Author Topic: Question about realforce 89u JIS and hasu  (Read 2067 times)
Offline Randalljai
« on: Sun, 11 June 2017, 00:53:08 »
Hello! not sure if this is the right area to post for help, but I hope I am. I just picked up the realfoce 89u JIS and there were some things I wanted to do, was hoping I could get used to the ISO layout but...yeah..its too different. Here are the things I want to do:
Here is a picture with boxes detailing what I want to do below: http://imgur.com/a/3okAc
the red square will be all spacebar function
the blue square will turn into a windows key
the yellow line's function would swap (currently the yellow key doesn't have a function, so when swapped, it would move up a row and turn into a enter key as well, the green square
and the pink box will turn into backspace
My question is, will the hasu work for this. windows 10 isn't picking up some keys on this keyboard so I'm not sure if the hasu will work Any help is appreciate!!
Offline Tactile
Re: Question about realforce 89u JIS and hasu
« Reply #1 on: Mon, 12 June 2017, 09:55:03 »
AFAIK Hasu doesn't make a controller for the Realforce. But he does make a USB to USB converter, which adds programming to a USB keyboard without modification. Maybe that's what you're interested in? If that's so, it's probably best to ask here.
REΛLFORCE
