thanks a lot!
Luxembourg? I lived there from 1y to 5.5years old... but forgot most of the language again :(
Offline Geass
« Reply #21 on: Wed, 07 June 2017, 10:09:23 »
Oh, ok that's great!
Offline Geass
« Reply #22 on: Wed, 07 June 2017, 10:11:30 »
Well thanks for the help until now, I'll just wait for the next Massdrop Groopbuy and try to get the Red Scarf Ver. C as cheap as possible.
Offline Geass
« Reply #23 on: Wed, 07 June 2017, 10:23:09 »
Sorry for the lots of questions, but could I technically buy, for example, a Corsair Keyboard and modify it to make it a hot swap keyboard?
Offline rioc
« Reply #24 on: Wed, 07 June 2017, 10:38:24 »
technically possible, but you'll have to desolder all the switches for that
Offline Geass
« Reply #25 on: Wed, 07 June 2017, 10:40:09 »
would that be worth it? Not the keyboard price, but the effort.
Offline rioc
« Reply #26 on: Wed, 07 June 2017, 10:41:00 »
would that be worth it, not the keyboard price, but the effort
well, if the sockets won't fit it wouldn't be worth it... depends how much time you've got ;P
Offline Geass
« Reply #27 on: Wed, 07 June 2017, 10:42:53 »
ok and what about ANSI layout? Do you have any experiences with it? Is it difficult to switch from ISO to ANSI?
Offline rioc
« Reply #28 on: Wed, 07 June 2017, 10:47:53 »
I switch between the two layouts frequently. You get used to it pretty fast though... and if you need special symbols and just wanna stick with ansi, use the ANSI international keyboard layout (software layout given by your OS)
Offline Geass
« Reply #29 on: Wed, 07 June 2017, 10:50:37 »
Well, then I'll probably just get the Glorious PC Gaming Race keyboard, since every criteria, except for the layout, is fulfilled.
Offline zurikade
  • Math Always Wins.
« Reply #30 on: Wed, 07 June 2017, 11:03:38 »
Honestly I have a Glorious with Gateron reds and I can't speak highly enough about it. Fantastic build, incredible lighting and a wonderful price. Truly exceptional.
Offline Geass
« Reply #31 on: Wed, 07 June 2017, 11:06:46 »
Okay, then my decision is taken and I'll get a Glorious keyboard with Gateron blues and reds and I'll also get the Kailh switches from Massdrop. Thanks for answering my questions, really appreciated!
